November 23, 2025, 01:59:00 AM *
Author Topic: Trunk?  (Read 719 times)
Chiefy
Sarasota, Florida
« on: October 24, 2015, 01:32:38 PM »
Does anyone know of a locking trunk that will attach directly to the luggage rack, and be able to be put on and off easily?  I'm seeing some that you mount a bracket to the luggage rack, then the trunk will go on and off the bracket easy.  But I was hoping to find a trunk that would come off easy and leave nothing behind.
Does such an animal exist?
« Reply #1 on: October 24, 2015, 03:01:57 PM »
Look up Super Valk. But then again I could be not right!  Roll Eyes Take THAT however ya wants ta.  2funny RIDE SAFE.
« Reply #2 on: October 24, 2015, 03:10:48 PM »
The reason folks use a wider/longer bracket plate is to adequately support a decent size trunk.  With the sissy bar in place, there is not much room on a std luggage rack to fit or support a medium to large trunk.  You could probably find something to go right on the rack alone, but it will not be very large, and not much will go into it.  It seems to me the best/largest storage on sissy bar/luggage racks are those tall backpacks that slide over the sissy.  They don't lock, but as soon as you get to your destination, you just lift it off and put it in the room.
Now if you're not 2-up, and remove the back seat and sissy, then a great big trunk would sit right on the rear fender.... but you'd still probably need to make a mount plate.
« Last Edit: October 24, 2015, 03:14:19 PM by Jess from VA » Logged
PAVALKER
Pittsburgh, Pa
« Reply #3 on: October 24, 2015, 03:49:00 PM »
Yep, no trunk specifically made for the rack with the sissy bar on.  Modifying any trunk to fit on the rack alone would be simple enough I would imagine.  But.... I think Jess gave you the best advise to get a tall bag or another bag of your choice to slip over the back rest or secure to the rest and rack.  Much more room for removable luggage for a trip and you can get the size bag that suits your needs.  If you are set on a trunk, there are options out there, not all that roomy I think.  And if you liked the Valkyire Interstate trunk, you could get one of those and set it up like a Super Valk.... but those are still a bit pricey.  Google Motorcycle Luggage.....
John
« Reply #4 on: October 24, 2015, 04:07:59 PM »
Several options here.
http://www.valkyrieforum.com/bbs/index.php?topic=63822.0
Promagnaman
North Dakota
« Reply #5 on: October 24, 2015, 07:27:21 PM »
Leatherlyke makes a couple tourpacks that match their bags perfectly. Had the set up on my Magna.
http://www.leatherlyke.com/catalog/6
« Reply #6 on: October 25, 2015, 04:25:48 AM »
I got an extra luggage rack, and mounted the bracket to the extra rack - then
change racks when you want the trunk on there...
Chiefy
Sarasota, Florida
« Reply #7 on: October 25, 2015, 05:54:15 AM »
Interesting idea.  But it will never work for me.  It's not complicated enough (I'm an engineer.)   cooldude
rocketray
« Reply #8 on: October 26, 2015, 12:07:02 PM »
I have  a GIVI trunk that has worked very well---expensive though--I got it with a pre-painted lid that perfectly matches the 2002 blue w/white stripe standard valkyrie
BudMan
"Two's in."
Tecumseh OK
« Reply #9 on: October 27, 2015, 05:32:28 AM »
I might be interested in that approach as well. Do you have any pictures, Mike?
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
Flat6Valk
Blacklick, Ohio
« Reply #10 on: October 27, 2015, 05:41:36 AM »
givi trunk is my add on preference.  I use it most of the time.  when I do not use it I spend 2 seconds to remove it.  4 seconds to put it back on when I want.
the attachment is black plastic but you could get it chromed to mask the black effect.
Greg
FlatValk
G-Man
White Plains, NY
« Reply #11 on: October 27, 2015, 07:02:23 AM »
The stock rack is too short for a trunk.  I tried.  I wound up using a piece of black shelving (no need for painting and the bike and trunk are black).  Mounted the board to the rack with 1/2" bolts and 2 pieces of angle iron, then mounted the the trunk to the board with 1/2" bolts.  Trunk doubled as a backrest and she didn't complain once!
« Reply #12 on: October 27, 2015, 07:10:24 AM »
Well... not close up...
I'm solo most of the time, so the bracket isn't even needed, just affix the mounting
plate right to the rack... pardon the on-the-road fork seal change  Wink ...
When two-up, just the rack won't do, as G-Man said. I made a simple bracket
out of wood that holds the mounting plate far enough back so that the passenger
seat and sissy bar can be mounted.
None of it looks good, but 99% of the time I don't care  Wink
G-Man
White Plains, NY
« Reply #13 on: October 27, 2015, 07:15:33 AM »
Looks very similar to what I did.
Chippy01
Gorey, Ireland
« Reply #14 on: October 27, 2015, 12:06:37 PM »
I got around the trunk mounting problem by extending the rack's 'legs' by using stainless steel plates, to move the rack up about 4'' and back about 2''. This was to facilitate opening the trunk while still on the bike to put our helmets in while parked up.
I should have made the brackets an extra half inch longer, as the lid binds a bit on the passenger backrest if opened too much, but it does open enough to get the helmets in so I left it as it is.
First trial using aluminium test pieces
After some shaping
Close up
'98 GL1500C Standard Valkyrie
'88 VF750C SuperMagna
'89 GL1500 GoldWing
