November 20, 2025, 09:40:17 AM *
Author Topic: GD hydroloc AGAIN....no damage  (Read 969 times)
baldo
Youbetcha
Cape Cod, MA
« on: October 16, 2016, 03:15:35 PM »
It did it again! This time #6 had a pretty good squirt come out of it. BF changed the cover plate at Inzane and I've got several 1000 miles on it.
This happened about 7 weeks ago, #4. I also had a bad fuel leak (rail o-rings) I changed the o-rings just before Oss's ride and had no problems. Looks like it's a Dan-Marc for me. This is getting old.
« Reply #1 on: October 16, 2016, 03:18:21 PM »
Sorry to hear this happened again but my offer still stands.
« Reply #2 on: October 16, 2016, 03:21:46 PM »
Bob, along with the DanMarc I would think new float valves might be in order. This has been 2 different cylinders that have had issues. A danmarc is excellent insurance, but I'd still like to keep the floats from overflowing.
« Reply #3 on: October 16, 2016, 03:38:16 PM »
https://www.amazon.com/Supply-18-8955-Float-Needle-K3-Keihin/dp/B001KOD732/ref=sr_1_2?ie=UTF8&qid=1476658490&sr=8-2&keywords=valkyrie+float+needles
dinosnake
« Reply #4 on: October 16, 2016, 03:59:36 PM »
Yes, cure the true problem and then apply double-preventative measures, rather than patch the problem.  Remember "Ounce of prevention", and all that, do things right the first time and it'll be done for a long, long time.
« Reply #5 on: October 16, 2016, 04:23:39 PM »
Bob, time to pull the carbs.  Change out the float valves.
Before you get to it, get in the habit of emptying the fuel in the bowls and lines.
« Reply #6 on: October 16, 2016, 04:41:29 PM »
good advice  cooldude
baldo
Youbetcha
Cape Cod, MA
« Reply #7 on: October 16, 2016, 04:50:34 PM »
Thanks Gavin,
I got these when it leaked the first time. I have a set along with the rebuild kit from Redeye. I was hoping to make it to the off-season before I pulled the rack again.... Angry
Only so many hours in the day.....
Bob
baldo
Youbetcha
Cape Cod, MA
« Reply #8 on: October 16, 2016, 04:51:39 PM »
I agree. I was really hoping to make it to snow before I put er down..... Sad Sad Sad
baldo
Youbetcha
Cape Cod, MA
« Reply #9 on: October 16, 2016, 04:52:11 PM »
You betcha.....
baldo
Youbetcha
Cape Cod, MA
« Reply #10 on: October 16, 2016, 04:53:31 PM »
Thanks Robert. I was thinking about that today. Is there any reason, either way, to go with a vac or non-vac Pingel with a Dan-Marc?
« Reply #11 on: October 16, 2016, 04:59:06 PM »
Thanks Gavin,
Bob
I have done 2 hydrolocked valks both with gears broken. These are what I used to replace the stock float needles. Also changed out the petcock with a pingle. I also turn the fuel off and let the bike die before putting her away every time. Just a little extra insurance to make sure the bowls are mostly empty. Of course if the petcock leaks there is no use. I test my petcock weekly to make sure it functions properly.
« Reply #12 on: October 16, 2016, 05:29:16 PM »
I don`t see any reason you cant. Just turn off your petcock 3 miles till home.  cooldude
« Last Edit: October 16, 2016, 06:42:17 PM by meathead » Logged
baldo
Youbetcha
Cape Cod, MA
« Reply #13 on: October 16, 2016, 06:38:56 PM »
Thanks Gavin,
Bob
I think I'll take your advice and check it frequently. I'll run the bowls dry each ride. Also carry the tools needed to pull the spark plugs if I do have a problem. I always bump the starter, so I should be ok as far as that goes. I'll recheck tomorrow to see if it's leaked down again. Also need to address possible oil contamination.....
I'll try to limp it for another 6 weeks or so. What could possibly go wrong?
dinosnake
« Reply #14 on: October 16, 2016, 07:32:59 PM »
You just channeled Murphy and his stupid law into play from the grave.  Wink
baldo
Youbetcha
Cape Cod, MA
« Reply #15 on: October 16, 2016, 08:27:53 PM »
i know... Cry Cry Cry
« Reply #16 on: October 17, 2016, 04:57:31 AM »
Change the floats as well, they are just plastic and can become deformed
Jess Tolbirt
White Bluff, Tn.
« Reply #17 on: October 17, 2016, 05:26:46 AM »
change the floats and needles and seats,, closing the petcoock aint gonna help if they are leaking because one day you will forget to close it and you will be back here saying here i went again..
baldo
Youbetcha
Cape Cod, MA
« Reply #18 on: October 17, 2016, 05:40:02 AM »
I was just going to start shopping. I think I read someone recommended OEM for the goats. If aftermarket is OK, who are the good vendors?
Hooter
S.W. Michigan
« Reply #19 on: October 17, 2016, 05:49:55 AM »
If I was to make a choice it would be OEM. Might be a touch more money but, sometimes the "cheap will become the expensive".  Just an opinion.
« Reply #20 on: October 17, 2016, 06:04:00 AM »
Be careful the distance you choose.  Two miles will usually run mine dry.  Might want to do a little experimentation.
baldo
Youbetcha
Cape Cod, MA
« Reply #21 on: October 17, 2016, 06:09:19 AM »
Lol.....I'm not a fan of the big push.....
« Reply #22 on: October 17, 2016, 06:27:18 AM »
No goats Bob. You are not in Memphis yet.  Grin If memory serves correct, BonS and AtticRat use the K&L. If its good enough for them it's good enough for me.
baldo
Youbetcha
Cape Cod, MA
« Reply #23 on: October 17, 2016, 06:35:42 AM »
DOH!......fat fingered Freddy strikes again....
And I'd be careful, lots of Tennessee representatives around.... angel
« Reply #24 on: October 17, 2016, 06:39:09 AM »
Yeah, but evidently they don't consider Memphis part of the state.  coolsmiley
