October 04, 2025, 06:26:39 PM *
Author Topic: How I fixed my new Valkyrie...  (Read 18967 times)
« on: January 21, 2015, 02:39:33 PM »
Some folks here seem to like their new Valkyries fine, I hated mine. I knew it
was an awesome bike the minute I test rode it, but I found it almost impossible
to make it comfortable.
Here's what I did... I'm leaving out the many less radical things I tried that
didn't work.
The root of the problem is those lame handlebars and the dinky one inch
risers.
I fixed that with some Baron 4 inch pullback risers and Baron riser extensions. The extensions
moved the risers back an inch and raised them an inch and allowed me to vary the distance
between the risers to fit whatever handlebars I chose... I chose 1500 Valkyrie bars, of course  Wink ...
The tape was just to register the extenders while I was tightening the bolts.
The new Valkyrie's risers are rubber mounted, and there's a collar around
the stud as it exits the riser. Without this collar, there would be a void under
my new risers. There's a certain size of washer that is perfect, but the hole in
the washer needs drilled out...
So, now I've got some bars/risers with some promise, but none of the control
wires and hydraulic lines and throttle cables will reach.
I cut the control wires and soldered in nine inches more wire and used
this nice wire loom to cover it up...
I ordered longer hydraulic lines from Spiegler. A guy named Matthias helped me
order them over the phone. Later when I looked for youtube videos showing
installation of Spiegler hydraulic lines, there was Matthias showing an
installation and how to use this cool little tool they send along with their
lines that allows you to spin the banjo joints on the ends of the lines if
needed.
I ordered longer throttle cables from Motion Pro.
And I ordered a Memphis Shades Hellcat handlebar mounted windshield, the
OEM one no longer came anywhere near fitting.
You basically have to remove everything but the motor to get to the throttle bodies to
change the throttle cables...
The LED pod mounts to little tabs on the OEM risers, so I had to make a bracket
for that.
Too ugly to even finish...
This one was small enough to finish, but it held the LED pod at the wrong angle...
There's no such thing (well, I don't know where to get it) as 45 degree angle
iron (aluminum  Wink ), and I don't have any kind of brake to bend aluminum
flat stock, so I made what I needed from several layers of roofing tin... I
have hand brakes that can bend that. The black stuff is several layers of
PlastiCoat...
The bracket is held to the handlebars with a couple of Formotion clock mounts...
The valkyrie is covered with plastic, much of it held on with reusable nylon "push pin"
rivets... I only broke one push pin, on one of the shrouds on the front of the motor
where the clutch bleeder hides. Honda wants three or four dollars each for the push
pins, I got a box of 60 from Amazon for $19.99...
Anywho... executing this whole thing has taken me months, but it has been worth
it. I got the bike back together Monday night, and after a few windshield adjustments
it was feeling pretty good. I rode it about 100 miles today, and felt something was
still lacking. As I rode I tried to figure out what needed changing, and decided the angle
of the backrest (oh yeah, I have a Corbin seat) need to come forward just a bit. I
made the change and went another 20 miles, and it was almost perfect.  cooldude
If tiny adjustments are making great improvements, I must be almost there...
Here's the bike pretty much as it is now (finger prints and all, I haven't washed it since
tearing it all apart)...
As small as it is, the windshield is nice, and can be adjusted a bunch of different ways. I
don't like to look through windshields, this one is plenty tall enough... it could be wider.
I'll probably keep fine tuning its adjustment, and maybe rotate the bars a little, but
my ride today, especially after I rotated the backrest forward a little, was great.
« Last Edit: February 16, 2025, 09:26:23 AM by hubcapsc » Logged
jimmytee
Elizabethtown,KY
« Reply #1 on: January 21, 2015, 03:01:32 PM »
 cooldude Good work. Glad you were able to finally get some satisfactory results. Do you have a link to the Amazon site with those push pins. I went through upgrading the stereo system on my F6B and lost one. I bought a couple from the dealer and you're right  it was like $3.50 a piece. Definitely would like to get a deal on those to have on hand for any future work.
