November 21, 2025, 08:52:12 AM *
Author Topic: Completely Non Valkyrie: TV Remote Control  (Read 1009 times)
vanagon40
Greenwood, IN
« on: May 20, 2016, 09:18:59 PM »
Right to the point: My TV remote controller does not work in temperatures below about 55° F.
The longer story: I have an old (about 1985-1988) color console RCA TV in my detached garage. I do not have the original remote controller. I use a Panasonic/Quasar tower universal remote controller (from about the same decade--I have numerous VCRs/remote controllers). The Panasonic/Quasar tower universal remote works great in the summer. But not in the winter. When the temperature in my garage drops below about 55° F, the remote does not work at all. I have put in new batteries, so that is not the problem. I swap the remotes with others in the house, and they all work fine in the house (where the temperature is around 70° F). But none work in the garage when it is cold.
Can someone explain why the TV or the remote control does not work in cold temperatures?
J.Mencalice
« Reply #1 on: May 20, 2016, 09:27:59 PM »
Maybe it was made in Mexico. Grin  Maybe it goes on strike for higher temperatures? Grin
Why are you watching television out in a garage in the middle of the winter?  Wife problems?  Too many R rated movies?  You are part Eskimo?  You like your beer naturally refrigerated?  You're a big fan of the Trans Siberian Orchestra?  Please, give us a clue. ???
« Last Edit: May 20, 2016, 10:26:15 PM by Willopad357 » Logged
vanagon40
Greenwood, IN
« Reply #2 on: May 20, 2016, 10:33:48 PM »
. . . . Why are you watching television out in a garage in the middle of the winter?  Wife problems? . . . .
Uh. . . . Man cave?
It's where I work on my Valkyrie?
« Last Edit: May 20, 2016, 10:36:23 PM by vanagon40 » Logged
jimmytee
Elizabethtown,KY
« Reply #3 on: May 21, 2016, 03:26:49 AM »
Your cave needs heat. Problem solved. Cheesy
"1985-1988"  I think you've got your money's worth out of them.  coolsmiley  JS
« Reply #4 on: May 21, 2016, 04:53:57 AM »
No idea why but, I'm happy just to find the remote where I think I left it.........
Maybe some day, someone will come up with a "clapper" type device to make it easier to find the damn remote when my other half decides to put it up.   Probably too much to ask or hope for but, it is, what it is...........
My bet is, you don't have that problem out in your garage.
« Reply #5 on: May 21, 2016, 04:56:46 AM »
Batteries are weak in the cold?
 - put in new warm batteries and see if it works until they
   cool down...
-Mike ?
« Reply #6 on: May 21, 2016, 05:04:42 AM »
The springs to keep contact with the batteries can change tension when cold.
A bad or poorly soldered electronic connection will loose contact when cold.
Sometimes a bad electronic component will not work when cold.
The new batteries are not supposed to leak but I have seen them leak to the point of almost destroying the piece of electronic equipment they were in. Acid on the contacts or dirty battery contacts can also cause this.
Use a hair dryer to warm it up and see if you can find the location when it starts to work. That will give you an idea also.
Batteries when cold loose 60 percent of their power so bad contacts can mean alot.
Logitech has a great universal remote called the Harmony that works with almost anything and is pretty intuitive when set up. I know this for sure, my wife actually doesn't have to much problem handling the remote and being able to watch the DVR or a movie or the TV.  Grin
« Last Edit: May 21, 2016, 05:16:29 AM by Robert » Logged
« Reply #7 on: May 21, 2016, 05:52:40 AM »
Probably just age, I no longer work well in cold weather either.   Smiley
« Reply #8 on: May 21, 2016, 06:33:42 AM »
I like the idea of the remote also being a Tazer. If somebody lets it slip down in the couch or they put it where it doesn't belong, automatic 400 volts.  Smiley
« Reply #9 on: May 21, 2016, 06:37:25 AM »
solution:  keep the remote in the house where it is warm until you go out in the garage and use it.
Or, try wrapping the remote in some lined insulation making a nice warm happy home for it in the garage.
Most homes are not below 60 degrees thus normal remote controls don't need to be in below 60 degree temps.
Michvalk
Remus, Mi
« Reply #10 on: May 21, 2016, 07:06:11 AM »
Or, maybe the problem is with the TV, and not the remote cooldude
« Reply #11 on: May 21, 2016, 08:01:42 AM »
 2funny 2funny 2funny 2funny Now that was funny
« Reply #12 on: May 23, 2016, 02:53:14 AM »
My dad had vast experience with remotes... Back in the 50s, when we were probably the first family in our neighborhood to have one, dad would feel like doing a little 'surfing', so he'd... point to our TV and say, "Bruce, see what's on the other channel..." If the 'remote' ever balked or failed to respond promptly or appropriately, mention of his belt was all that was required to solve the problem! Good luck...
Ramie
2001 I/S St. Michael MN
« Reply #13 on: May 23, 2016, 06:32:40 AM »
You need a remote like my dad had, one of his six kids.
« Reply #14 on: May 23, 2016, 06:53:16 AM »
I have a remote for the stereo in my unheated garage. It works fine throughout the year.
