November 24, 2025, 02:51:28 PM *
Author Topic: Fiddle me this.......  (Read 862 times)
« on: February 08, 2015, 05:55:06 PM »
http://www.telegraph.co.uk/news/earth/environment/globalwarming/11395516/The-fiddling-with-temperature-data-is-the-biggest-science-scandal-ever.html
Following my last article, Homewood checked a swathe of other South American weather stations around the original three. In each case he found the same suspicious one-way “adjustments”. First these were made by the US government’s Global Historical Climate Network (GHCN). They were then amplified by two of the main official surface records, the Goddard Institute for Space Studies (Giss) and the National Climate Data Center (NCDC), which use the warming trends to estimate temperatures across the vast regions of the Earth where no measurements are taken. Yet these are the very records on which scientists and politicians rely for their belief in “global warming”.
 Homewood has now turned his attention to the weather stations across much of the Arctic, between Canada (51 degrees W) and the heart of Siberia (87 degrees E). Again, in nearly every case, the same one-way adjustments have been made, to show warming up to 1 degree C or more higher than was indicated by the data that was actually recorded. This has surprised no one more than Traust Jonsson, who was long in charge of climate research for the Iceland met office (and with whom Homewood has been in touch). Jonsson was amazed to see how the new version completely “disappears” Iceland’s “sea ice years” around 1970, when a period of extreme cooling almost devastated his country’s economy.
One of the first examples of these “adjustments” was exposed in 2007 by the statistician Steve McIntyre, when he discovered a paper published in 1987 by James Hansen, the scientist (later turned fanatical climate activist) who for many years ran Giss. Hansen’s original graph showed temperatures in the Arctic as having been much higher around 1940 than at any time since. But as Homewood reveals in his blog post, “Temperature adjustments transform Arctic history”, Giss has turned this upside down. Arctic temperatures from that time have been lowered so much that that they are now dwarfed by those of the past 20 years.
 Homewood’s interest in the Arctic is partly because the “vanishing” of its polar ice (and the polar bears) has become such a poster-child for those trying to persuade us that we are threatened by runaway warming. But he chose that particular stretch of the Arctic because it is where ice is affected by warmer water brought in by cyclical shifts in a major Atlantic current – this last peaked at just the time 75 years ago when Arctic ice retreated even further than it has done recently. The ice-melt is not caused by rising global temperatures at all.
Of much more serious significance, however, is the way this wholesale manipulation of the official temperature record – for reasons GHCN and Giss have never plausibly explained – has become the real elephant in the room of the greatest and most costly scare the world has known. This really does begin to look like one of the greatest scientific scandals of all time.
 When future generations look back on the global-warming scare of the past 30 years, nothing will shock them more than the extent to which the official temperature records – on which the entire panic ultimately rested – were systematically “adjusted” to show the Earth as having warmed much more than the actual data justified.
Two weeks ago, under the headline “How we are being tricked by flawed data on global warming”, I wrote about Paul Homewood, who, on his Notalotofpeopleknowthat blog, had checked the published temperature graphs for three weather stations in Paraguay against the temperatures that had originally been recorded. In each instance, the actual trend of 60 years of data had been dramatically reversed, so that a cooling trend was changed to one that showed a marked warming.
This was only the latest of many examples of a practice long recognised by expert observers around the world – one that raises an ever larger question mark over the entire official surface-temperature record.
« Reply #1 on: February 08, 2015, 07:12:35 PM »
http://www.ncdc.noaa.gov/monitoring-references/faq/temperature-monitoring.php
« Reply #2 on: February 09, 2015, 07:40:37 AM »
 It’s a fact that if you just take all the thousands of fairly evenly-spaced “official” weather stations around the country and average them up since 1895, that you won’t get much of a warming trend at all.   Consequently a major and ongoing federal effort has been to try and cram these numbers into the box imposed by the theory that gives the government the most power—i.e., strong global warming.’
http://www.climatedepot.com/2013/01/10/meteorologist-anthony-watts-on-adjusted-us-temperature-data-in-the-business-and-trading-world-people-go-to-jail-for-such-manipulations-of-data/
Rewriting Their Own Temperature Past At The National Academy Of Sciences: ‘Massively altered temp history since their 1975 report. They have eliminated most of the 1940-1970 cooling’ - ‘If they didn’t tamper with the data, there is no global warming since 1940.’ - In 1978, NOAA reported 0.5C global cooling from 1960-1965. NAS has almost completely erased that.’