« Reply #2 on: January 21, 2015, 03:33:02 PM »
Mike, I am thinking when you retire you could go into business doing this mod for others.  Say parts for cost and shipping, and about $3000 in labor.  (if that's enough)
I think Honda ought to be shown what a real headache it is to make their bike handlebars comfortably ergonomic for the average cruiser rider.  Honda may have aimed the new F6C at the crotch rocket crowd, but that would be a mistake, and I believe the lion's share of new owners would be wing/cruiser people.
To my knowledge, nearly all 1500 Valk riders (long, tall, short or fat) add longer/taller risers to their bikes to make them cruiser friendly, and except for throttle cable rerouting for 5.5" risers, they are otherwise straight bolt ups, and a half hour, one-beer project.  The same is true for any number of Hog and Metric cruisers.
Seat, bag, shield, and hwy peg issues may be solved by simply throwing money at them and some straightforward bolt-up, but obviously not this project.
Way to stick with it.   cooldude cooldude
The Navy Seabees have nothing on you..... The difficult, we do right away, the impossible takes a little longer.
(Perhaps one picture to add to the collection would be those parts that will not go back on)
« Last Edit: January 21, 2015, 03:44:57 PM by Jess from VA » Logged
« Reply #3 on: January 21, 2015, 03:52:04 PM »
I got these:   http://www.amazon.com/gp/product/B00GXJIWRA/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
You might want to wait a few days and find out if I made a good choice...
« Reply #4 on: January 21, 2015, 03:56:19 PM »
handlebars, risers, windshield and brackets. I'd put a Utopia backrest on the OEM seat, it
was a good backrest and the OEM seat might be OK with it and these handlebars, so maybe
it shouldn't be in the picture...
EDIT: oh yeah, and a pile of cables and hydraulic lines.
« Last Edit: January 22, 2015, 04:56:47 AM by hubcapsc » Logged
Chadleys1
Texas Hillcountry
« Reply #5 on: January 21, 2015, 06:34:46 PM »
I would like to request, please, that you might post a beauty pic showing the whole bike, when you can, including the new mods of course.  Thanks for posting.
« Reply #6 on: January 21, 2015, 07:06:04 PM »
I lost the picture for this post. Here's one from 2024...
« Last Edit: February 16, 2025, 09:58:33 AM by hubcapsc » Logged
« Reply #7 on: January 22, 2015, 04:35:03 PM »
They arrived today. I made a good choice. Among the mix are some just like the one I
broke, I put it in right away.
jimmytee
Elizabethtown,KY
« Reply #8 on: January 22, 2015, 06:53:53 PM »
« Reply #9 on: January 24, 2015, 01:23:32 PM »
To keep from hijacking a post about useful motorcycle knowledge gleaned from
the instructables.com web site over on the 1500 tech board, I'll drag this part of
the thread back here...
If you had a design, Clearview might make one for you too.
I want a Hellcat, but X wider, Y taller.  Maybe a paper pattern.
Also, as you mount it low over the front parts (like a partial fairing), it seems that a gradient tint black on the low part (like Memphis shades) would partially hide some of the parts you would like to hide (per your earlier posts).
Just got back from a comfortable windy ride... studied the shield some more, trying to
think of what would make it just right....
The hateful OEM windshield is just the right size and is only hateful because of the
straight up-and-down way Honda mounted it. It has a nice chrome bracket on it.
I held it up in front of the Hellcat, if it could somehow be mounted at fork-angle,
it would be just the right amount wider and taller. But there's no way the Hellcat's
mounts would work with it. Two sets of Hellcat mounts probably would, though. If
the rods were a little longer.
I measured the rods... .38 inches... that's 3/8 inch...
