Eagle 1
my 99 Valk
Salem, Oregon
« on: April 11, 2015, 06:32:34 PM » |
Seems I have one of those pesky gremlins in my machine (99 IS), doesn't appear to be dangerous (hopefully) just annoying as hell. When approaching a stop I will use front and rear brake in order to come to a smooth(er) stop, as I slowly pull the front brake there is a very audible click most of the time when the forks compress but also has happened on rebound. It does appear that I can actually feel it in my left foot (while on the peg), I somewhat discount this as I know sound and feel can travel in mysterious ways. I have only been using my front brake in this manor for a short time (since I found it allows for a more controlled stop, thus I can point to no actual event or item that had taken place around the time this phenomenon began. One thing I have noted is it only happens once each stop, and I cannot make it happen again until the next stop, no matter how many times I pull the front brake during that stop. I am hoping someone else has had a similar experience and has solved it, but do not hold much hope as my doctor always tells me "if its weird you will get it", which is most likely the case here. By the way I have looked the bike over for any dangling or loose items with no success. Any help will surely be appreciated, Thanks Manny
« Reply #1 on: April 11, 2015, 06:45:05 PM » |
Normal. Glad to hear you learned to use the front brake. It has twice the stopping power as rear and you won't slide the front tire as you would the rear. Personally I use 75-80% front brake for stopping.
BradValk48237
« Reply #2 on: April 11, 2015, 07:09:06 PM » |
Normal...
Its the Floating calipers.......
Brad
« Reply #3 on: April 11, 2015, 07:36:34 PM » |
Also, there is an audible (if not quite tactile) click in the front brake light switch at the lever. When you hear it, you know it is working.
Valkjerk
Freedom ain't free.....just the price of a Valkyri
NOLA
« Reply #4 on: April 12, 2015, 06:17:55 AM » |
That click you hear can be eliminated. It's some kind of little keeper device that has to do with the pads. I told my mechanic when he was working on my bike and he said no problem and tried to show me what was happening but went right over my head. He fixed it in 5 seconds. Take this to the tech board and some of those geniuses will tell you what's happening and how to fix it. Again, it's some kind of retainer that has to do with the pads.
Ride like it's your last....grinnin' all the way.
Art708
« Reply #5 on: April 12, 2015, 07:37:33 AM » |
I slid my front tire last Saturday. As soon as I felt it start to slide I let off the brake lever. I had managed to slow down enough for the dog to clear the road.... I still left about 15' of black on the road.
Art 2014 Kawasaki Concours 14 Black
« Reply #6 on: April 12, 2015, 07:54:34 AM » |
Sure Art you can slide it but you gotta have one helluva handful unless something's wrong
Art708
« Reply #7 on: April 12, 2015, 01:04:45 PM » |
I musta had a helluva handful then. All I knew was that I did not want to hit that big animal going 70.
Big Al of Tennessee
« Reply #8 on: April 12, 2015, 05:35:02 PM » |
Front Fork Triple Tree big nut could be loose.
Tighten that, Oh God I should have put this on the Tech Side.
Have fun, but keep your nuts tight.
« Last Edit: April 12, 2015, 05:36:51 PM by Big Al of Tennessee »
« Reply #9 on: April 12, 2015, 05:43:09 PM » |
