« on: June 11, 2016, 07:39:20 AM » |
Have been loading, arranging, re-arranging, unloading and various forms of the afore mentioned activities since yesterday. Do I want to take this, will I need that. All the normal stuff is easy but, it's the stuff I don't normally undertake while traveling that is causing me the frustration. Will be changing out a rear dark side tire, what specifically do I need to bring along? Jerry is bringing his tire rack thingy so, that covered. Already loaded is the new tire, air compressor, bike lift and a few tools. Anything specific I'm not covering in the tool arena? Also going to swap out batteries, that's easy. Will be installing a Lithium Ion battery into my baby. Have you seen one of these things? Smaller and lighter than any motorcycle battery I've ever seen. I like the fact that it will lower the CG of the bike, not much but, every little bit helps IMHO. Again, any recommended special tools for that tire change? Not trying to be a pain in the ass to anyone but, I'd rather ask now than be one later on with a Valkyrie I can't ride.
« Last Edit: June 11, 2016, 07:40:51 AM by Rams »
VRCC# 29981 Learning the majority of life's lessons the hard way.
« Reply #2 on: June 11, 2016, 07:43:21 AM » |
Balancing beads ?
Oooo, good catch!!!  Will make a trip to town and see if I can locate some. Thanks. I've been told that they can be re-used, fact or fiction?
« Last Edit: June 11, 2016, 07:45:02 AM by Rams »
« Reply #3 on: June 11, 2016, 08:07:09 AM » |
What size is that rear axle nut?
« Reply #4 on: June 11, 2016, 08:27:37 AM » |
Ill be changing to a lithium battery in the next week or so. Went out earler to srart the bike and the battery is toast. Only a year old and always on a trickle charger. Said it was charged but went to start and I got nothing but a dim headlight.
Steve K (IA)
« Reply #5 on: June 11, 2016, 08:37:45 AM » |
Balancing beads ?
Oooo, good catch!!!  Will make a trip to town and see if I can locate some. Thanks. I've been told that they can be re-used, fact or fiction? Yes, they can be re-used.
 States I Have Ridden In
« Reply #6 on: June 11, 2016, 08:38:58 AM » |
Balancing beads ?
Oooo, good catch!!!  Will make a trip to town and see if I can locate some. Thanks. I've been told that they can be re-used, fact or fiction? Ive been reusing mine. Hardest part is scooping them out of the old tire. I think a turkey baster or something similar would work better than the spoon I've been using. I got beads at Loves Truck Stop. In their tire mounting shop.
« Reply #7 on: June 11, 2016, 08:45:25 AM » |
Balancing beads ?
Oooo, good catch!!!  Will make a trip to town and see if I can locate some. Thanks. I've been told that they can be re-used, fact or fiction? Ive been reusing mine. Hardest part is scooping them out of the old tire. I think a turkey baster or something similar would work better than the spoon I've been using. I got beads at Loves Truck Stop. In their tire mounting shop. A turkey baster huh? Well, that's going to go over like a lead balloon. Is this one of those times when it's better to seek forgiveness than seek permission? Like Sands through the hour glass, so go the Days of Our Lives.
« Reply #8 on: June 11, 2016, 09:09:56 AM » |
For beads try O'Reilly's auto parts. If not in the store the can usually have them by day's end or direct you to another shop that does have them. As for recovering the old beads, don't use a baster or spoon. Just steal one of mama's old panty hose or similar and put it over the intake end of the vacuum cleaner then suck away. The hose catches it all, just make sure you create a little pocket with her nylon hose and be certain it's tight when you press the nozzle in.
« Reply #9 on: June 11, 2016, 09:45:38 AM » |
Excellent tip, I'm going to try that. Keeps me from borrowing that turkey baster..........  Now, what was that question I was asking? Oh yeah....... What size is that rear axle nut?
« Last Edit: June 11, 2016, 09:48:31 AM by Rams »
« Reply #10 on: June 11, 2016, 10:43:54 AM » |
dont forget to use the GOOD valve stems not OEM  BigBF should have the right size tool to remove the axle nut if you change your tire near his station he may let you borrow it
baldo
Youbetcha
Cape Cod, MA
« Reply #11 on: June 11, 2016, 11:06:57 AM » |
dont forget to use the GOOD valve stems not OEM  BigBF should have the right size tool to remove the axle nut if you change your tire near his station he may let you borrow it I was hoping to get my stems changed over for the trip, no such luck. I'll bring them with me and maybe something will work out to change them there.....
« Reply #12 on: June 11, 2016, 11:52:01 AM » |
95% sure it is a 27 mm. I'll throw mine in the bike right now.
EDIT: Yep a 27mm. Mine is an (impact wrench) 27mm socket, in half inch drive.
Front is 22mm.
« Last Edit: June 11, 2016, 12:06:03 PM by Jess from VA »
« Reply #13 on: June 11, 2016, 01:18:44 PM » |
Front is 22mm.
I appreciate that Jess, I'll bring either a breaker bar or an electric impact driver.
« Reply #14 on: June 11, 2016, 01:44:06 PM » |
Front is 22mm.
I appreciate that Jess, I'll bring either a breaker bar or an electric impact driver.  No torque wrench ?
« Reply #15 on: June 11, 2016, 02:01:34 PM » |
Front is 22mm.
I appreciate that Jess, I'll bring either a breaker bar or an electric impact driver.  No torque wrench ? Ah, no.
« Reply #16 on: June 11, 2016, 03:28:20 PM » |
Thinking I have what I need loaded, I commented to my other half that I was anxious to get on the road, drive a while and rest some where enroute. Her reply was less than enthusiastic. I then advised her that encouraging me that way was almost a challenge. We both know how that's going to work out. Just need a short nap first.
« Last Edit: June 11, 2016, 03:48:59 PM by Rams »
Cracker Jack
« Reply #17 on: June 11, 2016, 05:38:13 PM » |
Balancing bead recovery? Just cut a plug out of the tire tread and pour them into a container/bucket before breaking the bead. I use an old butcher knife and cut a square plug. A hole saw would probably work good.
« Reply #18 on: June 11, 2016, 05:57:15 PM » |
Excellent tip, I'm going to try that. Keeps me from borrowing that turkey baster..........  Now, what was that question I was asking? Oh yeah....... What size is that rear axle nut?  turkey basters are cheap and can be used also to suck old gas out of gas tanks as well for small engines. well worth the few bucks to get one and what if mama doesn't have any panty hoses?
