Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: August 12, 2012, 04:57:38 AM » |
Most run symmetrical C/T here correct? I found a nice looking C/T in my 205/60/16 C/T search although this tire is asymmetrical. Will asymmetrical work?
« Last Edit: August 12, 2012, 05:04:25 AM by Tundra »
Disco
Republic of Texas
« Reply #1 on: August 12, 2012, 05:29:02 AM » |
Yes, but after 32,627 miles on an asymmetrical Continental Vanco, I like my symmetrical Falken Ziex 512 much better.
2000 Bumblebee Tourer, 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K, 07 Helix 71 MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #2 on: August 12, 2012, 06:18:48 AM » |
Yes, I have searched hard for the Falken Ziex 512 in 60 series, just not available anymore.
Michvalk
« Reply #3 on: August 12, 2012, 06:37:08 AM » |
I have a asymmetrical tire on my I/S and it works good. Never had a symmetrical tire on yet, so I don't know the difference.
Thrud
2000 Valkyrie Interstate
« Reply #4 on: August 12, 2012, 10:47:31 AM » |
I'm getting ready to mount my very first CT, a Yokohama AVID ENViigor V-rated tire in 205/60/16 size. Very nice symmetrical tread pattern with rounded sidewalls.
Steve (Flat6)
CajunRider
« Reply #5 on: August 12, 2012, 03:22:16 PM » |
Steve (Flat6)
I have a Yokohama Avid H4S... the predecessor of the Avid Envigor. The tread doesn't last very long (20-25K miles)... but it handles and grips well, wet or dry.
Sent from my Apple IIe
Ken Tarver
« Reply #6 on: August 12, 2012, 07:52:23 PM » |
asymmetrical = the tread pattern is not the same all the way across the tread face, the outer portion of the tread has a different pattern than the inner portion, like on a corvette. And they most likely are directional also.
symmetrical = the pattern is the same all the way across the tread (inner and outer), if you stand over a symmetrical tire and look at the pattern then spin the tire 180 degrees the tread pattern will look exactly the same.
directional = like a goodyear assurance tripletread, or motorcycle tire, made to rotate in a certain direction.
I have the Goodyear on the Valkyrie, directional. Have a firestone symmetrical on the GW.
Ken
Ken Tarver
« Reply #7 on: August 12, 2012, 07:54:08 PM » |
Oh Tundra Most probably run a "directional"
Ken
Disco
Republic of Texas
« Reply #8 on: August 13, 2012, 03:38:11 AM » |
Interesting post, Ken, but here's what I mean by symmetrical v asymmetrical. In my mind, I draw a line (axis) down the center of the tire and look at each side. Mirror Image from axis = symmetrical / Not Mirror Image from axis = asymmetrical. Although all symmetrical tires would be directional, I don't believe all directional - with the arrows on the sidewall - tires would be symmetrical according that definition.
Ken Tarver
« Reply #9 on: August 13, 2012, 03:32:02 PM » |
Valkpilot
What does the data say?
Corinth, Texas
« Reply #10 on: August 13, 2012, 05:56:07 PM » |
Like Disco, I have always defined symetrical as one half of the tread as being a mirror image of the other. Apparently this definition has to include "directional" to be completely accurate. It's my opinion that a directional, symetrical tread, such as found on the GY ATT, the General Altimax, and the Falken Ziex 512 will work best in DS applications for our bikes. I think the popularity of these models is something of a testament to this. A symetrical tread that is not directional can have sipes on the shoulders and/or tread blocks across the face of the tread that point in opposite directions. I believe that this condition contributes to "wandering" of the back end as the sipes and tread blocks push side to side in opposite directions. I would expect that the more neutral the pattern, the less this is noticable, as on Disco's Continental Vanco.
« Last Edit: August 13, 2012, 06:04:31 PM by Valkpilot »
Ken Tarver
« Reply #11 on: August 13, 2012, 07:15:49 PM » |
 by definition in the tire world a directional tire isnt the same as a symmetrical you have the theory correct in your head of the differences as do I the technical definition of asymmetrical, symmetrical, & directional is different in the tire world though a directional tire can't be criss-cross rotated on a car unless remounted on the wheel it can only go front to back or vice versa a symmetrical tire can be criss cross rotated without being remounted i have a "non-directional" symmetrical tire on my gold wing, it doesn't "wander" i have a GY ATT on the valkyrie, it doesn't "wander" we are all correct in theory, i was just bouncing off the "technical definition" of each http://blog.tirevan.com/2011/10/24/tire-tread-patterns-%E2%80%93-symmetrical-asymmetrical-and-directional/no harm i hope, i'll have nothing else to say about it ken
Disco
Republic of Texas
« Reply #12 on: August 13, 2012, 07:51:20 PM » |
Here are the visual aids (until tirerack pulls the linked-to images) stacked in the same order as in Ken's post. Goodyear Assurance Triple Tred  Goodyear Eagle LS  Goodyear Eagle F1 Asymmetric 2
