March 26, 2026, 03:07:42 AM *
Author Topic: Valk won't start. Need help  (Read 1806 times)
SlowRoad
Hartselle AL
« on: May 24, 2012, 04:58:58 PM »
I need some help/advice.  I got on the Valk after work today to head home and when I turned the key on I got nothing.  I thought maybe I had left the switch on this morning when I got here, so I tried to jump start but still nothing. No lights, no neutral light, no gauge lights, no clicks, nothing.
I installed hazard flashers several years ago, and they are working but nothing else.
97 Standard. Was running fine when I got to work.  Anyone have any suggestions of what I should check out.  I would like to get home some time tonight.
Thanks in advance.
Tim
« Reply #1 on: May 24, 2012, 05:03:27 PM »
I would try functioning the kill switch and the starter button over and over and see if its a dirty switch.....both devices have caused a no start to me in the past.  after that I dont know what to tell you except to check all fuses and the starter relay (behind the right side cover)
SlowRoad
Hartselle AL
« Reply #2 on: May 24, 2012, 05:11:44 PM »
I tried flipping the kill switch several times and checked what fuses I could find.  Don't see anything obviously wrong.  Would the starter relay cause none of the instrument lights to work?
SlowRoad
Hartselle AL
« Reply #3 on: May 24, 2012, 05:36:11 PM »
More info,
It's not battery or starter.  I jumped across the starter soleniod and it turns over fine. Doesn't hit a lick though.  I am thinking maybe something in the ignition switch.  Any thoughts?
« Reply #4 on: May 24, 2012, 05:52:38 PM »
Unplug and cleanup the starter relay contacts.  Hoser
SlowRoad
Hartselle AL
« Reply #5 on: May 24, 2012, 05:54:28 PM »
I found it and am headed home.
Corroded connection on the starter solenoid plug. Cleaned it and we are back in business.
Thanks for the suggestions!!
SlowRoad
Hartselle AL
« Reply #6 on: May 24, 2012, 05:55:34 PM »
That was it. I found it while you were posting, but thanks anyway for responding.  Figured I could get an answer here!!
« Reply #7 on: May 25, 2012, 04:19:09 AM »
Only reason I suspected that, it happened to me on the road.  Glad it fixed it.  Hoser
« Reply #8 on: May 25, 2012, 05:16:29 PM »
Go back in and use some dielectric grease in there. You live in a humid place so protect it from corrosion.
timo
« Reply #9 on: May 26, 2012, 03:54:35 PM »
Are you talking about the 4 prong plug (mine uses 3 of the 4)?  If so, how do you clean the female part?
Timo
« Reply #10 on: May 26, 2012, 05:46:48 PM »
I used a small brass toothpaste sized wire brush and wd 40, used the sharp edge of my pocket knife to get home.  Hoser  cooldude
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #11 on: May 26, 2012, 05:58:30 PM »
Used a eraser to clean mine. then lubed it up with dielectric grease cooldude cooldude cooldude
timo
« Reply #12 on: May 26, 2012, 06:48:56 PM »
Thanks I will try those on mine.
