November 21, 2025, 08:26:32 PM *
Author Topic: POR PaintOverRust experience?  (Read 1384 times)
« on: March 13, 2016, 07:27:17 AM »
Any one have any experience with this paint?  It claims to stop and coat rust.
http://www.por15.com/
signart
Crossville, Tennessee
« Reply #1 on: March 13, 2016, 08:35:22 AM »
Good stuff. Used it for years, follow instructions.
Then follow my advice. Don't lay on your back while painting the frame on your old truck and let it drip on your cheek. If you don't realize it in time, a piece of your cheek comes off with the paint!
« Reply #2 on: March 13, 2016, 12:29:18 PM »
Really good stuff,
 I used it on many projects on rusted cars and trucks. Two cases rocker panel on a 91 GMC 1500 truck was in good condition except the drivers rocker panel was rusting out with large hole in it. Wanted to stop further rusting so just coated it with that stuff. Its been a couple of years now and no further rust. Since it was enclosed I couldn't really prep the surface so I just took a pump sprayer and coated the inside and rusted edges. Didnt expect much but it has held good and looks like the day I put it on.
 I have used it on sunroofs to stop rust, and on the air intake box in front of the windshield. The body shop used it on the whole underside of a Porsche 356 and it came out great.
Comes in clear and colors once dried its extremely hard cannot scratch it with a nail or even a razor blade. Once you open the can be gentle at putting the top back on or maybe put the remainder in a very well sealed container. The top once on after use doesn't like to come off easily again and I wound up destroying the can after opening and closing. One can didn't seal properly and the paint hardened.
  Surface doesn't have to be free of rust just paint over it as long as its clean of grease and anything that would stop it from sticking. Make sure you only coat what you want because you are not getting it off with any solvent and more than likely will take a grinder. Does what it says it will do and seals very well. Once dried the black dries to a nice gloss
« Last Edit: March 13, 2016, 12:32:56 PM by Robert » Logged
« Reply #3 on: March 13, 2016, 02:12:39 PM »
Cool  coolsmiley
Thanks for the response guys cooldude cooldude
PAVALKER
Pittsburgh, Pa
« Reply #4 on: March 13, 2016, 02:14:47 PM »
As others have said...good stuff.  Wear goggles and protective clothing during use.  Knock off loose stuff and remove any grease or oil and have at it.
I have found that it is affected by UV/Sun, so give it a good clear or top coat.
John
J.Mencalice
« Reply #5 on: March 13, 2016, 04:06:55 PM »
Rust Never Sleeps-Neil Young.
