March 26, 2026, 12:22:09 AM *
Author Topic: Plug Wires  (Read 1542 times)
Hedgehog
« on: May 14, 2012, 07:00:55 AM »
Just wondering what folks recommendations for replacing spark plug leads / wires would be?
The standard Honda set (which comes complete with the rubber plugs on the end) is very expensive over here in the UK... about $250 - Is it the same in the US?
I keep seeing these nology wires offered - any good?
I would wonder with a replacement set that are not OE whether water would get into the hole / shaft in which the plugs sit..?
Any advice greatly appreciated.
HH
Dave King
Proud owner of Honda Valkyrie F6C 1997 Standard
& owner of BigBikeMad.com
BonS
Blue Springs, MO
« Reply #1 on: May 14, 2012, 08:00:11 AM »
You can buy bulk 7mm, copper core, wire for cheap and put on the old OEM boots yourself. It should be less than $20 easily. John Schmidt did a write up on changing out the OEM boots: http://www.valkyrieriders.com/ShopTalk/plugwires.pdf
There is a drain hole at the bottom of the spark plug well so if you decide to use non-OEM boots you will be fine as long as the drain hole is clear.
