March 26, 2026, 03:08:34 AM *
Author Topic: WD 40 another goofy use  (Read 3288 times)
garyheskett All 49 x 3 st.louis
St. Louis, Missouri
« on: May 23, 2012, 03:00:57 PM »
I have a 97 Standard with 113.000 miles on it. Today I was in the garage doing a few things to the Valk and noticed I had a little "glue smudge" on the taillight. Got a Kleenex and sprayed a little WD 40 on it and wiped off the taillight lense. The lense is very dull and looks its age. The spot I cleaned off looked bright red and looked like new,  so....a little more WD 40 and the whole taillight lense looks real red and looks brand new. Probably will only last till the next wash, but for a week or so the taillight lense looks new.  Only took 30 seconds to do it, so when I wash it again, I"ll probably spray a little more on it.  One of the many goofy things to do with WD 40!!!  Any other goofy uses for the stuff???
« Reply #1 on: May 23, 2012, 04:02:39 PM »
Before i repaired the the side cover hold downs on the center section with velcro i had duct taped my side covers to the center section. uglystupid2 This left that sticky hard to remove goop that most folks are familiar with. crazy2 A little W D 40 on a micro fibre cloth and voila no more sticky kaka goop!! Grin And the W D 40 residue washed off with soap and water and with an application of Turtle Wax Synthetic Silicone Wax ya can't see where the tape gunch was!! cooldude RIDE SAFE.
Challenger
« Reply #2 on: May 23, 2012, 05:07:38 PM »
It takes tar off your mufflers or paint, safer than ether for starting gas or diesel engines
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #3 on: May 23, 2012, 05:15:08 PM »
I have used it as starting fluid also.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
« Reply #4 on: May 23, 2012, 05:49:53 PM »
Kills large bugs.... slowly.
YoungPUP
Valparaiso, In
« Reply #5 on: May 23, 2012, 05:53:55 PM »
Used to use it to dry out the distributor on my 86 Cherokee when doing stupid things in large wet muddy areas.
99 STD (Under construction)
FryeVRCCDS0067
Brazil, IN
« Reply #6 on: May 23, 2012, 06:54:50 PM »
Glad to know it's not just me.  Grin It takes quite a while to kill carpenter bees with it.
WD is also great for cleaning black, nasty grease and grime off your hands before washing with soap and water.
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #7 on: May 23, 2012, 07:35:29 PM »
Any other tips for those bumbling flying bastards? We had orkin out to spray and get rid of them, but that just attracted them more!
sugerbear
wentzville mo
« Reply #8 on: May 23, 2012, 10:28:43 PM »
brake cleaner
RudyF6
Chelsea, Michigan
« Reply #9 on: May 24, 2012, 05:00:20 AM »
brake cleaner
And a lighter.....    crazy2
You can never be lost if you don't care where you're going!
98 "Tourerstate" (Std. with I/S bags/trunk)
98 Tourer solo ride
81 CBX
bassman
« Reply #10 on: May 24, 2012, 05:19:59 AM »
Other uses for WD-40.....
http://www.snopes.com/inboxer/household/wd-40.asp
F6Cruzer
Robbinsville, NC
« Reply #11 on: May 24, 2012, 08:03:50 AM »
Use Borax in the bee dens...boric acid...they hate it.
I live near the Tail of the Dragon!
« Reply #12 on: May 24, 2012, 08:38:08 AM »
They are important pollinators... Change your wood over to treated yellow pine, they don't hardly
like that at all...
Before I cared that they were pollinators, I found that they sail a long way if you hit them
with a tennis racket...
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #13 on: May 24, 2012, 08:49:26 AM »
like that at all...
Changing the wood is out of the question - it's the soffit and fascia on the house they've grown to love.  When she had the house painted and gutters installed, they didn't paint or flash over the exposed backside of the fascia and that's where they're nesting.
I've become quite adept at swatting them with the grill spatula or my baseball hat, and the spatula works great as a guillotine to slice them in half as the enter/emerge from the hole they've bored, but I'm ready to be rid of them.
Orkin used a .5oz/gallon mixture of Bifenthrin, which I've read is supposed to be effective, I guess we'll just have to have them come back out and re-spray because I guess the guy didn't spray everywhere.  He also tried to tell me that the droppings left on the stucco walls aren't feces but sawdust.  uglystupid2
There is an acre of wooded area behind her house that they can nest in and pollenate until their hearts are content - all I want them to do is stay out of the house.
FryeVRCCDS0067
Brazil, IN
« Reply #14 on: May 24, 2012, 07:10:05 PM »
Starting fluid (either) kills flying/stinging critters faster than anything I have ever seen. I don't know if it just knocks them out or kills them though since I always step on them afterwards anyway.
« Reply #15 on: May 24, 2012, 07:23:38 PM »
Tennis / Badminton racket is my weapon of choice  cooldude
« Last Edit: May 24, 2012, 07:26:40 PM by Smokinjoe-VRCCDS#0005 » Logged
texaninsouthfl
Serving those who served us...
East Lake County, Florida
« Reply #16 on: May 24, 2012, 09:40:56 PM »
Works great on spiders too!  A can of aerosol deodorant and a lighter is fun too... think pint sized flame thrower.  crazy2
Farther
Quimper Peninsula, WA
« Reply #17 on: May 25, 2012, 06:46:32 PM »
Boric acid and borax are two different things.
~Farther
« Reply #18 on: May 26, 2012, 11:59:50 AM »
Carburetor cleaner is the best even on hornets they died instantly. Brake clean the can still fly a bit. I had to plug up every single little crack and crevice to make sure that not only flying insects don't get in but also ants too. They have found that some insecticides are causing the colony collapse and killing the bees
Farther
« Reply #19 on: May 26, 2012, 07:26:03 PM »
Just plain soapy water knocks the flying critters down real good without all the toxicity of the pesticides or solvents.
~Farther
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #20 on: May 26, 2012, 08:30:32 PM »
Well the Orkin man came back out yesterday, and lo and behold, he used the wrong spray the first time!  uglystupid2
Sprayed again, they're dropping like flies (no pun intended lol).
Bullgoose
Bastrop, Tx
« Reply #21 on: May 26, 2012, 10:16:56 PM »
Before I got into street bikes, I rode a lot of dirtbikes. We used to spray the whole front end (and some other places) with WD40. When we'd get home, the bikes would be covered with all matter of crude, but we'd just hose 'em down. Worked like a charm. Wink
Haven't been brave enough to try it on "the Goose", though. From the above posts, sounds like it might be worth a try. The bugs have been pretty bad, here in Tx., this year.
If it's worth doing, it's worth over-doing!
ricoman
Sarasota, FL
« Reply #22 on: May 27, 2012, 09:46:24 AM »
WD 40 is good to use on fire ant bites. Takes away the sting and eliminates the bites swelling into those nasty puss filled bumps.
sugerbear
wentzville mo
« Reply #23 on: May 27, 2012, 03:32:05 PM »
try lemon pledge.  cooldude cooldude
Tailgate Tommy
Fort Collins, Colorado
« Reply #24 on: May 27, 2012, 05:59:50 PM »
+1  Works well on Colorado bugs.