NASA’s James Hansen in 1999 before feds tampered with temp data: ‘In U.S. there has been little temperature change in past 50 years…in fact, there was a slight cooling throughout much of country’
U.S. ‘Hottest Year’ ever?! ‘The past has been massively cooled, and the present has been massively warmed. A cooling trend has been turned into a warming trend, by adjusting the data’ - ‘NOAA makes bold press releases based on hugely altered data, and makes no mention that the data is altered. Then when called out, they claim that the adjustments are small, when in fact the adjustments are larger than the trend. The 1930s used to be by far the hottest decade, before the data was adjusted’
czuch
vail az
« Reply #3 on: February 09, 2015, 08:14:13 AM »
Ya mean the government lied???????
How could you not trust Algore??
 He wouldnt even debate the issue, he was so firm in his CONviction.
0leman
Klamath Falls, Or
« Reply #4 on: February 09, 2015, 08:40:52 AM »
CA, if you check out what they said about 2014 as the hottest year, you will find that there is a +/- error bigger than the supposed high temp.   Basically, It could have hotter than any recent year or it could have not been.  They were only 38% sure that the temp was right.  You have to read down into what was originally posted.  Lots of media hype.
The earth has been warming slowly since the last mini-ice age, naturally without man's influence.   It may continue to warm or we may see a cooling trend.  It seems to do it in jumps.   The UN climate folks were charge in finding CO2 as a scapegoat for global warming (to help in wealth distribution) and have written programs to show that it does.  Of courses the programs haven't been able to reproduce the climate since they were written (fault checking is what one does when one writes programs).  If they don't give you the correct results you check you programming.  Their answer  to bad results, is to try to change the data.
« Reply #5 on: February 09, 2015, 08:44:26 AM »
Some information I've kept
From 2008
Forget global warming: Welcome to the new Ice Age
Lorne Gunter, National Post Published: Monday, February 25, 2008
Snow cover over North America and much of Siberia, Mongolia and China is greater than at any time since 1966.
The U.S. National Climatic Data Center (NCDC) reported that many American cities and towns suffered record cold temperatures in January and early February. According to the NCDC, the average temperature in January "was -0.3 F cooler than the 1901-2000 (20th century) average."
China is surviving its most brutal winter in a century. Temperatures in the normally balmy south were so low for so long that some middle-sized cities went days and even weeks without electricity because once power lines had toppled it was too cold or too icy to repair them.
There have been so many snow and ice storms in Ontario and Quebec in the past two months that the real estate market has felt the pinch as home buyers have stayed home rather than venturing out looking for new houses.
In just the first two weeks of February, Toronto received 70 cm of snow, smashing the record of 66.6 cm for the entire month set back in the pre-SUV, pre-Kyoto, pre-carbon footprint days of 1950.
And remember the Arctic Sea ice? The ice we were told so hysterically last fall had melted to its "lowest levels on record? Never mind that those records only date back as far as 1972 and that there is anthropological and geological evidence of much greater melts in the past.
The ice is back.
Gilles Langis, a senior forecaster with the Canadian Ice Service in Ottawa, says the Arctic winter has been so severe the ice has not only recovered, it is actually 10 to 20 cm thicker in many places than at this time last year.
OK, so one winter does not a climate make. It would be premature to claim an Ice Age is looming just because we have had one of our most brutal winters in decades.
But if environmentalists and environment reporters can run around shrieking about the manmade destruction of the natural order every time a robin shows up on Georgian Bay two weeks early, then it is at least fair game to use this winter's weather stories to wonder whether the alarmist are being a tad premature.
