May 02, 2026, 12:50:55 AM *
Author Topic: Cobra Pipes dont align  (Read 2416 times)
22Dasher
Shelbyville, TN
« on: September 14, 2009, 11:49:47 PM »
I just got a new set of cobra slash cuts in today and tried installing them actually took them apart and attached to the engine first and the pipe with the nuts welded to will not align up to mount on bike and the other pipe to bolt them together and to the bike.
 The pipe that has the thru hole will align to the bike mounting bracket it's the other pipe thats not aligning correctly to bolt the 2 together. What can be done short of calling cobra and complaining?
 I took mount off bike and bolted all together and tried to install to engine and still no luck the bends or the bracket is not located properly.
James
junior
new hampshire
« Reply #1 on: September 15, 2009, 01:22:09 AM »
you got them on the right sides?
matt
Derry New Hampshire
« Reply #2 on: September 15, 2009, 06:06:19 AM »
I had same problem I had to make holes in bracket on bike a little bigger and got a longer bolt and washer to make it work
aviaator
No. Virginia
« Reply #3 on: September 15, 2009, 06:30:27 AM »
Nice QC by Cobra.  And what do those pipes cost??  Shocked
'97 Tourer
'00 I/S
VRCC 27632
Southern Cruisers Manassas, VA Chapter
Momz
ABATE, AMA, & MRF rep.
« Reply #4 on: September 15, 2009, 08:45:42 AM »
I had the same problem. Found that if you keep all the fasteners loose. You then be able to wiggle the three pies into alignment then hand tighten the rear pipe/footpeg mounts, and then move on to tightening and toqureing the head pipes then tighten the pipes, torque the pipe/peg mounts then fully torque the pipes together.
Those pipes are a pain in the posterior!
ALWAYS QUESTION AUTHORITY!
22Dasher
Shelbyville, TN
« Reply #5 on: September 15, 2009, 09:13:01 AM »
4 hrs later and cobras are installed...
Now I have another question..
Where exactly do the heat shields go?  Could someone post a photo of where ea heat shield is installed at on there cobras 6x6's?
James
B
Capital Area - Michigan
« Reply #6 on: September 15, 2009, 01:34:49 PM »
James
I had to use smaller bolts on one side and a little engineering on the other.  When I bought the bike, the guy didn't have the pipes supported because the brackets were offset.
Printer Mike
Eatonton, Georgia
« Reply #7 on: September 15, 2009, 08:40:45 PM »
Now I have a good idea of why one of the bolts on mine is too loose and jams either way it's turned. crazy2
One cool thing though...No rattling because of the Valk's smooth engine! cooldude
Never give up!
Sonny
Holt, Mo.
« Reply #8 on: September 18, 2009, 08:27:12 AM »
You can go to last uploads and see some pictures of a Yellow 99 with Cobra's with heat shields installed.  I had the same mounting problems you did during installation.  I have had them on and off a few times since purchased and have the same mounting issues each time.
What a great day, lets ride!
1999 Valkyrie Standard
2003 VTX, 1800C
