November 25, 2025, 12:41:38 AM *
Author Topic: If you're in need of OEM parts, this is the place to go. Check it out.  (Read 673 times)
« on: December 03, 2014, 06:26:30 PM »
This is the place to go; http://www.procaliber.com/
They're out of Vancouver, WA which might bother some due to the distance. However, everything they've shipped has been 2-day priority and since it was over $100, it was free.. The last part I needed left there Monday, delivered today. Like any of the dealers, they order from a warehouse source, but I found their prices well below others. Once it's "in house" it gets shipped quickly. Price example: new water pump for the 1200 through Partszilla, $122.xx, through Procaliber....$112.xx.  Check them out, compare prices, it will take all of the dealers about the same time to move it from the Honda warehouse to the dealer, but the shipping makes up for it....free if the order is over $99.
I just checked on front brake pads/per set for my Valk; Partzilla...$35.87, ProCaliber...$32.12. So, replace all pads and you're just below the $99, then toss in new piston seals for all three calipers and now you get free shipping. A u-joint: Partszilla...$130.82, ProCaliber...$120.86 w/free shipping. Just passing on my experience.  cooldude
« Reply #1 on: December 03, 2014, 07:06:02 PM »
Thanks John-now bookmarked!  cooldude RIDE SAFE.
mrider
« Reply #2 on: December 03, 2014, 08:18:26 PM »
yep thanks!
Rob A
Vancouver, WA
« Reply #3 on: December 03, 2014, 09:21:31 PM »
Hopefully you have better luck than I did. The couple of times I went in there and ordered parts when they came in they were wrong. After taking an ATV in there for servicing I would never have them work on my bike. I guess with their online ordering you are the one picking the part number so you will most likely get the right part.
1999 Interstate
« Reply #4 on: December 04, 2014, 10:43:30 AM »
I just ordered a few things from them, we'll see how it goes...
henry 008
BRP
willard, oh
« Reply #5 on: December 04, 2014, 11:57:54 AM »
thx john, I jus ordered wheel dampers, o'rings for the final drive etc. saved some money and got free shipping... like mike said, we'll see
Safe Winds... Brother
BobB
« Reply #6 on: December 04, 2014, 02:10:14 PM »
Thanks John, we always seem to have a list of parts to be replaced for these older bikes.  Right now, only about $15 worth, but I have yet to do the winter inspection.
Pepmyster
Go Bonzo, Go!!!!
Mascouche, Quebec, Canada
« Reply #7 on: December 04, 2014, 03:12:34 PM »
[/quote
When should we change the dampers?
Now this is getting interesting........
wiggydotcom
Yorkville, Illinois
« Reply #8 on: December 04, 2014, 04:07:23 PM »
[/quote
Probably couldn't necessarily go by mileage alone. I changed mine out when they had quite a bit of slop side to side. With your wheel off, stick your finger in them and see how much wiggle they have.
As long as you're ordering them, it wouldn't hurt to change em out if you have some "play".
VRCC #10177
VRCCDS #239
« Reply #9 on: December 31, 2014, 07:53:45 AM »
Just wanted to relate my experience with ProCaliber.com.
Ordered about $270.00 in parts on 12/7/14.
Almost complete order showed up on 12/24/14.
Some small spacers used on the coil were back ordered and they contacted me with the option of canceling for a refund or they will send later.
Pricing is lower than what I've experienced with other suppliers, but shipping (which was free) took longer.
All in all, good deal cooldude cooldude
Thanks John
