November 23, 2025, 03:33:30 AM *
Author Topic: Gas Station Flow Rates Increasing...  (Read 1183 times)
Joe Hummer
Arnold, MO
« on: October 14, 2015, 08:15:55 AM »
A good laugh for the day...This weekend, I contacted a couple of the local gas stations asking if there was a way to slow the pumps down when filling up the bikes. As all riders know, filling a bike tank on a fast pump leads to gas spilling all over the tank...and the nozzles usually don't have a fine enough control to keep this from happening. Here is part of the response I got from Phillips 66...
"Most dispensers have comparable flowrates so this issue would not be isolated to Phillips 66, Conoco, or 76 Brands. There is no way to restrict the flowrate at each station. One option would be to fill up a portable container, then use that to fill up the motorcycle, but we understand that this option is not very convenient."
Seriously!!?? This is the best they can come up with to keep from splashing gas all over our bikes??
I think it is time for all motorcycle riders to write their gas station customer service departments notes letting them know that we are not happy about this problem. They have sped up the pumps to the point of absurdity...all to please impatient motorists. Who is going to join me?
1999 Valkyrie Interstate
DK
Little Rock
« Reply #1 on: October 14, 2015, 09:11:16 AM »
I wonder how many fires are caused by the overflow. I have seen pics of it happening but I've no idea how many happen each year.
If it is a significant number, the AMA should place pursuing a regulation requiring on-off flow restricters to its legislative agenda.
I remember a post from several years concerning enlarging the fill pipe vent hole by drilling it out to lot the air escape quicker which would minimize the sudden eruption of gas and probably also enable getting more gas in before things get sensitive.
The person posting drilled it out. I haven't done this for fear of a spark starting a fire. I'm considering trying to do it with a brass drift which I think would be safe in that it wouldn't caust a spark.
Another possibility would be for someone to see if a flow restricter could be devised that you carry with you and clamp on the nozzle for adding the last half gallon or so. However, this could be even more dangerous.
Dandangerous.
PAVALKER
Pittsburgh, Pa
« Reply #2 on: October 14, 2015, 09:38:22 AM »
http://www.mccuff.com/
John
msb
Agassiz, BC Canada
« Reply #3 on: October 14, 2015, 12:02:58 PM »
Now that would be a good item to have on board, if they do work as shown. You have one?
I've always just kept my ring and little finger in between the pump handle and trigger to try and control the flow...usually works but can be a pain sometimes.
'99 Red  & Black IS
« Reply #4 on: October 14, 2015, 12:32:28 PM »
Maybe overly simplistic but I tend to find older station's pumps are more likely to feed slow than new stations.  That said, I try to pass stations that look like they do so little business they have old gas (and who knows what else) in their tanks.
Mobile Mayor
South Central Pa.
« Reply #5 on: October 14, 2015, 01:46:41 PM »
I believe that flow rate can be adjusted.  Recently, I happened to be at a local station where the pumps were being serviced and checked for proper calibration.  The pumps were difficult to control when trying to top off.   I had a small spill.   I went to the person working on the pump in the next island and  informed him of the problem,  and why bikers have difficulty 3/4 gallon in,  and what could result if gas hit hot pipes.   He said he would take care of it.   The nozzles are now much easier to feather when topping off.   Station managers should be made aware of this type of situation so that they can make pump technicians aware that they have to correct the problem.
PAVALKER
Pittsburgh, Pa
« Reply #6 on: October 14, 2015, 01:48:02 PM »
I do not have one....but think a friend has a similar device....will ask him about it.
John
« Reply #7 on: October 14, 2015, 02:10:14 PM »
I never have trouble feathering a nozzle in all my travels. Maybe just a couple. I put a rag or paper towel over the filler hole as I fill. Then I place it over the tip as I put it back.
« Reply #8 on: October 14, 2015, 03:01:24 PM »
I fill my tank to a higher level than do a lot of riders.
Some nozzles, maybe even most, I find respond to variable flow rate by feathering the grip.  Some don't.  Some are just either all on or completely off.  When I encounter one of those I just bury the nozzle in the fuel after the initial pressure shut of and the repeatedly squeeze the grip and let it shut off until I get to the level that is acceptable to me.
