November 25, 2025, 09:13:38 AM *
Author Topic: FAIRING  (Read 708 times)
trout dude
Hammond Louisiana
« on: December 05, 2014, 08:28:19 AM »
Has anyone fixed a crack in the fairing . Please let me know. I know i can get it new but i think this one can be fixed. The pod got a crack in it also but if one can be fixed i think both can.
  Thanks Dennis
« Reply #1 on: December 05, 2014, 10:04:51 AM »
  Thanks Dennis
Did you have a crash Dennis ?
BonS
Blue Springs, MO
« Reply #2 on: December 05, 2014, 10:15:55 AM »
I've fixed cracks in saddlebags using ABS glue and the repair has held up without any further running of the cracks or recurrence. I drilled small holes at the end of the cracks to stop them from running, blue-taped the outside of the bags to keep the ABS glue from escaping, and then simply glopped (sp?) the ABS glue into and around the crack from the inside. I suppose you could also add some fiberglass mat or cut fibers into the glue for additional strength. The bags, pods and fairing are all ABS so the glue melts right into/onto the existing material for a solid repair.
I got the ABS glue at Lowes in the plumbing department.
« Last Edit: December 05, 2014, 10:57:33 AM by BonS » Logged
trout dude
Hammond Louisiana
« Reply #3 on: December 05, 2014, 10:34:09 AM »
Joe no I did not I was pushing  Shelia bike out for her to ride and it got away from me and fell on mine . Pretty stupid on my part but $#!t happens. Thanks for asking man se y'all soon.
  Dennis
« Reply #4 on: December 05, 2014, 10:53:59 AM »
  Dennis
Are you planning on hookin' up with us when we ride down to " The Gulf Coast Ride " the day after Christmas ?   This ride is a weather pending .
trout dude
Hammond Louisiana
« Reply #5 on: December 05, 2014, 11:48:23 AM »
Yes Joe Daryl and myself  can't wait.
   Dennis
« Reply #6 on: December 05, 2014, 01:16:39 PM »
   Dennis
Outstanding  cooldude
« Reply #7 on: December 05, 2014, 01:38:24 PM »
Black A B S hardening glue cause it can be sanded and used after words as a filler. When I repaired my saddle bag the cracks had tension on them. I cleaned the cracks out glued them up and used wood clamps to hold pressure on them and put pieces of flat stock A B S on the crack from the inside. The first one I did was nerve wracking as I waited the full 24 hours to release the clamp pressure. And it held!  cooldude cooldude cooldude Continued my repair waiting the full 24 hours each time so I was completely certain the glue had set up and cured.  coolsmiley Once you start sanding the imperfections make themselves known. DO NOT give up-remember-the Black A B S hardening can be used as a filler. Take your time and it should work out just fine. When you try to rush the repair is when it WILL bite you in the keester!  uglystupid2 RIDE SAFE.
t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« Reply #8 on: December 05, 2014, 04:17:17 PM »
  Dennis
Okay, I got you covered ..... all you had to do was change a few words around and we'd understand.  Wink Like this ...... "Shelia was pushing her bike out to ride and it got away from her and fell on mine"!  Cheesy
Glad it was not worse ....... like a serious crash.
How about posting a picture of the cracks so we can see what your up against.
Misfit
Colorado Springs Colorado
« Reply #9 on: December 05, 2014, 04:52:39 PM »
I use a sheet of ABS. Cut it into narrow strips to be used as a welding rod. Use a chisel point soldering iron and melt a v into the two adjoining pieces. Then go back and weld the pieces together using the rod as a filler. Sand smooth and paint.  cooldude
da prez
Wilmot Wi
« Reply #10 on: December 06, 2014, 02:28:25 PM »
  Use only black ABS (NOT multi-purpose ) glue. As O2S said , it can be used for filler as well as a bonding agent. ONLY black ABS specific glue will stick. Fiberglass will not stick to abs plastic. (fiber glass matting may help , but I have never used it) J B weld works but not as well. I have done many repairs and am now doing a severe road rash on a bag lid. I will take it right up to primer with the glue. I let it set up and then sand and fill as needed.
                                      da prez
Felonious Thump
Same hair line...
West Valley City, Utah
« Reply #11 on: December 06, 2014, 09:05:51 PM »
                                      da prez
Thanks. This might lead me to pick up some hard bags with some flaws, but a great price.
Of all the things I lost I miss my mind the most.
trout dude
Hammond Louisiana
« Reply #12 on: December 07, 2014, 07:08:06 AM »
Thanks to everyone who answered and to my little buddy who had Greg call and fill in some good info.
 Think i will get started this week and see how it goes also T-Man your insight was all wrong it was all me and my stupid decision not to move my bike that was under cover. It will be fixed but like Gordon told me it still rides good and runs good. Rode it yesterday to Hooters to meet my brother for lunch and ended up having lunch with Magoo,Lisa & Beekeeper  what a great time we had and good seeing them.
  Thanks Again Dennis
« Last Edit: December 07, 2014, 07:48:00 AM by trout dude » Logged
t-man403
Valk-a-maniac
« Reply #13 on: December 07, 2014, 03:15:42 PM »
Insight ........... that ain't insight..........just tryin' to cover you arse ........ but don't tell Shelia!  2funny
« Reply #14 on: December 07, 2014, 05:51:58 PM »
thanks,  good to know about the black ABS glue found in plumbing dept.  I have several items needing glueing and is that polypropeline/polyethanel (spelling?)  plastic material.  I have used JB weld thinking it could be used for plastic, and although it holds for awhile, never worked and cracked all over again.  Not a lot of glues out there able to bond solid plastic.
Hooter
S.W. Michigan
« Reply #15 on: December 08, 2014, 04:32:28 AM »
   J.B. Weld and some fiber glass cloth on the inside of the bag.
Jess Tolbirt
White Bluff, Tn.
« Reply #16 on: December 08, 2014, 06:03:05 AM »
at Lowes they sell ABS repair in the glue section,, its a 2 part epoxy type product..
