March 26, 2026, 02:34:13 PM
speedo cable
Topic: speedo cable (Read 1434 times)
speedo cable
August 10, 2012, 07:08:21 AM »
My speedo cable went out in Kansas the other day. I unscrewed it at the wheel and all was fine. Put it back together and noticed the cable itself pulls out of the mounting part. I shoved it back in and the speedo works. How hard is it to replace? Does it just unscrew at the gauge?
olddog1946
Moses Lake, Wa
Re: speedo cable
August 10, 2012, 07:19:43 AM »
Every speedo cable I have ever replaced just pulled out of the housing be it car or bike, though I haven't changed the one on the valk I would imagine it to be the same. Or if you want to change out the whole thing, just unscrew the housing at the speedo. So just the cable or the cable and housing, either way a simple job.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Moses Lake, Wa. 509-760-6382 if you need help
Re: speedo cable
August 10, 2012, 07:33:36 AM »
I would do the housing cause I can pull it in and out of the mount.
Mildew
Live, Not Just Exist
Auburn, Ga
Re: speedo cable
August 10, 2012, 08:44:14 AM »
Let us know. My Speedo cable broke years ago and haven't fooled with it yet
Farther
Quimper Peninsula, WA
Re: speedo cable
August 10, 2012, 09:10:05 AM »
I just changed out my speedo cable about a week ago. The cable both inner and outer cost was just a little more than shipping. Remove the screw from the hub holding the cable housing, then unscrew the cable from the speedometer housing. Reverse to install your new cable. I went with the new complete inner and outer because I was concerned about the condition of the lining and the cost was acceptable.
Last Edit: August 10, 2012, 09:12:47 AM by Farther
~Farther
art
Grants Pass,Or
Grants Pass,Or
Re: speedo cable
August 10, 2012, 12:16:25 PM »
i was out riding last night and heard a unusual sound from the speedometer and forgot about it until I seen your post about the speedo.Well I went out and pulled the cable from the wheel mounting and found it getting rusty.I cleaned it and greased it .All fixed ,10 minute fix.
Re: speedo cable
Reply #6 on:
August 10, 2012, 02:00:01 PM »
Don't get to aggressive with that little retainer screw..