WintrSol
Florissant, MO
« Reply #9 on: October 14, 2015, 03:29:09 PM »
I have one in my saddle bag. Yes, it helps keep the splashes inside the tank, and, as the tank fills, even if the nozzle shuts off early, you can keep hitting the lever to get that last 1/2 gallon in. Some nozzles have small vent holes near the end, so you have to make sure you hold it so that hole is past the end of the cuff; otherwise, I just put the nozzle just past the end of the cuff, and hold it there. I wipe then stuff mine with a paper towel, before putting it back in the saddle bag.
« Last Edit: October 14, 2015, 03:31:21 PM by WintrSol » Logged
msb
Agassiz, BC Canada
« Reply #10 on: October 14, 2015, 05:15:40 PM »
I have one in my saddle bag. Yes, it helps keep the splashes inside the tank, and, as the tank fills, even if the nozzle shuts off early, you can keep hitting the lever to get that last 1/2 gallon in. Some nozzles have small vent holes near the end, so you have to make sure you hold it so that hole is past the end of the cuff; otherwise, I just put the nozzle just past the end of the cuff, and hold it pthere. I wipe then stuff mine with a paper towel, before putting it back in the saddle bag.
Thanks for the info. Smiley
'99 Red  & Black IS
« Reply #11 on: October 14, 2015, 05:25:42 PM »
Wait until gas goes up in price    Grin
john
tyler texas
« Reply #12 on: October 14, 2015, 07:41:21 PM »
 Shocked     Roll Eyes     Undecided      coolsmiley      2funny 2funny 2funny
vrcc # 19002
« Reply #13 on: October 14, 2015, 11:49:02 PM »
YOU DO NOT NEED TO DRILL IT OUT.
Take a scratch all and just run it around and around in the pipe it will enlarge it out real nice.
The pipe is not steel, it is a flimsy lead/aluminum or something very soft.    I enlarged MGM's hole shortly after I bought the bike.      That was the way I enlarged the hole.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #14 on: October 15, 2015, 03:07:42 AM »
$25 on sale for $20 for a hunk of plastic  uglystupid2 I'll just keep feathering the trigger on the nozzle  laugh
DarkSideR
Pueblo, Colorado
« Reply #15 on: October 15, 2015, 05:55:35 AM »
If it would prevent what happens in the video below from happened I think $25 is well worth it.
http://bikerpunks.com/mediaviewer/5165/custom-motorcycle-goes-up-in-flames-at-the-fuel-pump.html
« Last Edit: October 15, 2015, 06:26:31 AM by DarkSider (AKA Joshcornkid) » Logged
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
MP
North Dakota
« Reply #16 on: October 15, 2015, 06:21:28 AM »
Phillips works too to enlarge hole.
"Ridin' with Cycho"
« Reply #17 on: October 15, 2015, 07:40:56 AM »
I don't buy gas at Phillips 66/Conoco at all ever.  I caught them padding the pumps at 3 different stations. One of their stations, their car wash machine ran into my Explorer and ripped the roof rack off. They denied any responsibility.  I called Tom Martino, radio consumer advocate, on the air.  Suddenly they decided to pay. I had a P-66/Conoco card that had a ridiculous annual rate if you carried a balance and they wouldn't lower it so I cut it up and sent it to them - like this:
16 years ago I wrote a tech article on enlarging the hole - you can do it with a tapered punch or the like, the metal is soft.  I just drilled it out way oversize on Jade, while I had the tank off and purged for brazing the belly tank bung.
http://www.horseapple.com/Valkyrie/Tech_Tips/Burping_Brunhilda/burping_brunhilda.html
Never tried to stick the nozzle in the gas and use the auto-shutoff.  Have to check that out.  Good tip.
« Last Edit: October 15, 2015, 07:43:56 AM by MarkT » Logged
« Reply #18 on: October 15, 2015, 08:01:30 AM »
         Beneath the video it said the dud(e) left the engine running while refueling.  uglystupid2 We all ride. THAT being said I ALWAYS shut the engine off during the refueling process. NOT shutting engine off while refueling might/can/WILL be expensive!  uglystupid2 This video proves the expense part.  crazy2 I won't even touch on the stupidity part.  Roll Eyes RIDE SAFE.
0leman
Klamath Falls, Or
« Reply #19 on: October 15, 2015, 08:12:47 AM »
I bought a McCuff while I lived in CA due to the device they required at all pumps.  That rubber collar that is suppose to keep the gas fumes in the tanks while filling.  It was almost impossible to fill the tank up with that collar on.   The McCuff allowed me to fill nearly to top without much problems.  don't use it on pumps without the collar.
