May 01, 2026, 02:07:07 PM *
Author Topic: Sprocket and chain question.  (Read 2380 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: June 23, 2009, 06:38:36 PM »
My VLX is near ready for a chain, so I'm shopping around.  I see front or rear sprockets offered with fewer teeth than OEM. I've always gone with OEM replacent.
What is the result of using a rear sprocket with few teeth?
quexpress
Montreal, Québec, Canada
« Reply #1 on: June 23, 2009, 06:47:32 PM »
Higher gearing ... in other words less grunt at low end in order to go faster at higher end. I'm not sure that this is desirable with a VLX.... but I don't have one ... therefore this is only an opinion.  Smiley
I still have a full deck.
I just shuffle slower ...
Warlock
Magnolia, Ms
« Reply #2 on: June 23, 2009, 07:13:53 PM »
A rule of Thumb. One tooth less on the front is like 3 less on the rear end or use 3 to 1 ratio. If you want more get up and go go one tooth on the front which will make more rpm's at cruising speed. One tooth less and better gas milage but less power.
David
fiddle mike
Corpus Christi, TX
« Reply #3 on: June 23, 2009, 07:46:02 PM »
I ride the VLX in town, on the freeway, rarely over 75 mph. Lower rpm would be desirable.
Thanks, to you and to David for the feedback.
« Reply #4 on: June 24, 2009, 03:21:48 AM »
Front sprocket,,Fewer teeth=more power, less speed.. More teeth=less power, higher speed..
Rear sprocket,, fewer teeth=less power, more speed.. more teeth=more power, less speed..
Warlock
Magnolia, Ms
« Reply #5 on: June 24, 2009, 06:03:19 AM »
Thanks Patrick, read my post again and realized the 3 to 1 was right just had my sprockets wrong. One less on front = 3 more on back more power, one more on front =3 less on back which means better gas milage but no get up and go.
David