And it's not just anecdotal evidence that is piling up against the climate-change dogma.
According to Robert Toggweiler of the Geophysical Fluid Dynamics Laboratory at Princeton University and Joellen Russell, assistant professor of biogeochemical dynamics at the University of Arizona -- two prominent climate modellers -- the computer models that show polar ice-melt cooling the oceans, stopping the circulation of warm equatorial water to northern latitudes and triggering another Ice Age (a la the movie The Day After Tomorrow) are all wrong.
"We missed what was right in front of our eyes," says Prof. Russell. It's not ice melt but rather wind circulation that drives ocean currents northward from the tropics. Climate models until now have not properly accounted for the wind's effects on ocean circulation, so researchers have compensated by over-emphasizing the role of manmade warming on polar ice melt.
But when Profs. Toggweiler and Russell rejigged their model to include the 40-year cycle of winds away from the equator (then back towards it again), the role of ocean currents bringing warm southern waters to the north was obvious in the current Arctic warming.
Last month, Oleg Sorokhtin, a fellow of the Russian Academy of Natural Sciences, shrugged off manmade climate change as "a drop in the bucket." Showing that solar activity has entered an inactive phase, Prof. Sorokhtin advised people to "stock up on fur coats."
He is not alone. Kenneth Tapping of our own National Research Council, who oversees a giant radio telescope focused on the sun, is convinced we are in for a long period of severely cold weather if sunspot activity does not pick up soon.
The last time the sun was this inactive, Earth suffered the Little Ice Age that lasted about five centuries and ended in 1850. Crops failed through killer frosts and drought. Famine, plague and war were widespread. Harbours froze, so did rivers, and trade ceased.
It's way too early to claim the same is about to happen again, but then it's way too early for the hysteria of the global warmers, too.
lgunter@shaw.ca
« Last Edit: February 09, 2015, 08:47:55 AM by Britman » Logged
« Reply #6 on: February 09, 2015, 08:46:01 AM »
From 2006
Majority Press Release
Contact:  MARC MORANO (202) 224-5762 (marc_morano@epw.senate.gov), MATT DEMPSEY (202) 224-9797 (matthew_dempsey@epw.senate.gov)
Renowned Scientist Defects From Belief in Global Warming – Caps Year of Vindication for Skeptics
October 17, 2006
Washington DC - One of the most decorated French geophysicists has converted from a believer in manmade catastrophic global warming to a climate skeptic. This latest defector from the global warming camp caps a year in which numerous scientific studies have bolstered the claims of climate skeptics. Scientific studies that debunk the dire predictions of human-caused global warming have continued to accumulate and many believe the new science is shattering the media-promoted scientific “consensus” on climate alarmism.
Claude Allegre, a former government official and an active member of France’s Socialist Party, wrote an editorial on September 21, 2006 in the French newspaper L'Express titled “The Snows of Kilimanjaro” (For English Translation, click here: http://epw.senate.gov/fact.cfm?party=rep&id=264835 ) detailing his newfound skepticism about manmade global warming. See: http://www.lexpress.fr/idees/tribunes/dossier/allegre/dossier.asp?ida=451670 Allegre wrote that the “cause of climate change remains unknown” and pointed out that Kilimanjaro is not losing snow due to global warming, but to local land use and precipitation changes. Allegre also pointed out that studies show that Antarctic snowfall rate has been stable over the past 30 years and the continent is actually gaining ice.
“Following the month of August experienced by the northern half of France, the prophets of doom of global warming will have a lot on their plate in order to make our fellow countrymen swallow their certitudes,” Allegre wrote. He also accused proponents of manmade catastrophic global warming of being motivated by money, noting that “the ecology of helpless protesting has become a very lucrative business for some people!”
