November 23, 2025, 05:00:56 AM *
Author Topic: Tech question, need help  (Read 737 times)
Aries
« on: September 26, 2015, 02:53:26 PM »
Took the valk out today and the minute I pulled into my driveway, she died. I turned the ignition key off and then turned it back on. When I pushed the start button nothing happened but the head lamp dimming. No engine turn what-so-ever. I checked the battery and have 12.7 so that's not the problem. Anyone have any ideas what I should check next. I'm not much of a mechanic so this may be something simple like a fuse. Thoughts or guidance anyone?
« Reply #1 on: September 26, 2015, 03:14:55 PM »
kill switch accidentally touched,
loose kickstand switch (Is there a bump at the curb and have you hit any really big potholes lately)
sometimes my bike will only start in neutral with kickstand up
loose grounding cable?
check the 30amp and other fuses
« Last Edit: September 26, 2015, 03:16:36 PM by Oss » Logged
« Reply #2 on: September 26, 2015, 04:13:04 PM »
Just because Ihe battery had 12V doesn't mean it's not the problem.  How old is it?  Three years or more,  get a new one.
Master Blaster
Deridder, Louisiana
« Reply #3 on: September 26, 2015, 04:42:08 PM »
Check the starter button, is a weak point, the tech board should cover it.
Aries
« Reply #4 on: September 26, 2015, 04:59:49 PM »
Ok, I went out about 30 minutes later from the time of my initial post. Turned the ignition key and the bike started right up. I then shut the engine off and then tested the kickstand theory and found that if you drop the stand while the bike is in gear, the engine will stop. This makes sense. I do remember dropping the stand while still in gear so that would explain why the bike cut-off initially. What puzzles me is that once I put the bike back in neutral, the bike still would not start. I tried repeatedly and still no engine start. Then I walked away, sent my post, tried again 30 min later, doing the exact same thing as a half hour before, then the bikes starts perfectly....? Could this be a possible issue with the kickstand kill switch?
Moonshot_1
« Reply #5 on: September 26, 2015, 05:23:25 PM »
Behold the power of this website! Just posting the question and tada!
Could be just an anomaly. Wouldn't do anything unless it happens again.
If it does make sure---
Kickstand is up
Kill switch is off
Clutch lever in or
Bike in neutral
Still won't start, begin the process.
Start with cleaning starter button. It is in the Shoptalk section. And it don't cost nothing.
Then go to the things that will cost something.
But it really has to go wrong enough times to track the problem down or present a range of symptoms. Ya ain't there yet.
Mike Luken
Cherokee, Ia.
« Reply #6 on: September 26, 2015, 06:17:33 PM »
Be very, very careful with the small spring inside the starter push button assembly
« Reply #7 on: September 27, 2015, 05:02:07 AM »
Take the switch housing (throttle side) apart, clean the start switch and the kill switch.
Every year in Daytona we have to jump start a bike due to using the kill switch or side stand to turn off the engine.  Sooner or later you too will forget the key, I just hope its somewhere help is available.
« Reply #8 on: September 27, 2015, 05:51:35 AM »
My Valk can be in neutral with the neutral light not being on. The neutral light must be on for it to start with the side stand down.
« Reply #9 on: September 27, 2015, 08:05:16 AM »
I've had that similar issue with starter switch only once.  Tried starting in 1st gear which I 99% of the time do not do since I usually park in neutral on level ground.  I pushed starter switch while in first gear and nothing, totally dead.
Believe it or not,   a once in a lifetime coincidence,  I was in a parking lot about 30 miles from home and a fellow Valkyrie owner comes up to me (my jaw dropped) and says try putting it in neutral and see if it starts firing it up.  WALLA - it worked.
I was stumped for a split second or two and probably would have tried putting the bike into neutral to start it 1-2 minutes later trying something different, but to see a fellow Valk rider come up to me in a parking lot ASAP was a once in a lifetime oddity.   Glad he came by though.
I haven't tried cleaning my starter switch yet since hasn't happened again, but probably couldn't hurt.
Alien
Ride Safe, Be Kind
Earth
« Reply #10 on: September 27, 2015, 08:08:49 AM »
^^THIS^^  Took me about 2 hours to find it the first time I let it get away from me.
Ride Safe,
Alien
