March 25, 2026, 02:41:37 PM *
Author Topic: Balancing Beads Kit  (Read 2425 times)
Paxton
So Cal
« on: March 17, 2012, 10:12:39 PM »
I read here about a product like this one.  Is this particular one recommended?  Undecided
http://www.ebay.com/itm/Honda-Goldwing-Valkyrie-Balancing-Beads-Kit-Internal-Tire-Balancing-Beads-/140724748755?pt=Motorcycles_Parts_Accessories&hash=item20c3d941d3&vxp=mtr
If not, could you provide a link to the "right" product?  ???
Thanks!  cooldude
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
BonS
Blue Springs, MO
« Reply #1 on: March 17, 2012, 10:23:02 PM »
This is the usual source for small amounts of balancing beads.
http://www.innovativebalancing.com/motorcycle.htm
Some folks buy in bulk from another source. Let me know if you're interested and I'll dig them up.
da prez
Wilmot Wi
« Reply #2 on: March 18, 2012, 12:22:19 AM »
  I thought the manufacturer was in Crystal Lake Il. I do need bulk as I want to do all the tires on all vehicles.  Any info would help
                                                       da prez
mario
NW Houston, TX
« Reply #3 on: March 18, 2012, 02:17:13 AM »
http://www.ride-on.com/motorcycle-formula-mot.html
if you're going to do beads, do ride-on.  imo.
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
bogator
IN GOD WE TRUST------KK4KSN-------
Valley,Al
« Reply #4 on: March 18, 2012, 04:19:24 AM »
I use ---counteractbalenceing.com----I get them at covington truck parts in Opelika AL--for 14 bucks a bag--12 oz--I have them in all my cars and trucks --I have the dyna beads in my Valk--hope this helps---heres a website for --www.quacko.com---for 5 lbs of dyna beads in a quart jar-they are in Crystal lake IL.---
BonS
Blue Springs, MO
« Reply #5 on: March 18, 2012, 06:28:23 AM »
Exactly right. The folks at Quacko.com know that we use their beads for balancing. They use them as grinding media. I'd call them to make sure that you're getting the right beads for balancing. They used to sell to InnovativeBalancing so they know what you want. Good people.
PharmBoy
Lawton, Ok
« Reply #6 on: March 18, 2012, 07:41:47 AM »
No matter whose beads you decide to buy, if you are going to introduce them through the valve stem, I would suggest that you obtain a longer plastic tube (18-24").  That way it is possible to "trickle" them down the tube a few at a time and they arrive at the valve stem with a much higher velocity which tends to carry them on through the valve stem.  Otherwise, they clog up the valve stem and the whole exercise becomes quite frustrating.  Even at best, this operation will take a little time.  Oh yes, a car tire requires 3 oz. of beads unless it is pretty well balanced to start with.  At least, that is my findings...Jim
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Jeff K
« Reply #7 on: March 18, 2012, 03:47:23 PM »
the proper link is
http://www.quackco.com/
This is the stuff in bulk.
CASABROKER
« Reply #8 on: March 18, 2012, 07:15:18 PM »
If you have an impact ratchet the head on the valve stem and vibrate it when you put the beads in from the plastic bottle with the tubing.  The will jiggle right in with no problems quick and easy.
da prez
Wilmot Wi
« Reply #9 on: March 18, 2012, 08:19:14 PM »
  JEFFK thanks much. I was not able to find it under dyna beads. They are just down the road,
                                                    da prez
Paxton
So Cal
« Reply #10 on: March 22, 2012, 01:34:26 AM »
Folks;
Thank you for all the leads.  Cheesy
RIDE SAFE  cooldude
J. Paxton Gomez
So Cal... 91205