Allegre, a member of both the French and U.S. Academy of Sciences, had previously expressed concern about manmade global warming. "By burning fossil fuels, man enhanced the concentration of carbon dioxide in the atmosphere which has raised the global mean temperature by half a degree in the last century," Allegre wrote 20 years ago. In addition, Allegre was one of 1500 scientists who signed a November 18, 1992 letter titled “World Scientists' Warning to Humanity” in which the scientists warned that global warming’s “potential risks are very great.” See: http://homepages.ihug.co.nz/~sai/sciwarn.html
Allegre has authored more than 100 scientific articles, written 11 books and received numerous scientific awards including the Goldschmidt Medal from the Geochemical Society of the United States.
Allegre's conversion to a climate skeptic comes at a time when global warming alarmists have insisted that there is a “consensus” about manmade global warming. Proponents of global warming have ratcheted up the level of rhetoric on climate skeptics recently. An environmental magazine in September called for Nuremberg-style trials for global warming skeptics and CBS News “60 Minutes” correspondent Scott Pelley compared skeptics to “Holocaust deniers.” See: http://www.epw.senate.gov/fact.cfm?party=rep&id=264568 & http://www.cbsnews.com/blogs/2006/03/22/publiceye/entry1431768.shtml In addition, former Vice President Al Gore has repeatedly referred to skeptics as "global warming deniers."
This increase in rhetorical flourish comes at a time when new climate science research continues to unravel the global warming alarmists’ computer model predictions of future climatic doom and vindicate skeptics.
60 Scientists Debunk Global Warming Fears
Earlier this year, a group of prominent scientists came forward to question the so-called “consensus” that the Earth faces a “climate emergency.” On April 6, 2006, 60 scientists wrote a letter to the Canadian Prime Minister asserting that the science is deteriorating from underneath global warming alarmists.
“Observational evidence does not support today's computer climate models, so there is little reason to trust model predictions of the future…Significant [scientific] advances have been made since the [Kyoto] protocol was created, many of which are taking us away from a concern about increasing greenhouse gases. If, back in the mid-1990s, we knew what we know today about climate, Kyoto would almost certainly not exist, because we would have concluded it was not necessary,” the 60 scientists wrote. See: http://www.canada.com/nationalpost/financialpost/story.html?id=3711460e-bd5a-475d-a6be-4db87559d605
“It was only 30 years ago that many of today's global-warming alarmists were telling us that the world was in the midst of a global-cooling catastrophe. But the science continued to evolve, and still does, even though so many choose to ignore it when it does not fit with predetermined political agendas,” the 60 scientists concluded.
'Climate Change is Nothing New'
In addition, an October 16, 2006 Washington Post article titled “Climate Change is Nothing New” echoed the sentiments of the 60 scientists as it detailed a new study of the earth’s climate history. The Washington Post article by reporter Christopher Lee noted that Indiana University geologist Simon Brassell found climate change occurred during the age of dinosaurs and quoted Brassell questioning the accuracy of computer climate model predictions.
“If there are big, inherent fluctuations in the system, as paleoclimate studies are showing, it could make determining the Earth’s climatic future even harder than it is,” Brassell said. See: http://www.washingtonpost.com/wp-dyn/content/article/2006/10/15/AR2006101500672.html
Global Cooling on the Horizon?
