November 22, 2025, 06:32:53 PM *
Author Topic: My First Job with my Truck and Tractor.......  (Read 842 times)
Stanley Steamer
Athens, GA
« on: November 21, 2015, 03:24:46 PM »
Still making a few tweaks here and there, got a few more small things to do, but I decided to test the truck out by hauling some mulch to use for the driveway into the In-laws back yard where I'll be parking the trailer.....
Here's 4 cubic yards on the truck.....the mesh tarp with bungee cords worked great to keep the mulch from blowing off the truck...made a tight seal all the way around the bed.....and I couldn't really tell there was a load on the truck...that 350 V8 with a 4 barrel will .....suck some gas!..... Cheesy Cheesy........
It only took about 15 mins to use the tractor to spread out this pile roughly.....and about ten mins of hand raking to knock off the high spots....about 30 mins max.....
This is about 450ish square feet at 2-3" deep......
Here's just the BX25D on the trailer with my DOT chains and ratchet binders...
And the truck and trailer ........
« Last Edit: November 21, 2015, 05:20:34 PM by Stanley Steamer » Logged
Stanley "Steamer"
"Ride Hard or Stay Home"
« Reply #1 on: November 21, 2015, 03:45:00 PM »
Nice !
« Reply #2 on: November 21, 2015, 03:46:29 PM »
I hope this will be the start of many more for you, good job!
« Reply #3 on: November 21, 2015, 03:51:35 PM »
Be thankful the truck doesn't have the 455 4 barrel carb - you can watch the fuel guage go down  when using it for all it's worth (mom and dad had a '72 Olds Custom Cruiser S/W  that we used to pull a 24 foot travel trailer (about 4000-500 pounds) that had that monster. Could pass everything except a gas station....
« Reply #4 on: November 21, 2015, 04:01:14 PM »
Looking Good. I`m still thinking you need that Cousin Cletus pic on the doors though.  cooldude
hal47
INDIANA
« Reply #5 on: November 21, 2015, 04:58:57 PM »
Looks like your on your way,wishing you all the work you can handle.
« Reply #6 on: November 21, 2015, 06:12:19 PM »
You're going to have to change your handle to "digger".
Stanley Steamer
Athens, GA
« Reply #7 on: November 21, 2015, 06:18:04 PM »
Uhhhhh, I haven't even taken the lock pins out of the backhoe boom yet...not sure when I'll break that in...... Undecided
Stanley "Steamer"
« Reply #8 on: November 21, 2015, 07:57:58 PM »
yah,  gas mileage sucks with any V8 when pulling a load.
I normally get 17 avg mpg unloaded normal driving my 1/2 ton V8 truck, but I recently pulled my 4000 lb. loaded up enclosed trailer and got 13.8 avg mpg.   I guess not too bad??  Roll Eyes
Alpha Dog
Arcanum, OH
« Reply #9 on: November 21, 2015, 09:00:54 PM »
That's a nice set up Mr. Steamer.  You are in business with out a huge investment making payback time and potential to expand much easier.  Hard work is all it takes and I am sure you are more than up for the task.  Best of Luck
Chuck
jimmytee
Elizabethtown,KY
« Reply #10 on: November 22, 2015, 04:10:01 AM »
 cooldude  At least for now, the gas prices are not too bad.
« Reply #11 on: November 22, 2015, 05:11:41 AM »
When it's time to expand, get a duramax diesel to haul all that stuff.  Congrats on the bidness startup and I agree, "Cousin Cletus's landscaping N'at" on the side of that truck would be awesome!
« Last Edit: November 22, 2015, 06:36:23 AM by Skinhead » Logged
Mr Whiskey
« Reply #12 on: November 22, 2015, 05:14:48 AM »
Chuck
Ditto cooldude
(Couldn't have said it any better myself!)
Peace, Whiskey.
da prez
Wilmot Wi
« Reply #13 on: November 22, 2015, 08:17:32 AM »
  Stanley , go for it and best of luck. Work it as a side business (if I remember ,you still have your regular job)until you are doing enough hours to support yourself. I started my own business and ended working over a hundred hours a week before I finally hired help. I quit my other job in about three weeks as I could not keep up.
  FYI , I do not know your state law , but in Illinois , a back hoe must have a separate chain on it even if it is chained to itself on the machine. It must be a three point tie-down. DOT tickets are expensive.  Please just check so you do not have to support a donut eater. ( no offence to our LEO's)
                               da prez
« Reply #14 on: November 22, 2015, 08:33:37 AM »
good point on DOT rules/regs, learn them.
