March 26, 2026, 04:16:24 PM *
Author Topic: Front caliper rebuild  (Read 1592 times)
YoungPUP
Valparaiso, In
« on: August 12, 2012, 09:43:18 AM »
Well the left front on my valk isn't releasing, so I guess its time for a rebuild.  I though I saw a post somewhere about it, but search doesn't seem to like me.  IS there anything special to rebuilding these things?
99 STD (Under construction)
« Reply #1 on: August 12, 2012, 10:02:35 AM »
I was going to rebuild mine yesterday, but... we went to the Bourne Legacy matinee  Smiley ... I
liked it.
I always replace the seal when I do mine, it is probably not always needed, but they're cheap.
Nothing special that I know of...
« Reply #2 on: August 12, 2012, 02:27:53 PM »
When you get them-both of them apart look at the bores and the pistons. Both should be smooth as a babys butt. Scotch brite or something similar-NOT SANDPAPER OR EMERY CLOTH. You just want to clean the bores and pistons up-not change their dimesions. New O rings and crush washers. You might need acess to an air line to get the pistons out. Not that hard of a job but it is your brakes!!  cooldude RIDE SAFE.
« Reply #3 on: August 12, 2012, 07:52:45 PM »
I usually take the pads out and look around for something to stick in front of the pistons
so I can blow them out without them going into orbit, usually a bit of 1X flooring or whatever
is laying about... DUH...  Wink
sugerbear
wentzville mo
« Reply #4 on: August 13, 2012, 08:13:46 AM »
be sure to clean the slides inside and out. i use a little silicone spray to lube them.
lube the seals with brake fluid when you reassemble. Smiley
« Reply #5 on: August 13, 2012, 08:31:00 AM »
You mean the pins that the calipers float on?... There's goo (I don't know what makes it special)
at the auto parts store counter in little packets that I put on there...
« Reply #6 on: August 13, 2012, 05:33:04 PM »
That brake caliper lube (in thepic) is exactly what goes on the slider pins.