In August, Khabibullo Abdusamatov, a scientist who heads the space research sector for the Russian Academy of Sciences, predicted long-term global cooling may be on the horizon due to a projected decrease in the sun’s output. See: http://en.rian.ru/russia/20060825/53143686.html
Sun’s Contribution to Warming
There have also been recent findings in peer-reviewed literature over the last few years showing that the Antarctic is getting colder and the ice is growing and a new 2006 study in Geophysical Research Letters found that the sun was responsible for up to 50% of 20th-century warming. See: http://www.agu.org/pubs/crossref/2006/2006GL027142.shtml
“Global Warming” Stopped in 1998
Paleoclimate scientist Bob Carter has noted that there is indeed a problem with global warming – it stopped in 1998. “According to official temperature records of the Climate Research Unit at the University of East Anglia in the UK, the global average temperature did not increase between 1998-2005. “…this eight-year period of temperature stasis did coincide with society's continued power station and SUV-inspired pumping of yet more carbon dioxide into the atmosphere,” noted paleoclimate researcher and geologist Bob Carter of James Cook University in Australia in an April 2006 article titled “There is a problem with global warming... it stopped in 1998.” See: http://www.telegraph.co.uk/opinion/main.jhtml?xml=/opinion/2006/04/09/do0907.xml&sSheet=/news/2006/04/09/ixworld.html
“Global?" Warming Misnamed - Southern Hemisphere Not Warming
In addition, new NASA satellite tropospheric temperature data reveals that the Southern Hemisphere has not warmed in the past 25 years contrary to “global warming theory” and modeling. This new Southern Hemisphere data raises the specter that the use of the word “global” in “global warming” may not be accurate. A more apt moniker for the past 25 years may be “Northern Hemisphere” warming. See: http://motls.blogspot.com/2006/09/southern-hemisphere-ignores-global.html
Alaska Cooling
According to data released on July 14, 2006 from the National Oceanic and Atmospheric Administration (NOAA), the January through June Alaska statewide average temperature was “0.55F (0.30C) cooler than the 1971-2000 average.” See: http://www.publicaffairs.noaa.gov/releases2006/jul06/noaa06-065.html
Oceans Cooling
Another bombshell to hit the global warming alarmists and their speculative climate modeling came in a September article in the Geophysical Research Letters which found that over 20% of the heat gained in the oceans since the mid-1950s was lost in just two years. The former climatologist for the state of Colorado, Roger Pielke, Sr., noted that the sudden cooling of the oceans “certainly indicates that the multi-decadal global climate models have serious issues with their ability to accurately simulate the response of the climate system to human- and natural-climate forcings.“ See: http://climatesci.atmos.colostate.edu/2006/09/
Light Hurricane Season & Early Winter
Despite predictions that 2006 would bring numerous tropical storms, 2006’s surprisingly light hurricane season and the record early start of this year’s winter in many parts of the U.S. have further put a damper on the constant doomsaying of the global warming alarmists and their media allies.
Droughts Less Frequent
Other new studies have debunked many of the dubious claims made by the global warming alarmists. For example, the claim that droughts would be more frequent, severe and wide ranging during global warming, has now being exposed as fallacious. A new paper in Geophysical Research Letters authored by Konstantinos Andreadis and Dennis Lettenmaier finds droughts in the U.S. becoming “shorter, less frequent and cover a small portion of the country over the last century.” http://www.worldclimatereport.com/index.php/2006/10/13/where-are-the-droughts
Global Warming Will Not Lead to Next Ice Age
Furthermore, recent research has shown that fears that global warming could lead to the next ice age, as promoted in the 2004 Hollywood movie “The Day After Tomorrow” are also unsupportable. A 2005 media hyped study “claimed to have found a 30 percent slowdown in the thermohaline circulation, the results are published in the very prestigious Nature magazine, and the story was carried breathlessly by the media in outlets around the world…Less than a year later, two different research teams present convincing evidence [ in Geophysical Research Letters ] that no slowdown is occurring whatsoever,” according to Virginia State Climatologist Patrick Michaels, editor of the website World Climate Report. See: http://www.worldclimatereport.com/index.php/2006/10/13/overturning-ocean-hype
‘Hockey Stick’ Broken in 2006
The “Hockey Stick” temperature graph’s claim that the 1990’s was the hottest decade of the last 1000 years was found to be unsupportable by the National Academy of Sciences and many independent experts in 2006. See: http://www.epw.senate.gov/pressitem.cfm?party=rep&id=257697
Study Shows Greenland’s Ice Growing
A 2005 study by a scientist named Ola Johannessen and his colleagues showed that the interior of Greenland is gaining ice mass. See: http://www.co2science.org/scripts/CO2ScienceB2C/articles/V8/N44/C1.jsp Also, according to the International Arctic Research Institute, despite all of the media hype, the Arctic was warmer in the 1930’s than today.
