November 23, 2025, 09:28:56 AM *
Author Topic: Won't start  (Read 681 times)
carl1up
sardinia ohio
« on: September 05, 2015, 06:23:29 PM »
Help laid bike down easy now won't start
« Reply #1 on: September 05, 2015, 06:29:50 PM »
kill switch ?
Is bike in neutral kickstand up?
You have to turn off key and then on to reset after a spill
J.Mencalice
« Reply #2 on: September 05, 2015, 06:36:51 PM »
Need more info to help.  Did you check the kill switch on the right side grip?
« Reply #3 on: September 05, 2015, 07:13:02 PM »
Sounds like the tip over switch. Like Oss said cycle the key.
carl1up
sardinia ohio
« Reply #4 on: September 06, 2015, 05:02:47 AM »
Kick stand up, kill switch set at run. In neutral, still nothing when starter button is pressed
« Reply #5 on: September 06, 2015, 05:04:43 AM »
What does that mean, it won't start ? Does the starter work, or, not ?
Regardless, the fellas covered it.
Its either the tilt switch [ recycle key] or kill switch [ make sure its off].
Or, see if it will start with clutch lever pulled in.
carl1up
sardinia ohio
« Reply #6 on: September 06, 2015, 05:13:36 AM »
Does nothing when pressing the starter button. The lights dim when trying to start but no starter
« Reply #7 on: September 06, 2015, 05:18:29 AM »
Maybe it's just a coincidence that this happened after the tip over. Have you done a clean up of the starter switch ?  If not I would do that next. Be careful not to lose any of the little springs and screws. If you haven't done it before I think there is a write up in shoptalk or in the tech section about it.  cooldude
« Reply #8 on: September 06, 2015, 06:17:18 AM »
can't hurt to check battery connections to make sure completely tight and not loose.
« Reply #9 on: September 06, 2015, 06:43:23 AM »
Have you turned the key off, waited a few seconds and turned the key back on
You really dont want to know how I learned this    Cry
The good thing is you did not describe hearing a THUNK of stripped starter gears !
(dreaded but rare hydrolock)
The only thing I can think of otherwise is maybe the connection on the kickstand tip over sensor came loose  Are there any loose wires under there?
which side did it fall over onto ?  That may give us an idea   Also maybe we have a member near cincinatti   or columbus  where you are who can come over
« Last Edit: September 06, 2015, 06:46:57 AM by Oss » Logged
Bigwolf
Cookeville, TN
« Reply #10 on: September 06, 2015, 06:49:57 AM »
I am assuming you mean the instrument lights dim.  The headlight should go out when the start button is pushed.  If it does not go out, then there is definitely a problem with start switch.
I have heard of the bank angle sensor getting stuck when bike was dropped.  If everything else checks OK, then a few light taps on the angle sensor might solve the problem.
« Reply #11 on: September 06, 2015, 06:15:17 PM »
Didn't say how much or how long the bike was tipped.  May be a good idea to pull the plugs and try to turn it over just in case.
Surely the key was turned off and on again.
carl1up
sardinia ohio
« Reply #12 on: September 07, 2015, 04:20:00 AM »
Was the starter switch.thanks to all
« Reply #13 on: September 07, 2015, 09:41:28 AM »
OH, good to know. Talk about coincidences.
