November 22, 2025, 02:58:05 PM *
Author Topic: Wood router bit  (Read 680 times)
Cotton Mouth
VRCC # 28922 Southern Nevada
« on: December 08, 2015, 08:49:13 PM »
Hi, Does anybody know where I can buy a wood router bit with this profile, or very close to this profile? Or does somebody have one to sell me or that I can borrow? I have a 3' and 6' section of baseboard I need to make to match our current stuff.  Wood is 3/4" thick. Thank you
pics in post below
« Last Edit: December 09, 2015, 08:42:22 PM by Cotton Mouth » Logged
1999 I/S SOLD BUT NOT FORGOTTEN Jan 2015
1998 HD Road King Classic
« Reply #1 on: December 09, 2015, 02:50:55 AM »
Your picture doesn't show for me.
You could try a quality wood shop, they might already have the profile you want and will run off a small amount for you.
Also, some profiles are actually a combination of two or more bits.
Good luck.
« Reply #2 on: December 09, 2015, 03:17:21 AM »
Good luck.
Yep.
The pic doesn't come up for me either
If you can't find something close, or, it needs to be perfect, there are companies that could make one for you. I don't any names for you though.
« Last Edit: December 09, 2015, 07:23:28 AM by Patrick » Logged
Ramie
2001 I/S St. Michael MN
« Reply #3 on: December 09, 2015, 04:34:55 AM »
Can't see your pic but try here, if they don't have it I don't know who would.
http://www.rockler.com/
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #4 on: December 09, 2015, 04:42:39 AM »
Timber Woodworking Machinery located just down the road from me, might have something for you.
http://timber-woodworking.com/
Crackerborn
SE Wisconsin
« Reply #5 on: December 09, 2015, 04:52:25 AM »
Your picture is not showing but if it is an older home, sometimes a shop specializing in custom mill runs will have a moulding that the local big box store won't have. Try a search for specialty mouldings in your area, it might be easier and cheaper to buy an eight foot stick than trying to make a piece. I have knives ground for historical reproduction mouldings, but that is a bit pricy for a single stick.
97 Valkyrie Tour
99 Valkyrie Interstate
Flat6Valk
Blacklick, Ohio
« Reply #6 on: December 09, 2015, 06:19:25 AM »
Rocker Woodworking should have it.  White (brand) of router bits would have it also (google them).  Your picture is not showing so I am making a little bit of an assumption.
Greg
Flat6Valk
« Reply #7 on: December 09, 2015, 08:14:36 AM »
I'm pretty sure you can't link to a picture in dropbox to display it here.  Save the pic to photobucket or our Photostash or a similar service, then link to it.
Mn. Norseman
central Mn
« Reply #8 on: December 09, 2015, 10:14:42 PM »
can you use a round over bit and a cove bit and make three passes?
« Reply #9 on: December 10, 2015, 03:15:36 AM »
My thoughts too.
Crackerborn
SE Wisconsin
« Reply #10 on: December 10, 2015, 05:04:08 AM »
That looks like window stool not base. Try MLCS.com for a profile. Two passes and two bits likely unless you have a router table to run bullnose.
97 Valkyrie Tour
« Reply #11 on: December 10, 2015, 09:11:10 AM »
Or maybe a round-over and an ogee?
TallRider
Cape Coral, Fla
« Reply #12 on: December 13, 2015, 06:35:32 AM »
You may need to use two different radius bits for that one and a router table. A round over bit and a radius or make 3 cuts with two radius bits. Easy enough to do. Good luck
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
« Reply #13 on: December 13, 2015, 10:05:41 AM »
Thank you to each of you for the tips and tricks. cooldude I'll forward all of them to my Irish carpenter buddy, as I don't understand any of it, but he will.
Yep, your friend will know. Its not hard.
There's usually more than one way to milk a cow.
