March 26, 2026, 12:22:03 AM *
Author Topic: Fork Question  (Read 1409 times)
forjj
Luray, VA
« on: May 11, 2012, 07:20:13 PM »
Okay, stupid question, but here goes--why is there a hole on the bottom (the end) of one fork, and not the other?  I want to attach a chrome piece to the ends of the forks, and found the hole on the one side, and started working on attachment method, then discovered that there wasn't a hole on the other side.  Any thoughts on drilling a hole in the bottom of the other fork???
2000 Interstate Blue/Silver
2005 Corvette
1989 F250 Diesel
1979 Ford 1100 Diesel Tractor
"I don't know where I'm going, I see no reason in being late"
« Reply #1 on: May 12, 2012, 07:18:49 AM »
The hole is for access to an allen head bolt that bolts the damper to the bottom of the fork inside. It uses a crush washer to seal off the fork so it doesn't leak fork oil. The left fork doesn't have the damper inside so no hole is necessary.
forjj
Luray, VA
« Reply #2 on: May 12, 2012, 12:25:17 PM »
Thanks!
2005 Corvette
1989 F250 Diesel
