March 26, 2026, 04:16:28 PM *
Author Topic: Rear fender bolt  (Read 1773 times)
csj
Peterborough Ontario Canada
« on: August 16, 2012, 09:59:32 AM »
I did the search, found 'some' info, but not enough. The rear part of the rear fender has One single bolt holding the two fender halves together.
http://www.ronayers.com/Fiche/TypeID/26/Type/REAR_FENDER_-_GRAB_RAIL/MakeID/1/Make/Honda/YearID/40/Year/1999/ModelID/6791/Model/GL1500CF/GroupID/289297/Group/REAR_FENDER_-_GRAB_RAIL
It's item #15 in the attached, also called 90085-MZ1-000, Bolt Special (6x17). Does that mean 6mm x 17mm?
I suppose I could just go the local dealer and order it.
But I'd still like to know. I lost the original somehow, can't find anything in the home supply to fit.
pacowboy78
Towanda, PA
« Reply #1 on: August 16, 2012, 10:58:04 AM »
I may have a spare.  I won't be home for a few days, but I just installed a hitchdoc, so had to replace the bolts as well.  If I can remember, I'll dig into my parts bin in the garage.  As long as it's there and you can wait a bit, I'll get it sent on out.
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #2 on: August 16, 2012, 11:11:03 AM »
PaC - the one he's talking about isn't replaced with the hitch - it's on top of the fenders, where they meet, and holds them together at the top.
csj - you should be able to go to any decent hardware store and pick up the bolt.  20mm probably won't be too long, but to be safe, I'd throw a washer in there to keep it from digging into the tire on full suspension compression.  6mm is the correct thread diameter, but the diagram doesn't give the thread pitch.  If you have the option, grab one of both pitches (fine and coarse).  Shouldn't be too expensive - even if you opt for stainless steel.
« Reply #3 on: August 16, 2012, 11:14:33 AM »
Thats the bolt that holds the passenger seat on........I bet its with the seat wherever you put that........that is what I wudda done
pacowboy78
Towanda, PA
« Reply #4 on: August 16, 2012, 11:27:55 AM »
Hell...that one. Yeah, helps to pull the diagram.  Agree with the other posters.  If nothing else, and if one is close, try Tractor Supply Co. in the specialty bins in the hardware department.  I've found all kinds of usefull/useless stuff in there.
valky1500
MI
« Reply #5 on: August 16, 2012, 11:44:52 AM »
With metric nuts and bolts there are only 2 different thread pitchs:
1. fine
and
2. course.
Easy enough to tell apart when you're buying them.
'98 Standard
'01 IS
Yes I pull a trailer
I have taken notice to those who use that word (Precautionary) and abide by it are not only very happy in life...
but they also live long and prosper.  Wink
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #6 on: August 16, 2012, 11:54:25 AM »
1. fine
and
2. course.
That it is, but there's no indication on that diagram, or others I've looked at, that say which one fits the nut permanently affixed to the fender of the bike.  Cheesy
shortleg
maryland
« Reply #7 on: August 16, 2012, 01:33:19 PM »
 I think you will find it to be 1.25 pitch .
  Shortleg[Dave]
BlueValk
Albuquerque, NM
« Reply #8 on: August 16, 2012, 03:22:56 PM »
Just checked mine.  It is an M6 x 1.0 pitch and 20mm long
BlueValk
csj
« Reply #9 on: August 16, 2012, 05:25:07 PM »
Thanks guys, found the item at two different bike shops locally. Yes it is 6mm x 17mm, one shop
charged me $0.84, and the other gave me a free bolt.
Everything is secure now. No more rattling fender.
Now it''s time to get some more light on the back of the bike.