Polar Bears Not Going Extinct
Despite Time Magazine and the rest of the media’s unfounded hype, polar bears are not facing a crisis, according to biologist Dr. Mitchell Taylor from the Arctic government of Nunavut. “Of the 13 populations of polar bears in Canada, 11 are stable or increasing in number. They are not going extinct, or even appear to be affected at present,” Taylor wrote on May 1, 2006. See: http://www.thestar.com/NASApp/cs/ContentServer?pagename=thestar/Layout/Article_Type1&c=Article&cid=1146433819696&call_pageid=970599119419
Media Darling James Hansen Hypes Alarmism
As all of this new data debunking climate alarmism mounts, the mainstream media chooses to ignore it and instead focus on the dire predictions of the number-one global warming media darling, NASA’s James Hansen. The increasingly alarmist Hansen is featured frequently in the media to bolster sky-is-falling climate scare reports. His recent claim that the Earth is nearing its hottest point in one million years has been challenged by many scientists. See: http://www.co2science.org/scripts/CO2ScienceB2C/articles/V9/N39/EDITB.jsp Hansen’s increasingly frightening climate predictions follow his 2003 concession that the use of “extreme scenarios” was an appropriate tactic to drive the public’s attention to the urgency of global warming. See: http://naturalscience.com/ns/articles/01-16/ns_jeh6.html Hansen also received a $250,000 grant form Teresa Heinz’s Foundation and then subsequently endorsed her husband John Kerry for President and worked closely with Al Gore to promote his movie, “An Inconvenient Truth.” See: http://www.heinzawards.net/speechDetail.asp?speechID=6 & http://www.columbia.edu/~jeh1/dai_complete.pdf
American People Rejecting Global Warming Alarmism
The global warming alarmists may have significantly overplayed their hand in the climate debate. A Los Angeles Times/Bloomberg poll this August found that most Americans do not attribute the cause of any recent severe weather events to global warming, and the portion of Americans who believe that climate change is due to natural variability has increased over 50% in the last five years.
Senator Inhofe Chastises Media For Unscientific & Unprincipled Climate Reporting
Senator James Inhofe (R-Okla.) Chairman of the Environment and Public Works Committee, commented last week on the media’s unfounded global warming hype and some of the recent scientific research that is shattering the so-called “consensus” that human greenhouse gas emissions have doomed the planet.
“The American people are fed up with media for promoting the idea that former Vice President Al Gore represents the scientific ‘consensus’ that SUV’s and the modern American way of life have somehow created a ‘climate emergency’ that only United Nations bureaucrats and wealthy Hollywood liberals can solve. It is the publicity and grant seeking global warming alarmists and their advocates in the media who have finally realized that the only “emergency” confronting them is their rapidly crumbling credibility, audience and bottom line. The global warming alarmists know their science is speculative at best and their desperation grows each day as it becomes more and more obvious that many of the nations that ratified the woeful Kyoto Protocol are failing to comply,” Senator Inhofe said last week. See: http://www.epw.senate.gov/pressitem.cfm?party=rep&id=264616
“The mainstream media needs to follow the money: The further you get from scientists who conduct these alarmist global warming studies, and the further you get from the financial grants and the institutions that they serve the more the climate alarmism fades and the skepticism grows,” Senator Inhofe explained.
Eco-Doomsayers’ Failed Predictions
In a speech on the Senate floor on September 25, 2006, Senator Inhofe pointed out the abject failure of past predictions of ecological disaster made by environmental alarmists.