Most of the pumps I use let me feather the flow for the last quarter/half gallon.   Those that don't, I don't try to fill to the top.  It would be great if all pumps would allow one to feather the flow.
DarkSideR
Pueblo, Colorado
« Reply #20 on: October 15, 2015, 08:21:31 AM »
To top off my tank I have developed a method that works at most gas stations despite the flow rate to really, really top it off.
When you look into the tank (down the filler hole) there is a flanged ring (about a 1/4" deep) at the top of the hole, and then below that is the neck of the filler hole. The flange is a smaller diameter than the neck of the filler hole (this is the key).
When filling up, to start I bury the pump nozzle as far as it will go into the tank and pump away. After the first auto-shutoff I then angle the nozzle so that the tip of the nozzle is under the flanged ring, and right up against the neck of the filler hole. I then feather the pump. What happens is the opening of the nozzle is right against the neck slowing down the flow of gas. What also happens is the opening of the nozzle is under the flanged ring and acts as a splash guard for the gas that does want to spit out.
With this method I can usually get an addition 1/2 gallon of gas into the tank without mishap.
FYI - I have also done the gas tank mode to enlarge the filler vent hole which speeds up the feather the additional 1/2 gallon into the tank.
Hope this helps ya'll.  Smiley
VRCC#34410
VRCCDS#0263
msb
Agassiz, BC Canada
« Reply #21 on: October 15, 2015, 08:46:55 AM »
Relating this topic to another post recently about "excessive lean" of ones Valk when on the side stand (my IS has a pretty good lean).  I too try to fill my tank to the max, especially when on longer rides. Filling it when it is upright makes it easier to squeeze in that extra half gallon or so, and when doing this I usually just take right off from the pump after filling. Just this past Summer though, I forgot myself and placed the bike back down on the stand after filling "to the max" to get something out of the trunk, and a significant leak through the closed gas cap ensued. Lesson learned.  uglystupid2
'99 Red  & Black IS
Williamsburg, KY
« Reply #22 on: October 15, 2015, 12:10:59 PM »
Been riding for 36 years and never had that happen. Don't need to spend $25 to prevent what happened in the video, just some common sense........but then again it's not so common.  cooldude
DarkSideR
Pueblo, Colorado
« Reply #23 on: October 15, 2015, 12:26:08 PM »
I read the bike was running while he was filling up. That is a big no-no.
VRCC#34410
VRCCDS#0263
« Reply #24 on: October 15, 2015, 12:33:57 PM »
Then there's the loonies who rely on the auto shut off and clean their windshield whilst refilling.  Shocked
« Reply #25 on: October 15, 2015, 03:32:22 PM »
Same way.  Centerfill gas tank, I stay on the bike and fill to top.  But some pumps have no slow feed and it will eventually squirt out no matter how tricky you are with the nozzle, so I stop short of squirting out.
If you really need a full tank on a fast feed pump, you can leave the nozzle buried deep and just keep letting it auto shutoff (click, click), and no splash.  It gets full or your hand gets tired.
However you do it, you need to look down in the hole and observe the level...... eventually, it's full enough.
« Last Edit: October 15, 2015, 03:35:29 PM by Jess from VA » Logged
« Reply #26 on: October 15, 2015, 05:20:59 PM »
So many double entedres to work with
Here's the first
The next
And then
So many
I wish I was younger
WintrSol
Florissant, MO
« Reply #27 on: October 15, 2015, 06:49:24 PM »
If you really top off the tank, don't leave your bike sitting in the sun while you go inside to get something. I learned this in Bryson City, NC; went inside to get a snack, and found a pool of gas under my VS800. Since then, if I fill up for maximum range, I then push or ride to a shady spot if I'm going to leave it sit a short while.
« Reply #28 on: October 15, 2015, 08:36:42 PM »
I was at McDonalds having lunch one day. Bright sunshine and 120* . People were a little concerned about the impending fireball. IT WASNT AN OVERFLOWING DRIBBLE. IT WAS A GUSHER !
« Reply #29 on: October 15, 2015, 08:58:21 PM »
I wasn't really attempting a pornographic refueling story.
Happy coincidence.   Smiley