I just ordered a replacement set of Hellcat hardware and 72 inches of
3/8 inch stainless steel rod... if it works, it will still be handlebar mounted,
but the hardware and shield bracket will all be "factory made"... Hellcat
hardware is pretty nice I think, and almost infinitely adjustable...
« Last Edit: February 16, 2025, 09:30:59 AM by hubcapsc » Logged
Detn8er
« Reply #10 on: January 24, 2015, 02:45:56 PM »
Lookin' good......Now you need to put a car tar on there. You know just to piss certain people off.  Wink The handle bars look to be a good fit.
woofred1832
My Valkyrie
northern Ill near fox lake
« Reply #11 on: January 28, 2015, 10:42:12 AM »
Hi Mike
                    From woofred1832  The oem handlebars dont bother me.
                    I have a 2014 valkyrie that I had the honda bags put on,and hyw pegs, I used the honda wire harness but mounted other led driving lites, and adapted after market windshield to the bulavard brakets I would like to post pictures. How do I do that?  ALSO would like to find after market sissy bar, some thing les than the $275 honda wants for thiers
« Reply #12 on: January 28, 2015, 02:46:47 PM »
Hi Mike
You have to put your pictures on the Internet somewhere, then type the URL here, like
this:
http://sites.google.com/site/hubcapsite3/howifixed/perfect.jpg
If you get that far we can see your pictures by clicking on the URL... there's one more
step to learn to display the image instead of the URL...
I wondered about using the inexpensive, but plug-and-play, Honda wiring harness, and some other
LED lights in the cowl... is that what you did? I can't wait to see your pictures, and find out more
details about the LED lights you chose...
« Last Edit: June 30, 2017, 06:38:38 AM by hubcapsc » Logged
Bagger
VRCC #102
CT-USA
« Reply #13 on: January 31, 2015, 03:44:25 PM »
Hey, Hub ...
I modified the rake of the windscreen several months ago, too.  If you do a search you'll see how I did it and some photos of how it looks.
It's in the same/same plane as the front forks.  I look over the windscreen, there is air coming from under the front of the screen to my chest area, less buffeting than oem, more hand/arm air, too.  Cost was Zero !
Check it out.
Nice work on your New Valk, Hub.
« Reply #14 on: February 01, 2015, 04:27:31 PM »
Hey, Hub ...
Check it out.
I saw that... with my handlebars, I had to ditch all the OEM mounting hardware... I got mine
mounted today... I'm looking through it, so I'll probably not be happy till I cut it down a little,
but a bit at a time... I got started on mounting the Givi trunk today, and I have to hook up
my heated gear plug in...
« Last Edit: February 16, 2025, 09:33:20 AM by hubcapsc » Logged
woofred1832
My Valkyrie
« Reply #15 on: February 17, 2015, 08:50:18 AM »
                         Mike    I got my led lites fron a china co  DHgate.com took a while to find them but they do have them I also got 2 led lite strips just havent figured out where to put them or how and where to wire them in       Still cant figure out how to post pics yet....since I am computer dumb I need step by step instructions     thanks
rainman
Steve ( rainman) Eads
Bloomington Indiana
« Reply #16 on: February 17, 2015, 09:04:02 AM »
Hey, Hub ...
Check it out.
looking good Mike cooldude  now if you could do something with those ugly looking rat pods
« Reply #17 on: February 17, 2015, 10:05:45 AM »
I'm not crazy about the look either (esp being open in the front), but whenever I see a picture of the bike, they always remind of a big shoulder muscle-builder.  It is a muscle bike.
« Reply #18 on: February 17, 2015, 11:25:57 PM »
It will always be a stripped down Goldwing. Changing the radiators is
beyond me. I ordered the Corbin bags the other day. Now that the
bike is comfortable I find myself daydreaming about riding it...
