March 26, 2026, 03:13:24 AM *
Author Topic: Ticking noise - NOT pair vavle  (Read 1502 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: May 26, 2012, 07:06:33 PM »
I have a ticking noise but it is not the pair vavle because I did the complete desmog.  Sounds like when a spark wire is loose but they are tight.  Any thoughts?
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
sugerbear
wentzville mo
« Reply #1 on: May 26, 2012, 07:11:37 PM »
start looking for air leaks. start with the exhaust.
junior
new hampshire
« Reply #2 on: May 27, 2012, 01:49:17 AM »
it is more than likely your lifters our bikes have solid lifters instraed of hydrolic and will make a ticking noise
9Ball
« Reply #3 on: May 27, 2012, 04:35:16 AM »
search for air leaks....loose hose clamps on the intake runners, cracked vacuum lines or caps, and header nuts.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #4 on: May 27, 2012, 06:01:35 AM »
Where is the noise coming from ??  Trying to locate it would help.. Its generally a leaky exhaust gasket which can be a real PITA at times to keep from leaking.. That said,, sometimes these monsters will just tick,, its one of lifes little wonderments.. Glenn seems to think its the oil pump chain,, could very well be correct..
