November 25, 2025, 07:22:00 AM *
Author Topic: It was there the last time I adjusted them  (Read 661 times)
Eagle 1
my 99 Valk
Salem, Oregon
« on: December 19, 2014, 12:35:02 PM »
Hello again: The last time I adjusted my rear shocks I had no problem since the little silver thingy with the adjusting numbers was in clear view. I decided to take a little stiffness out, got out my trusty adjusting wrench, and guess what? there were no adjusting numbers on either shock, and I have forgotten which way they adjust, for lighter ride. can anyone give me the directions?
Manny
big poppa pump
San Antonio, TX
« Reply #1 on: December 19, 2014, 12:55:11 PM »
Clockwise - increase preload, counter-clockwise - decrease preload. You need to turn the wrench counter-clockwise for a lighter ride.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
czuch
vail az
« Reply #2 on: December 19, 2014, 01:29:49 PM »
Anti clockwise. Acording to my Jaguar manual.
« Reply #3 on: December 19, 2014, 04:43:47 PM »
For OEM shocks the instructions say to always turn them clockwise.  To go lighter one would go to the top; turn once more to let it drop to the bottom; and then turn to the desired setting.  With that method you don't really need the label.  Just count the notches.
If they're not OEM disregard these comments.
SpidyJ
Murrells Inlet
« Reply #4 on: December 19, 2014, 04:49:37 PM »
Willow,
What do you mean go to the top?  Does the bike raise up as you stiffen the ride? I have never adjusted mine yet.
thx,
john
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #5 on: December 19, 2014, 04:54:09 PM »
Willow,
thx,
john
No, the bike will not raise up. He means go to the #5 setting. Past that it will thunk really hard and be back at #1. So going to the top means going to #5, another quarter turn and will thunk and reset to #1. Helps to take a little weight off the rear tire while doing this also.
SpidyJ
Murrells Inlet
« Reply #6 on: December 19, 2014, 05:00:21 PM »
Willow,
thx,
john
Thanks Gavin or Son of Gavin!
Peace,
johnnywebb
« Reply #7 on: December 19, 2014, 05:16:34 PM »
Thats actually my name. Sons is my last name Gavin is my first.  cooldude
wiggydotcom
Yorkville, Illinois
« Reply #8 on: December 19, 2014, 05:18:21 PM »
Hmmmm, I met and talked with you at Inzane and didn't even think to ask you about that. Learn sumtin new every day. Wink
VRCC #10177
VRCCDS #239
« Reply #9 on: December 19, 2014, 06:39:15 PM »
I remember talking with you too.
Mike in AR
Redfield, Arkansas 72132
« Reply #10 on: December 19, 2014, 09:01:01 PM »
Adding to Willow's post, I was told that you had to alternate as you went up. Go up one notch on the right side, then go up one notch on the left side,and continue until you reach the setting you want. Now, I don't know if this true or not, but it is how I was told to do it, and how I have been doing it for about 8 years now. Maybe someone with more knowledge can varify, or disprove this.
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
Jess Tolbirt
White Bluff, Tn.
« Reply #11 on: December 20, 2014, 06:35:11 AM »
as long as both sides are set the same it doesnt matter how you get there,
SpidyJ
Murrells Inlet
« Reply #12 on: December 20, 2014, 08:29:27 AM »
  Now I get it......we went to the liquor store together once......(fall ride).
Peace,
johnnywebb
« Reply #13 on: December 20, 2014, 02:35:32 PM »
Hmmm, I'll be darned. Its been 15 yrs since I've used the factory shocks. But, I thought I turned them in either direction to get the load I wanted. I thought you weren't supposed to go past 5. Learn something new everyday.
