March 26, 2026, 09:33:05 AM *
Pages: 1 [2]   Go Down
Author Topic: Disconnect emergency shut off  (Read 6304 times)
junior
new hampshire
« Reply #40 on: June 28, 2012, 03:31:00 PM »
i am glad to see that my mind aint alone in the gutter  2funny
really fudgie? lidless? with your background? in the med feild?  2funny
« Reply #41 on: June 29, 2012, 06:34:52 PM »
You only live once. I can live with a little itch and burning.  2funny
Brian
Monroe, NC
« Reply #42 on: June 29, 2012, 07:20:53 PM »
I walk along side my bike when I'm putting it up on the lift table and I use the engine to help it up the ramp.  Once the front wheel hits the chock, I use the switch to kill the engine while holding the front brake, then let out the clutch to keep it from rolling back.
+1. I do this same procedure putting the bike on the lift table. When I am sure the chock has the front wheel secure the key is turned off. The transmission is left in gear till the safety straps are secure with the jack stands under the engine guard.
« Reply #43 on: June 29, 2012, 08:03:29 PM »
Do Valkyries have a rev limiter. I didn't think that was the case.  My VTX does and will cause the bike to cutout at about 6K. I have wrapped my 97 Valk up and never had it cutout.    Roll Eyes
My rides:
tank_post142
south florida
« Reply #44 on: June 29, 2012, 08:52:57 PM »
cutout in mid 6000s
I got a rock Sad
VRCCDS0246
Mr.BubblesVRCCDS0008
« Reply #45 on: June 30, 2012, 06:52:13 AM »
I was thinking it was about 7200 rpm
« Reply #46 on: June 30, 2012, 07:01:57 AM »
In stock form, Valkyrie makes max horsepower 6000 to 6500 rpm.  limiter is set in that range. These three dyno runs, the limiter came on at 6500 rpm, where the torque  and horsepower lines end on the graph.  Hoser
« Last Edit: June 30, 2012, 08:09:54 AM by Hoser » Logged
Madmike
Campbell River BC, Canada
« Reply #47 on: June 30, 2012, 08:42:10 PM »
Whats a run away engine?
When the throttle gets stuck open and you can't can't control it.
Marty
an Instructor told me years ago that engines don't run away ..... they overspeeed and mechanics run away.
Madmike
« Reply #48 on: June 30, 2012, 08:43:58 PM »
A "runaway engine" is not likely with the rev-limiter on the Valkyrie.
Don't see the motor keep running since the tip-over switch will kill the motor.
A bunch of fallacious arguments!
................... would you guys quit engaging in this fellatio please..............
Madmike
« Reply #49 on: June 30, 2012, 08:45:25 PM »
We're not talking about the tip over switch.  We're talking about the switch that is to be used if you have a runaway engine.
if you've got a runway engine, just pull in the clutch....
......that'll slow her down.......
« Reply #50 on: July 01, 2012, 05:11:24 AM »
2funny
tank_post142
south florida
« Reply #51 on: July 01, 2012, 06:01:44 AM »
MadMike is still snowbound? and bored?  Cheesy
I got a rock Sad
VRCCDS0246
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #52 on: July 01, 2012, 06:02:06 AM »
X Ring
VRCC #27389, VRCCDS #204
« Reply #53 on: July 01, 2012, 06:44:57 AM »
LOL!
Marty
Madmike
« Reply #54 on: July 01, 2012, 07:53:28 AM »
yup.... all meaningful discussion had long since ended... and I'm not snowbound... I'm in siege from the bugs now..lol
« Reply #55 on: July 01, 2012, 12:45:16 PM »
I say again.
 OMG, it's the thread that won't die!   Cheesy  Grin  Hoser
« Reply #56 on: July 01, 2012, 12:59:09 PM »
We need a never ender in the tech board.  Cheesy
« Reply #57 on: July 01, 2012, 04:56:40 PM »
ok,maybe,it might be possable,it mighta coulda happen............i still dont see the safty issue with it. i bet most of you guys that have your painties in a buntch about the saftey factor of this kill switch, carry a condom in your wallet just incase that naked bigtitted bumb blonde emerges out of the woods while you have stopped for a piss break on the side of the road and she begs you to "take her take her now"
 2funny 2funny 2funny 2funny 2funny 2funny 2funny 2funny
Your eloquence with words is beyond description
« Reply #58 on: July 01, 2012, 08:50:14 PM »
Well, in that case, I'm proud to have started it!  Hoser  cooldude
junior
new hampshire
« Reply #59 on: July 02, 2012, 12:54:56 AM »
dont twll me you never thought of it..................lol
Rocketman
Seabrook, Texas
« Reply #60 on: July 02, 2012, 08:48:32 AM »
Back on the "meaningful" portion, I've bumped mine while reaching back up to disengage the throttle lock.  Cutting off the engine at freeway speeds, then switching her back on before touching the clutch equals one hell of a backfire.  I know this represents several errors on my part, but it still is an annoyance.  Perhaps I'll do the Chet's mod as well.
Mark
« Reply #61 on: July 03, 2012, 01:48:49 PM »
Just bringing it back to page 1.  Grin
Williamsburg, KY
« Reply #62 on: July 03, 2012, 01:52:44 PM »
Was gonna do it myself......Thanks.  2funny
« Reply #63 on: July 05, 2012, 02:23:57 PM »
So hoser, did ya do it?
« Reply #64 on: July 05, 2012, 06:16:17 PM »
No, found a new switch and housing cheep and replaced the whole thing, since the starter switch was busted and some times would not work, finally seized up and would not work at all.  After reading the instructions for the mod, I found it beyond my limited skills in electrical repair work.  Funny, cause I was an aircraft electrician  in the Navy 40 years ago, but mostly just replaced parts.  Shocked
Pages: 1 [2]   Go Up