“The history of the modern environmental movement is chock-full of predictions of doom that never came true. We have all heard the dire predictions about the threat of overpopulation, resource scarcity, mass starvation, and the projected death of our oceans. None of these predictions came true, yet it never stopped the doomsayers from continuing to predict a dire environmental future. The more the eco-doomsayers’ predictions fail, the more the eco-doomsayers predict,” Senator Inhofe said on September 25th. See: http://epw.senate.gov/speechitem.cfm?party=rep&id=263759
Related Links:
For a comprehensive review of the media’s embarrassing 100-year history of alternating between promoting fears of a coming ice age and global warming, see Environment & Public Works Chairman James Inhofe’s September 25, 2006 Senate floor speech debunking the media and climate alarmism. Go to: (epw.senate.gov/speechitem.cfm?party=rep&id=263759)
To read and watch Senator Inhofe on CNN discuss global warming go to: (http://www.epw.senate.gov/pressitem.cfm?party=rep&id=264308 )
To Read all of Senator Inhofe’s Speeches on global warming go to: (http://epw.senate.gov/speeches.cfm?party=rep)
“Inhofe Correct On Global Warming,” by David Deming geophysicist, an adjunct scholar with the Oklahoma Council of Public Affairs (ocpathink.org), and an associate professor of Arts and Sciences at the University of Oklahoma. (http://epw.senate.gov/fact.cfm?party=rep&id=264537)
« Reply #7 on: February 09, 2015, 08:46:59 AM »
From 2007
Global Warming, humans, Carbon Dioxide
Global Warming: The Cold, Hard Facts?
By Timothy Ball
Monday, February 5, 2007
Global Warming, as we think we know it, doesn't exist. And I am not the only one trying to make people open up their eyes and see the truth. But few listen, despite the fact that I was one of the first Canadian Ph.Ds. in Climatology and I have an extensive background in climatology, especially the reconstruction of past climates and the impact of climate change on human history and the human condition. Few listen, even though I have a Ph.D, (Doctor of Science) from the University of London, England and was a climatology professor at the University of Winnipeg. For some reason (actually for many), the World is not listening. Here is why.
What would happen if tomorrow we were told that, after all, the Earth is flat? It would probably be the most important piece of news in the media and would generate a lot of debate. So why is it that when scientists who have studied the Global Warming phenomenon for years say that humans are not the cause nobody listens? Why does no one acknowledge that the Emperor has no clothes on?
Believe it or not, Global Warming is not due to human contribution of Carbon Dioxide (CO2). This in fact is the greatest deception in the history of science. We are wasting time, energy and trillions of dollars while creating unnecessary fear and consternation over an issue with no scientific justification. For example, Environment Canada brags about spending $3.7 billion in the last five years dealing with climate change almost all on propaganda trying to defend an indefensible scientific position while at the same time closing weather stations and failing to meet legislated pollution targets.
No sensible person seeks conflict, especially with governments, but if we don't pursue the truth, we are lost as individuals and as a society. That is why I insist on saying that there is no evidence that we are, or could ever cause global climate change. And, recently, Yuri A. Izrael, Vice President of the United Nations sponsored Intergovernmental Panel on Climate Change (IPCC) confirmed this statement. So how has the world come to believe that something is wrong?
Maybe for the same reason we believed, 30 years ago, that global cooling was the biggest threat: a matter of faith. "It is a cold fact: the Global Cooling presents humankind with the most important social, political, and adaptive challenge we have had to deal with for ten thousand years. Your stake in the decisions we make concerning it is of ultimate importance; the survival of ourselves, our children, our species," wrote Lowell Ponte in 1976.
I was as opposed to the threats of impending doom global cooling engendered as I am to the threats made about Global Warming. Let me stress I am not denying the phenomenon has occurred. The world has warmed since 1680, the nadir of a cool period called the Little Ice Age (LIA) that has generally continued to the present. These climate changes are well within natural variability and explained quite easily by changes in the sun. But there is nothing unusual going on.
Since I obtained my doctorate in climatology from the University of London, Queen Mary College, England my career has spanned two climate cycles. Temperatures declined from 1940 to 1980 and in the early 1970's global cooling became the consensus. This proves that consensus is not a scientific fact. By the 1990's temperatures appeared to have reversed and Global Warming became the consensus. It appears I'll witness another cycle before retiring, as the major mechanisms and the global temperature trends now indicate a cooling.
No doubt passive acceptance yields less stress, fewer personal attacks and makes career progress easier. What I have experienced in my personal life during the last years makes me understand why most people choose not to speak out; job security and fear of reprisals. Even in University, where free speech and challenge to prevailing wisdoms are supposedly encouraged, academics remain silent.
