March 31, 2026, 09:54:57 PM *
Author Topic: Miss fire, Loosing spark, backfire, popping  (Read 1051 times)
Blaze
Usa
« on: August 08, 2015, 06:21:48 PM »
I had an issue and found the resolution and thought it might be beneficial to someone else. I've done a search and have not found someone else with a similar post. My bike would, Miss fire, Loose spark, backfire, pop. I thought I was loosing spark occasionally because it would run periodically on all cylinders. Come to find out, after I washed my bike, or ran through a lot of rain, It would happen. What I found was one of the weep holes in the spark plug area was clogged by dirt. Not allowing the water to drain properly. When the spark plug area was full of water the spark was shorted by the water, loosing the spark for that cylinder. Hope this helps someone.
« Reply #1 on: August 09, 2015, 05:27:59 AM »
Thats good for folks to know. Its a good idea to poke around and make sure they are clear every now and again.
There have been some here that said we were kidding about those drain holes.
« Reply #2 on: August 09, 2015, 09:05:37 AM »
After winter and just before "serious" riding season begins or when I change tires after looking at my spark plugs and rechecking the gap I rod those drain holes out. I can see where water buildup around the spark plug(s) would cause a problem. Add the rodding out of those drain holes when yer doing the 10 G lube on the ladies hind side!  cooldude You're already on the lift anywho.  Roll Eyes And by checking you MIGHT keep critter varmints from turning the drain hole into some kinda home or nest!  uglystupid2 RIDE SAFE.
slider
mulberry arkansas
« Reply #3 on: August 09, 2015, 01:56:23 PM »
I cant seem to locate the drain holes,,,Do they access from underneath the head/?
a proud navy veteran
« Reply #4 on: August 09, 2015, 02:02:26 PM »
Yes. Also the base of the spark plug holes. It's been a while since I've seen mine, and will be doing them over the winter maintenance when I change my plugs to Iridiums.
« Last Edit: August 09, 2015, 02:06:55 PM by gordonv » Logged
Blaze
Usa
« Reply #5 on: August 09, 2015, 02:20:59 PM »
They come out real close to the header bolts.
« Reply #6 on: August 09, 2015, 03:33:26 PM »
Just pour some water in the holes and look where it leaks.   Smiley