In WI I did not know anything over 3000lbs. total weight inside and trailer combined has to have a trailer brake controller hooked up to tow vehicle.  If ever stopped and asked to see inside my trailer,  they can surely see 1600lbs. inside and 2500lb. trailer is surely over 3000 lbs.   The trailer dealer said tickets like that can be expensive.  When I registered,  I ONLY paid  yearly registration fee for 4500lbs. combined weight rating, but could have done 6000lbs. for another few bucks per year, technically trailer can hold combined weight with trailer of 7700lbs..  I doubt the law enforcement would require me to go to a weigh station or check that closely though just in case I attempt also to squeeze my Valk inside the trailer making it close to 5000 lbs. total weight.   But, you never know especially if involved in an accident??
Spirited-6
Nicholasville, Ky.
« Reply #15 on: November 22, 2015, 10:16:34 AM »
Stanley, you can bet that no one will wish you the best more than I ! Grab it by the horns !  cooldude
Spirited-6
Stanley Steamer
Athens, GA
« Reply #16 on: November 22, 2015, 04:47:12 PM »
I finally connected the truck and trailer today and loaded the backhoe up on it to test the trailer brakes...the truck had an OLD Tekonsha brake controller in it, and I was taking it for granted that it was going to work right....wrong.....I had found some instructions for one that looked pretty close to the same as the one I have....I tried it all the ways I could, no go....I had to cut the hot wire to it and put some wire nuts on the ends to let the trailer brakes release(don't tell Randy I did that.... Cheesy Cheesy).....
The truck ignition switch has been kind of touchy too..I think I'm going to need a new ignition switch...guess it's "old" in 31 truck years speak....replacement ones are cheap, but I'm going to have to get Randy to do that for me.....I don't have a steering wheel puller.....once I got it cranked though, I took it for a short trip from my In-laws to my house to see how it would pull...no problem.....you can tell there's some weight back there, but it wasn't really straining it too much......I unloaded the backhoe and dug up a small stump from an old juniper.....didn't even scratch the paint.... Cheesy....wish I had of had this a few years ago when I dug all the previous shrubs out by hand..... 2funny.....I figure that one little stump cost me almost ~$30,000 to dig out..... Shocked Shocked Cheesy Cheesy cooldude cooldude
Stanley "Steamer"
« Reply #17 on: November 22, 2015, 05:08:56 PM »
I just bought a new Tekonsha Primus IQ brake controller with wiring harness for 95 bucks on amazon.com
It is a proportional brake controller much like the more expensive ones without the added price, does the job.   Same one at trailer dealer wanted 117 bucks for it without the extra wiring harness.
I could have used that backhoe to dig up my huge/old lilac bush taking me 2 hours to dig with shovel and chop up with an axe the roots and all the way around the roots (3 foot wide hole by 1 foot deep).  Something you could have done within 30 minutes easily.
Spread the word or advertise local in the paper might get you a few side jobs.  Even most local grocery stores have a board on the wall to advertise for free.   You get 3-4 jobs done,  word of mouth will spread and you will become very busy eventually.
Stanley Steamer
Athens, GA
« Reply #18 on: November 22, 2015, 05:19:07 PM »
Yeah......I looked at this one too......need to get one made in THIS decade for sure....
http://www.amazon.com/Tekonsha-90160-Primus-Electronic-Control/dp/B001P11SCM/ref=sr_1_3?ie=UTF8&qid=1448242918&sr=8-3&keywords=tekonsha
I have a feeling I'm going to be very busy come this Spring...got a few co-workers who already are wanting some stuff done... cooldude
« Last Edit: November 22, 2015, 05:20:45 PM by Stanley Steamer » Logged
Stanley "Steamer"
« Reply #19 on: November 22, 2015, 05:38:18 PM »
yep, that is the one.  The box doesn't say it, but inside this primus IQ box is about 9-10" of wiring with the plug in ONLY to the unit in back with the 4-5 wires coming out to wire into to your truck wiring.  85 bucks is a good deal, I paid 10 bucks more to get the plug-n-play wiring harness for my 1/2 ton truck.  Took me 1 hour to do, but 20 minutes of actual install time once I figured out how to route the wires and where to place the unit.    My optional plugnplay wiring harness was just barely long enough at 32" to get the wiring from left kick panel, up under the steering wheel lower dash with 3 cable ties and right above my right gas pedal on lower part of the dash.    The unit shuts off after 15 or so minutes of non-use so as to not run down your battery or I could simply just unplug it from the back of the unit when not in use as well.
The trailer place said this unit by tekonsha is what they sell and  recommend does pretty much all the more expensive ones over 100 bucks will do.    Product does say made in Mexico though but at least not made in China.  With a name like Tekonsha,  you'd think Japan, guess not?
« Reply #20 on: November 22, 2015, 06:48:51 PM »
Tekonsha sounds Native American to me.