-Mike "instead of daydreaming about burning it  Smiley "
Pete
« Reply #19 on: February 18, 2015, 06:43:59 AM »
Aluminum Angle - Ace Hardware in 8 ft length - great stuff for making brackets
Bronxboy
Tampa Bay FL
« Reply #20 on: April 12, 2015, 05:15:45 AM »
I'm thinking more like this
« Reply #21 on: April 13, 2015, 08:10:53 AM »
A couple of people have looked at this thread recently, interested
in seeing the details of how I tried to make my Valkyrie comfortable...
A couple of details I might not have emphasized enough... multiple
windshield readjustments and fiddlings... the windshield is in pretty
good shape now, I'm real happy with it.
I made all the control cables and wires and lines nine inches longer.
I probably could have gotten away with seven inches, but if you make
them too short, you're up the creek. I perceive no problems with
nine inches...
« Last Edit: February 16, 2025, 09:34:36 AM by hubcapsc » Logged
« Reply #22 on: April 13, 2015, 07:09:45 PM »
Mike that is the best looking new Valk I have seen cooldude
« Reply #23 on: April 14, 2015, 04:35:49 AM »
Thanks!
-Mike "The ergonomics of a Valkyrie on a stripped-down Goldwing..."
BIG--T
The Twilight Zone
« Reply #24 on: April 14, 2015, 08:41:03 AM »
Mike I agree with Bighead on that...she is sharp and the best looking new Valk I've seen!!! I haven't been on here in a while and read about all the improvements you made and all I gotta say- It was worth it!  Congrats!!  cooldude
bscrive
Ottawa, Ontario
« Reply #25 on: April 14, 2015, 09:14:21 AM »
When my new valk grows up, I want it to look just like hubcapsc's.  With a few minor changes.  Also, I have to save up for those corbin bags and seat..
BIG--T
The Twilight Zone
« Reply #26 on: April 14, 2015, 10:39:56 AM »
All the hours and money paid off. I think the hard bags and seats make it.
« Reply #27 on: April 14, 2015, 11:00:51 AM »
The bags and the seat were easy (except for the $)... the bars
and the shield make the bike, the seat and the bags would be
a waste for me without them...
BIG--T
The Twilight Zone
« Reply #28 on: April 14, 2015, 12:09:53 PM »
Yes the bars and shield was a must for comfort, but the bags and seat makes it look better  imo.
spud
London Ontario
« Reply #29 on: July 14, 2015, 04:22:15 AM »
Thanks for the link to your mods hubcapsc. I just got my 1800 last week
and am catching up with 1800 Tech Board. I'll bookmark this for later
when I know what I need for the new Valkyrie. Had a 2001 Interstate
that never let me down. Hoping the same for the 1800.
Also interested in the fog lights that were posted. Dual fog and signal. Neat.
Hoping to find something like that for the back for more visibility from
cagers.
woofred1832
My Valkyrie
« Reply #30 on: July 14, 2015, 07:41:20 AM »
                                 OH you will love the 1800  I had a 98 1500 c and when honda brought the valkyrie back I knew I had to have one     Got mine last oct. and not even a year old and I have 9000 miles on it ...Thats not bad since I live in northern Ill close to Wis border... leaving to go to door county tomarrow... any way this is a great site ENJOY.......................
bradrcfii
« Reply #31 on: September 13, 2015, 05:37:21 AM »
didn't work.
risers.
Wow, a lot of work but I get it.  I probably not as tall as you. I want my bars to come back at least one inch.  Height is OK.  Do you see a solution for this?
Brad
« Reply #32 on: September 13, 2015, 06:08:31 AM »
You'll probably have to change the risers to something like I have.
If you don't, whatever different bars you choose will probably not clear
the key at some point as you turn the bars from lock to lock. Another 1800
rider (bscrive) made his own radical handlebars that cleared the key without
changing risers.
