March 15, 2026, 08:59:45 PM *
Author Topic: Need advice on installing Audiovox CC w/out vac cannister  (Read 2022 times)
FLAVALK
Winter Springs, Florida
« on: September 14, 2009, 10:06:24 AM »
I have researched archives but can't find the exact answer to my question. I understand that a vacuum cannister is not required with the Audiovox cruise control. My question is, what is the fewest number of intake runner leads (hose & check valves) required to cause the cruise control to function properly? Seems that I recall one member posting that he only used two.
Thanks in advance
Novavalker
99 Interstate/2017 Goldwing
« Reply #1 on: September 14, 2009, 12:25:49 PM »
I believe "Baloo" installed his Audiovox without a vac canister.
FLAVALK
« Reply #2 on: September 14, 2009, 12:56:33 PM »
OK, I finally found what I was looking for. It seems that if I hook hoses/check valves to at least two carbs (intakes) and then "T" them together, I should be good to go.
Now to find another place to mount the Servo other than behind the battery. I really dont want to butcher the tool box area. Mr Bubbles mentioned that he mounted his over the swing arm. Since I won't need a vac cannister, has anyone ever tried mounting the servo on top of the engine and routing the cable around in a big (multiple?) loop(s)?
« Reply #3 on: September 14, 2009, 06:50:33 PM »
Steve, one of the first members to mount one put his servo on the left side sorta under the petcock control I believe. I can't find the picture just now, but know that's what he did. Appearance was the main reason most will mount it behind the battery...as I did.
humshark
Spring Hill Tennessee
« Reply #4 on: September 14, 2009, 07:47:42 PM »
I'm assuming that this isn't an interstate.  Otherwise, I'm seeing more and more installations where the actuator is up front in the fairing.  I'll move mine from behind the battery in a week or so to the front location.
99 Interstate
05 FJR
97 Vulcan '88' Hacked
PapaHotel
« Reply #5 on: September 14, 2009, 08:34:13 PM »
When I had a Tourer, I mounted it behind the ignition key, under the petcock area. Didn't look too bad ( I could have put a cover on the Ignition end to clean it up) This allowed access to the seat key and also kept it away from the dirt and moisture of the swingarm area.
Printer Mike
Eatonton, Georgia
« Reply #6 on: September 14, 2009, 10:16:21 PM »
I believe there is a Audiovox model that does not require any vacuum to operate.
Never give up!
Mr.BubblesVRCCDS0008
« Reply #7 on: September 15, 2009, 01:43:20 AM »
I put my servo in the back behind the battery. The vac. res is what I mounted on the bottom of the swingarm. I think there is room to mount the servo there but it would be exsposed to all the elements. Behind the battery is the most concealled place to put it on a tourer or standard. On and I/S under the fairing is a perfect place for it.
PapaHotel
« Reply #8 on: September 15, 2009, 06:46:14 PM »
Make your Vacuum reservoir out of PVC parts. Just get a small section of 2' pipe and two end caps. cut to length, install a vacuum port to hook up the hose, glue it up and you can figure a way to clamp it down. This system is totally impervious to moisture.
 I also put a one way vacuum stop in the line to keep more vacuum in the canister for hills. put a tee in the line, the valve goes between the t and the engine, the T section goes to the servo
MP
North Dakota
« Reply #9 on: September 16, 2009, 05:18:40 AM »
No need for vac cannister.  Just hook up to two or more vac ports.  Be sure to use a little one way valve on EACH line coming off the carb.
MP
"Ridin' with Cycho"
