November 21, 2025, 07:09:42 AM *
Author Topic: RAM mounts  (Read 691 times)
baldo
Youbetcha
Cape Cod, MA
« on: May 29, 2016, 01:53:17 PM »
Looking for advice regarding a RAM mount for my cell phone (Samsung Galaxy). What works best on these bikes for attachment? I don't have a separate GPS, hopefully I'll be able to use the Maps function on my cell.....
Joe Hummer
Arnold, MO
« Reply #1 on: May 29, 2016, 02:37:53 PM »
A buddy had this one:  http://www.rammount.com/part/RAM-B-149Z-UN10U  Make sure whichever one you get, that it has a tether.  My buddy lost his phone riding one day.
1999 Valkyrie Interstate
Jack B
Two Rivers Wis
« Reply #2 on: May 29, 2016, 02:47:17 PM »
  That's the one I got works great
Let’s RIDE
Pappy!
Central Florida - Eustis
« Reply #3 on: May 29, 2016, 03:48:58 PM »
I have the same one as well, Baldo. Works well on my iPhone 6 but the larger one, on Lesa's bike,  for her iPhone 6+ sucks! She literally caught the phone in mid-air or it would have been toast. Came loose one more time as well.
Edit - read the post below and this was not the case with Lesa's phone. All the rubber snubbers are still in place.
« Last Edit: May 29, 2016, 03:58:46 PM by Pappy! » Logged
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #4 on: May 29, 2016, 03:57:07 PM »
  I have that one.  While doing a little research on WHY they failed, it turns out that most of them were because the rubber boots came off WITH THE PHONE!   Cry
       SO.   Before using, pull the 4 rubber boots off (which you will find is surprisingly easy).  Put some instant glue inside the boots and stick em back on.  Smiley
    InZane and back last year - lotsa weather and interesting roads both directions no tether and no problems with my iPhone 6  Cool
« Reply #5 on: May 29, 2016, 04:40:46 PM »
Check this out.  The quality is great!   I recently installed one on Big Bertha.  Charging issue resolved, USB charger built in.  And the price can't be beat.
http://www.ebay.com/itm/X-Grip-Universal-Motorcycle-Car-Mount-Holder-Stand-USB-Charger-For-Cellphone-GPS-/222099438483?hash=item33b6287b93:g:4KMAAOSw2GlXICV8
BTW, the mirror mount ball is removable, and the unit can be mounted to any standard RAM ball mount.  So your mounting options aren't limited only to the mirror mounts.  The unit also comes with two extra rubber grips, which you won't ever need if you glue them on as recommended above.
« Last Edit: May 29, 2016, 07:52:56 PM by Valkorado » Logged
baldo
Youbetcha
Cape Cod, MA
« Reply #6 on: May 29, 2016, 07:49:16 PM »
Thanks guys, this is just what I was looking for.......
« Reply #7 on: May 29, 2016, 08:01:45 PM »
I'm using the same one, it works pretty good.
mike72903
« Reply #8 on: May 30, 2016, 09:00:33 AM »
had the exact experience with the larger sized Ram phone mount.  Doing 70 on a freeway, hit a bump, phone went flying fortunately to the shoulder or it would likely been run over.  Took me a while to find and screen was cracked all to heck.  Don't use it anymore without wire ties to keep the arms clamped tight.  On a salient point, I find the phones presence something of a disraction similar to another thread here about car dash complexity.  Find I'm better off just paying attention to what's around me so it normally stays in the screen bag where I can pull over and access it if needed.
msb
Agassiz, BC Canada
« Reply #9 on: May 30, 2016, 10:30:00 AM »
I use the following Kappa holder for my GPS and/or S5. Weather protection and sun visor for good visibility, can easily use phone functions through the plastic screen, and it's got a great handlebar mount with quick release system for the case. Very safe, no worries about the phone popping out.
http://www.kappamoto.com/Various-accessories/Accessories/KS954B
'99 Red  & Black IS
CajunRider
Broussard, LA
« Reply #10 on: May 30, 2016, 01:32:43 PM »
That looks pretty nice.  Where did you pick it up?  I can't seem to find a retailer in the US.
Sent from my Apple IIe
msb
Agassiz, BC Canada
« Reply #11 on: May 30, 2016, 01:46:09 PM »
A local independant service/accessory shop here in BC carries several of their products http://2ndgearmotorcycles.com/ .... a little ways from you  Wink
I just assumed if they're available here they would be in the US as well. I paid about 65.00 CDN for the case and mount last year
'99 Red  & Black IS
jim@98valkyrie.com
Wayne, PA
« Reply #12 on: May 30, 2016, 03:00:24 PM »
I have the same RAM mount but have it attached through the handlebar top plate. So far, with the tethers that come with it, and my Samsung S6 phone has not moved. I have been over some pretty rough road. I also have a USB power port directly below it with a "charging only" cable to keep the most juice flowing and keeping it charged.
mike72903
« Reply #13 on: May 30, 2016, 03:30:19 PM »
thats a very secure looking tether.  My big one didn't come with one, was it a separate item?
jim@98valkyrie.com
Wayne, PA
« Reply #14 on: May 30, 2016, 03:47:33 PM »
My RAM phone mount came with the tether. RAM sells them here:
http://www.rammount.com/part/RAM-HOL-UN7TU
and Amazon also sells them here:
http://www.amazon.com/RAM-Mount-Tether-X-Grip-Holders/dp/B017STCELI
mike72903
« Reply #15 on: May 30, 2016, 04:15:24 PM »
Thanks Jim
