November 20, 2025, 09:39:32 PM *
Author Topic: Valk Info.  (Read 445 times)
dreamaker
Harrison Township, Michigan
« on: August 13, 2016, 04:42:16 AM »
Now a stock, say standard Valk, trigger wheel is 4* advanced correct, what would the total advance be? If you were to put the 6* advanced trigger wheel in, what would the total advanced be?
big poppa pump
San Antonio, TX
« Reply #1 on: August 13, 2016, 04:55:19 AM »
The trigger wheel on a stock Valk has no advance. You swap out the stock trigger wheel for either a 4 or a 6 degree wheel.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #2 on: August 13, 2016, 07:36:27 AM »
The IS ICM is already advanced 2 deg in the mid range (RPM). The 4 deg wheel was designed to be added to an IS. The 6 deg wheel is for the standard/tourer Valk.
dreamaker
« Reply #3 on: August 13, 2016, 09:20:24 AM »
Do we know what the total advances would be in those cases. I am trying to figure something out in my head, and seeing if I misunderstood the while thing.
Highbinder
Bastian/Tazewell,VA.
« Reply #4 on: August 13, 2016, 01:48:02 PM »
The 4 degree trigger wheel will fire the I/S at top dead center and the 6 will fire the standard or tourer at top dead center....your low end torque will increase some and your gas mileage should increase, you will lose on the top end speed..I never heard of anyone putting a 4 in a standard or tourer, but if you did it would probably fire 2 degrees before top dead center..