I'm just 5-11... If I ever find a set of bars that are pretty much like 1500 Valkyrie bars
but that have an extra inch of pullback, I might give them a try... I extended all the
cables and lines and wires 9 inches, and I have a little left to work with. The way it is
now, though, is extremely acceptable... OEM bars, both 1500 and 1800, have the little
knobs on them that hold the OEM style tie wraps, and they have little holes in them
in the right places to register the tabs on the control boxes, I like that pretty much and
wouldn't want to have to work around their absence... the little holes on the 1500
bars were almost in the wrong place, but I have my control boxes and their associated
lever perches placed pretty comfortably.
« Reply #33 on: September 14, 2018, 08:17:49 AM »
September 2018...
Mods: Russell seat, big handlebars, Traxxion forks and shocks and steering head bearings, Corbin bags, Utopia backrest...
I got a two-inch-shorter (seven inches longer than OEM) set of throttle cables made and installed them, nine inches
was too long for the throttle cables...
I have two sizes of GIVI top cases, they're only on the bike for trips...
I still imagine the handlebars being a little different... I never measured my Valkyrie
handlebars while they were off, I found these measurements on the web:
diameter:1"  height:6"  width:33" pullback:14"  center:9"  clamp-area:3" x 5"  part-number:53100-MZ0-000
While riding I paid attention to the slightly different place and angle I wished
my hands were at, and using the above measurements I think I might try these
32″ width, 5″ rise, 15-1/2″ pullback Yamaha handlebars: Baron Custom Accessories  BA-7308-00
I'm not sure what makes them "Yamaha", but they're one inch bars...
« Last Edit: February 16, 2025, 09:36:07 AM by hubcapsc » Logged
mikefromohio
« Reply #34 on: September 14, 2018, 05:04:18 PM »
I am in the market for highway pegs and wondered which ones you bought? You are very discerning and I would appreciate knowing what you decided on.
« Reply #35 on: September 14, 2018, 06:04:08 PM »
Heaven help us... I started with these:
https://www.amazon.com/dp/B00CQ7W0Q2/ref=psdc_404667011_t3_B000XY6XMM
Then I tried the medium length arms, then (now) the long arms...
http://wingstuff.com/products/3443-short-4-5-or-6-inch-arms-for-ergo-pegs
bscrive
Ottawa, Ontario
« Reply #36 on: September 15, 2018, 04:49:51 AM »
September 2018...
Mike,
If I had known that you were looking for another set of bars, I would have given you my 1-1/4" set that I made for my bike.  I decided to make a set of 1-1/2" bars because I like the larger size.  I ended up giving them to a guy on the F6C site.
I still have my original 1" bars that I made.  I found them a little too small diameter because of the length, but you may find them fine.  You can have them for the cost of shipping.  The last set of bars cost $80USD to ship to Ohio.  I just would need to find another large box to ship them.
Brian
« Reply #37 on: September 15, 2018, 05:11:46 AM »
Thanks for the offer Brian... I need to try lowering the
handlebars I have a little and maybe also adjust my
backrest to scoot me a tiny bit forward, that might do
what I want... I'm just thinking out loud about different handlebars
for now... I was even looking at the helibar web $ite, they have
a 1 inch cruiser/bagger bar. The way you can turn the handgrip
part of helibars out at arbitrary angles seems pretty useful...
People still look at this thread occasionally, so I wanted to add
the updated picture to show that the handlebar change has worked
for me in the long run...
bscrive
Ottawa, Ontario
« Reply #38 on: September 15, 2018, 06:39:41 AM »
No problem Mike if you ever decide that you want them just give me a p.m..
I hope you are doing fine with that hurricane where you are in South Carolina. It's a pretty nasty storm with the rain coming down in buckets.
« Reply #39 on: February 16, 2025, 09:55:23 AM »
2025
I guess people might still look at this thread, it's been looked at 11,000 times.
I just noticed all the pictures were dead due to yet another out-of-my-control
innernet reorganization. I pointed all the image links in the thread I could back
to hubcapsc.com, the images will stay there until the lights go out there.
I still have both Valkyries. Never any trouble with the modifications to the 1800.
Been all over  cooldude ...
