November 23, 2025, 03:39:17 PM *
Author Topic: Help, Tool for removing small screw with broken head.  (Read 390 times)
BigAlOfMD
« on: July 03, 2015, 11:52:57 PM »
Help, I broke the head off a small #8 x 1/2" metal screw.
It is screwed into aluminum.
« Reply #1 on: July 04, 2015, 12:18:03 AM »
da prez
Wilmot Wi
« Reply #2 on: July 04, 2015, 08:31:24 AM »
  Tap-tap-tap with a small hammer. Drill a small hole in a piece of steel the size of the root diameter of the screw, that you can mount over the broken screw. once you have figured the location with marks , file the screw flush. Attach the plate and drill out the broken screw. Root diameter is the inner shank below the threads. Re-tap the threads. On a tap drill chart , it will tell you what size drill bit to use. Some taps have them on the side . The steel plate will guide the drill thru the center of the broken screw. Take your time. This method will work.
                                         da prez
Jess Tolbirt
White Bluff, Tn.
« Reply #3 on: July 04, 2015, 08:57:27 AM »
if its a sheet metal screw you are screwed
may have to drive it all the way through and use a larger screw
