November 22, 2025, 11:57:01 AM
autocad 2015 question
Topic: autocad 2015 question (Read 521 times)
Jeff K
December 18, 2015, 08:19:45 PM »
I'm new to this version and this hasn't happened to me before on previous versions.
I have phantom lines they come and go based on zoom, but they are driving me batty.
Any biker autocad help?
Re: autocad 2015 question
December 18, 2015, 08:51:02 PM »
This maybe? (I haven't used Autocad since the late 1980's, this is just something I googled up)
type in “3DCONFIG” and turn off HARDWARE ACCELERATION
http://www.appliedtg.com/techblog/index.php/2014/04/14/2015-autocad-lt-phantom-lines-appearing-in-dwg/
Jeff K
December 18, 2015, 09:03:47 PM »
It's not the mouse trails that is a problem with graphics cards. If I choose a different "visual style control" they go away, but then some of my lines are not visible.
Crackerborn
SE Wisconsin
December 19, 2015, 04:51:15 AM »
I don't use Autocad much, but it sounds like your graphics card doesn't have enough memory (common on laptops). Try changing the rendering settings.
97 Valkyrie Tour
99 Valkyrie Interstate
Jeff K
December 19, 2015, 05:02:04 AM »
But... If I save the drawing, close it, reopen it, they are still there. It's not like cursor trails, it appears it is in the drawing. Never had that problem with 2010. Maybe it's a graphics problem, but it doesn't seem like it to me.
Jess Tolbirt
White Bluff, Tn.
December 19, 2015, 05:40:20 AM »
use solid works
Jeff K
Reply #6 on:
December 19, 2015, 05:12:24 PM »
Quote from: Jess Tolbirt on December 19, 2015, 05:40:20 AM
use solid works
I tried... old dog, new trick... I can't fumble through it to make anything
dinosnake
Reply #7 on:
December 19, 2015, 10:56:25 PM »
Ya, blame your video card first. Any update in CAD software brings higher demands in video hardware. Check the specs on the version you are using and compare them to your hardware's abilities.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-AutoCAD.html
Update your video drivers pronto and start from there. If you are using Intel integrated graphics...sorry, almost all the new CAD software demands better; turn off hardware acceleration.
Last Edit: December 19, 2015, 11:00:21 PM by dinosnake
=> InZane XXV
