November 21, 2025, 05:12:13 AM *
Author Topic: In the morning  (Read 850 times)
santa
Santa Tom
Ardmore, Alabama
« on: June 09, 2016, 07:37:43 PM »
 All gassed up, new headlight, changed air in the tires (I was told to do that every 10,000 miles) clothes packed have enough for 5 days on one side and 4 on the other side:)  Really looking forward to this trip.
  Santa
« Reply #1 on: June 09, 2016, 08:02:17 PM »
 cooldude angel cooldude
« Reply #2 on: June 09, 2016, 08:21:20 PM »
RDAbull
SW Ohio
« Reply #3 on: June 10, 2016, 06:43:37 AM »
  Santa
I changed the air in my tires.  Put high density summer air in.
See you tonight, gonna be fun.
2015 GoldWing Trike
« Reply #4 on: June 10, 2016, 07:31:54 AM »
  Santa
Seriously?   Did you happen to ask why?
Having met you a couple of times, I surmise you're pulling my leg.   Let go.  Wink
Now, rotating the tires to resolve a flat tire issue is a totally different situation.    Although I've been unsuccessful in my attempts, I'm told if you have a flat and can rotate the flat spot to the top of the tire while in rotation, you can continue to ride and not concern yourself with ruining the tire.   At least that's what I was told.  Wink
da prez
Wilmot Wi
« Reply #5 on: June 10, 2016, 12:48:37 PM »
Use helium, it lightens the load. See you there Tom.
                                        da prez
« Reply #6 on: June 10, 2016, 01:28:56 PM »
Me too, Thom! Looking forward to seeing you again, too... Been too long.
« Reply #7 on: June 10, 2016, 01:34:26 PM »
  Santa
that's the"special" schedule
-change tire air
-top off blinker fluid
-pee on all the sparkplugs
-tighten the loose nut behind the wheel
And lube the clutch cable
Better get her done!
Crackerborn
SE Wisconsin
« Reply #8 on: June 10, 2016, 09:24:01 PM »
Only while the engine is running!
97 Valkyrie Tour
99 Valkyrie Interstate
Hooter
S.W. Michigan
« Reply #9 on: June 11, 2016, 05:23:15 AM »
[/quote
I'm not sure what that does but let me know when you have a minute.    Grin
  Santa
-change tire air