I once received a three page letter that my lawyer defined as libellous, from an academic colleague, saying I had no right to say what I was saying, especially in public lectures. Sadly, my experience is that universities are the most dogmatic and oppressive places in our society. This becomes progressively worse as they receive more and more funding from governments that demand a particular viewpoint.
In another instance, I was accused by Canadian environmentalist David Suzuki of being paid by oil companies. That is a lie. Apparently he thinks if the fossil fuel companies pay you have an agenda. So if Greenpeace, Sierra Club or governments pay there is no agenda and only truth and enlightenment?
Personal attacks are difficult and shouldn't occur in a debate in a civilized society. I can only consider them from what they imply. They usually indicate a person or group is losing the debate. In this case, they also indicate how political the entire Global Warming debate has become. Both underline the lack of or even contradictory nature of the evidence.
I am not alone in this journey against the prevalent myth. Several well-known names have also raised their voices. Michael Crichton, the scientist, writer and filmmaker is one of them. In his latest book, "State of Fear" he takes time to explain, often in surprising detail, the flawed science behind Global Warming and other imagined environmental crises.
Another cry in the wildenerness is Richard Lindzen's. He is an atmospheric physicist and a professor of meteorology at MIT, renowned for his research in dynamic meteorology - especially atmospheric waves. He is also a member of the National Academy of Sciences and has held positions at the University of Chicago, Harvard University and MIT. Linzen frequently speaks out against the notion that significant Global Warming is caused by humans. Yet nobody seems to listen.
I think it may be because most people don't understand the scientific method which Thomas Kuhn so skilfully and briefly set out in his book "The Structure of Scientific Revolutions." A scientist makes certain assumptions and then produces a theory which is only as valid as the assumptions. The theory of Global Warming assumes that CO2 is an atmospheric greenhouse gas and as it increases temperatures rise. It was then theorized that since humans were producing more CO2 than before, the temperature would inevitably rise. The theory was accepted before testing had started, and effectively became a law.
As Lindzen said many years ago: "the consensus was reached before the research had even begun." Now, any scientist who dares to question the prevailing wisdom is marginalized and called a sceptic, when in fact they are simply being good scientists. This has reached frightening levels with these scientists now being called climate change denier with all the holocaust connotations of that word. The normal scientific method is effectively being thwarted.
Meanwhile, politicians are being listened to, even though most of them have no knowledge or understanding of science, especially the science of climate and climate change. Hence, they are in no position to question a policy on climate change when it threatens the entire planet. Moreover, using fear and creating hysteria makes it very difficult to make calm rational decisions about issues needing attention.
Until you have challenged the prevailing wisdom you have no idea how nasty people can be. Until you have re-examined any issue in an attempt to find out all the information, you cannot know how much misinformation exists in the supposed age of information.
I was greatly influenced several years ago by Aaron Wildavsky's book "Yes, but is it true?" The author taught political science at a New York University and realized how science was being influenced by and apparently misused by politics. He gave his graduate students an assignment to pursue the science behind a policy generated by a highly publicised environmental concern. To his and their surprise they found there was little scientific evidence, consensus and justification for the policy. You only realize the extent to which Wildavsky's findings occur when you ask the question he posed. Wildavsky's students did it in the safety of academia and with the excuse that it was an assignment. I have learned it is a difficult question to ask in the real world, however I firmly believe it is the most important question to ask if we are to advance in the right direction.
 Other Articles
http://www.canadafreepress.com/2007/global-warming091307.htm
http://www.canadafreepress.com/2007/global-warming072007.htm
http://www.canadafreepress.com/2006/harris061206.htm
http://www.canadafreepress.com/2007/global-warming020507.htm
Dr. Tim Ball, Chairman of the Natural Resources Stewardship Project, is a Victoria-based environmental consultant and former climatology professor at the University of Winnipeg. He can be reached at letters@canadafreepress.com
