November 23, 2025, 10:38:41 AM *
Author Topic: Handlebar upgrade  (Read 639 times)
Aries
« on: September 13, 2015, 04:58:46 PM »
I would like to switch out my bars for something that feels more comfortable. I'm 6' tall and while riding, hands on the bar and boots on the highway pegs, I feel like I'm doubled over. Any recommendations?
« Reply #1 on: September 13, 2015, 05:30:23 PM »
Try 4" risers.  No cable or line changes and they move the bars back somewhat.
Aries
« Reply #2 on: September 13, 2015, 05:33:02 PM »
Any particular brand?
« Reply #3 on: September 13, 2015, 05:34:49 PM »
I've heard handle bar riser will help, the answer for me was to go with Mick O Pegs for my knees.   I love them.
« Reply #4 on: September 13, 2015, 05:35:19 PM »
Dont get the chinese knockoffs.
BobB
« Reply #5 on: September 13, 2015, 06:02:49 PM »
Stay away from the risers that have a small cross section at the bar clamp.  There are many available.  Mine were made for a H-D Sportser...
« Reply #6 on: September 13, 2015, 06:03:09 PM »
Aeromach 4" pullbacks for Honda are great.  Spendy and fancier than they need to be (especially buried under an interstate fairing), but about as much movement as you can get without changing anything.
(out of stock?)
http://www.aeromachmfg.com/RISER_SET_4_VTX_Retro_1300_p/am-4120c.htm
You can probably get about the same thing, less fancy, from Scootworks (heavy duty).
http://www.scootworks.com/shop.cgi/page=partshonhandle.htm/SID=PUT_SID_HERE
Pad the tank well when you loosen the OE riser bolts or you'll have a real awh crap moment.
If you go much over 4 1/4", you may be able to get away with rerouting the throttle cables inside the triple tree and nothing else (and you may need to turn the handlebar wire clips around 180* even with 4").  Just be sure to test your running bike (for involuntary throttle gooses) turning the bars lock to lock before riding it.
wiggydotcom
Yorkville, Illinois
« Reply #7 on: September 13, 2015, 06:08:41 PM »
Jess gave good advice on his post. I put Harley style Deuce Risers on my I/S. I believe they are 6 inch. I kept the original cables/hyd lines but did have to reroute some of them to inside the triple tree.
I also had to remove the lines from the handlebar clips and then re-tywrap them to themselves. It worked fine but the better solution would be to go with only 4 inch risers or buy longer lines/cables if you go with the 6 inch.
VRCC #10177
VRCCDS #239
« Reply #8 on: September 13, 2015, 06:23:17 PM »
Wiggy, the Harley Deuce are 5.5", and require you to cut the bottom domes off, and come with SAE 1/2" bolts, not Metric, so you can get conversion bolts or drill a few thousandths of material out of the bolt holes in the tree.  Barely shaves any material and you can go back to metric without worry or problem later.
http://www.jpcycles.com/product/5000728?utm_source=none&utm_term=[74945928610%3Aproduct_type_l1%3D%3Dvehicles%2520%26%2520parts%26%2520product_type_l2%3D%3Dland%2520vehicles%26%2520product_type_l3%3D%3Dmot&cid=Google+SEARCH+NON-BRAND+PLA+-+Shopping+Campaign&adpos=1o1&creative=42616780690&device=c&matchtype=&network=g&gclid=CLbmoIKx9ccCFcOQHwodJYkCjA
See the bottom domes?
http://www.ebay.com/itm/Drag-Specialties-56033-00-Deuce-Style-Risers-/301731682962
Conversion bolts are easier.
http://www.phatperformanceparts.com/LA_Choppers_Handlebar_Risers_Mounting_Bolts_1_2_p/lac-risers-studs.htm
Alien
Ride Safe, Be Kind
Earth
« Reply #9 on: September 14, 2015, 08:02:41 AM »
(out of stock?)
Or just remove the tank altogether.
« Reply #10 on: September 14, 2015, 08:07:54 AM »
That's overkill, no?
Momz
ABATE, AMA, & MRF rep.
« Reply #11 on: September 14, 2015, 08:21:13 AM »
ALWAYS QUESTION AUTHORITY!
