Bonzo
« on: May 03, 2016, 07:41:13 AM » |
On my '97 standard always was a Dark Sider running coopers zeons. Needing tires on my 98 tourer , any feed back on the Austones? where they are available and size?
Woops, I'm sorry.
« Reply #1 on: May 03, 2016, 07:51:33 AM » |
Lots of different vendors out there. This is just one I found. I've been running the "taxi" tire for about 10K miles. Love it!! http://www.austonetaxityre.co.uk/
VRCC# 29981 Learning the majority of life's lessons the hard way.
« Reply #2 on: May 03, 2016, 08:20:54 AM » |
 Two thumbs up!
Bonzo
« Reply #3 on: May 03, 2016, 08:22:49 AM » |
175r16?
Woops, I'm sorry.
« Reply #4 on: May 03, 2016, 08:29:10 AM » |
https://www.universaltire.com/175r16-austone-taxi-black.htmlIt's a tall sucker, handles like a dream and wears long. Use good shocks, 13" recommended especially if doing any two up riding. I have heard rumors of folks tearing out all their rear wiring, I think I heard Hotglue had this happen to him.
Bonzo
« Reply #5 on: May 03, 2016, 08:34:33 AM » |
I have 13" 444 and I ain't no light weight. calling and ordering the tire now. The profile looks as curved as a MC tire.
Woops, I'm sorry.
PAVALKER
Pittsburgh, Pa
« Reply #6 on: May 03, 2016, 08:54:51 AM » |
where did you order from? Universal Tire? I have one and very happy with it.
John
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #7 on: May 03, 2016, 09:16:53 AM » |
Seeing opinions are asked for, I am not a fan. I had two Interstates at the same time and was able to switch bikes back and forth for quite a while and instantly noticed the difference. The Pro is the slightly lower RPM, what I did not like was the rear slightly higher than the front due to the taller tire however that was small stuff, what I felt was the Interstate with taxi tire was sucked into ruts something terrible and the Michelin primacy pilot CT did everything better to the point it is now on my Tourer. I know personally many people who like the AT, it is just not for me.
« Reply #8 on: May 03, 2016, 09:29:04 AM » |
Bonzo keep that Austone at 42psi minimum. I run 44 two up. There is a shimmy I have experienced (high speed) at or below 40, it's nonexistent at or above 42. As far as following ruts, it's a heckuva lot better than the Falken Ziex I have on the IS I purchased last fall. That thing is getting replaced with an Austone ASAP! YMMV.
« Last Edit: May 03, 2016, 09:31:50 AM by Valkorado »
Bonzo
« Reply #9 on: May 03, 2016, 09:31:01 AM » |
where did you order from? Universal Tire? I have one and very happy with it. Yes I did, They are in Hershey PA pretty close to me in Chester NY should be here by tomorrow
Woops, I'm sorry.
« Reply #10 on: May 03, 2016, 10:07:00 AM » |
Like the A T T I have on my I/S.  Even though it sits somewhat taller I can still flat foot it.  IF I happen to wear this one out I WILL purchase another.  RIDE SAFE.
Mr Whiskey
« Reply #11 on: May 03, 2016, 04:59:11 PM » |
Peace, Whiskey.
« Reply #12 on: May 03, 2016, 05:08:56 PM » |
Just getting back from running the hell out of mine! I saw this posted quite awhile back, when I was just breaking my first Austone in (I'm on my second, and ordered a third for Bertha -- about 35k so far). Anyway, I got paranoid and emaild Dubsvalk. He replied telling me he does not think it was the taxi tire that was at fault. Said he thought it was a great tire.
Big Rig
« Reply #13 on: May 03, 2016, 07:10:10 PM » |
Love mine. Agree with the 44 psi. Put mine on last year and then road us129 the dragon. Handled perfectly. Others (hd) riders were surprised I ran tbe twisties with zero worries. You will love it.
Bonzo
« Reply #14 on: May 04, 2016, 04:07:33 PM » |
I called and ordered the tire yesterday,it was leaning against my door when I got home!! It seems a bit thinner than the Coopers I ran. Any thoughts on "The Nut Cage Mod" (Mrs Bonzo loves that term)
Woops, I'm sorry.
« Reply #15 on: May 04, 2016, 04:17:55 PM » |
I'll say this, I did not need the "Nut Cage Mod" for me to run the Austone Taxi Tire (plenty of room there) and no harm has resulted from that. Yes, the wife is also still happy. Well, as happy as she ever was................
« Last Edit: May 04, 2016, 05:40:50 PM by Rams »
hukmut
« Reply #16 on: May 04, 2016, 04:24:19 PM » |
I, at 220+ lbs, and my gal, 125 lbs, running stock shocks set at 3, have never rubbed the tire, an Austone taxi tire, which is at 42 psi. Been to 100 mph for miles, 2up, with no shakes. Did not remove nut cages, however there IS a nut driving. BTW, I put that tire on myself. Oh, and another BTW, be sure to replace that valve stem with a new metal one. Lesson learned...
Ride safe...
Bonzo
« Reply #17 on: May 04, 2016, 04:33:45 PM » |
Thank you! I got you by a few I'm pushing 350, the Mrs is about 125 also. I have progressive 444, I might crank them up a bit. I might do the nut cage anyway, I did it on my '97. BTW all thanks for the input!
Woops, I'm sorry.
« Reply #18 on: May 05, 2016, 08:04:36 PM » |
I was running the ATT at 36#, was pretty happy with it. Until I started towing the Timeout popup camper which is heavier than most trailers.  All of this tent is inside the trailer, and quite a lot more equipment, too.  I was getting a wobble at 70 on I-25, which is rotomilled. Did not get the wobble at 70 on non-milled pavement. OK so took a spin today sans the trailer but with the pressure boosted 7# to 43. WOW what a difference! The bike rides like it's on rails! Feels very solid, planted, good footing. Like a completely different ride! Haven't tried the trailer yet, but expect no more wobble.
« Reply #19 on: May 06, 2016, 05:18:07 AM » |
The Austone max inflation is I believe 50 psi. It needs every bit of 40 to ride well. IM HO.
