Corbin Sidebags & Givi Top Case
hubcapsc:
I made this ugly bracket to put my Givi trunk on... I used it some
before the saddlebags came in. It's off now, but ready to use
on long trips... saddlebag lids open, passenger has good
backrest and the trunk lid opens over the backrest...
jpntiger:
Mike,
I am looking to buy "http://www.revzilla.com/motorcycle/givi-e370-tech-monolock-topcase"
This also comes with Universal Mounting Plate.
But i am not sure if i have to buy the mounting bracket like this one
http://www.revzilla.com/motorcycle/givi-m5m-monolock-top-case-mounting-plate?
I do have a "Rear Carrier Luggage Rack" installed. I prefer to mount it on top of it. But the load capacity for the 'Rear carrier Luggage Rack' concerns me 6.6 LBS. This Givi case itself is 8.8 LBS.
Wilkins,
Most of the time i ride to work solo, So i am thinking of mounting like 'wilkins' and remove the Rear Carrier luggage rack. Wilkins can you share some more details on what do i need?
thanks a lot!
hubcapsc:
I have monokey instead of monolock stuff, so it doesn't directly
relate... but...
I think you'll for sure need an appropriate mounting plate... the mounting
plate is fixed to the rear carrier and the trunk is fixed to the plate... is swilkens'
mounting place bolted directly to the Valkyrie's fender grab handles?
Honda's lawyers make them put those lawyer stickers on there I guess.
I think the new Valkyrie's rear carrier is much more studly than the
old Valkyrie's, and I hauled a giant Givi trunk all over the country
with that one...
swilkins65:
To mount my Givi mono lock case plate I made brackets that bolt into the interior screw holes on the grab handles, removed the rear pillion seat and then screw/nut secured the Givi plate to the brackets. Not the best quality welds or assembly but when the case is on you really can't even see any of it.
swilkins65:
One of these days I'll get better at linking photos
https://www.dropbox.com/s/86xgdwfdh3mjvgo/IMG_1728.JPG?dl=0
https://www.dropbox.com/s/r7pmiy4qopfuyyq/IMG_1727.JPG?dl=0
https://www.dropbox.com/s/wew9alihngppq41/IMG_1724.JPG?dl=0
Navigation
[0] Message Index
[*] Previous page
