Here's another rifle for the safe, in case the Hildabeast wins and these become unobtainium.
American made AR-15, Member's price, annual membership $40 - worth it if you buy outdoor equip online. Kit has everything incl fire control parts, except a stripped lower receiver, rear sight and magazines. Can get the lower online but you need to have it shipped to an FFL if it's finished - I've found them locally at Big R and gun stores for under $100 for black anodized aluminum - might have to ask for a deal, I did. Of course you can also buy 80% lowers, finish them yourself and no NCIS check if you care about not being listed with the govt. Not for me, I LOVE having my own dossier at the NSA - I feel "special". If the Hildabeast gets in, betcha she will try to "close" this "loophole" of avoiding the 4473 with her dictator edicts. IIRC there are NO documented cases of such Modern Sporting Rifles (w/o serial #'s) being used criminally.
You can get free shipping by googling for a coupon for sportsman's guide.
It took me a couple hours for complete assembly including the FCG but it's not my first build. If I had finished an 80% lower myself, it would have taken a couple hours as well. But then I have machining equipment and experience... I've built half a dozen Del-ton kits for friends (not for hire), usually tutoring sometimes supervising and I (we) have been happy with all of them. Only once have we had one part missing in the FCG parts.
specs:
16" chrome moly vanadium with 1:9 twist, threaded muzzle and A2 flash hider
Chambered for 5.56x45mm
Mil.-spec forged 7075 T6 aluminum upper receiver with A3 flat top, M4 feed ramps, right hand eject with ejection port cover, round forward assist
Hard coat anodized. Bore's surface is coated with dry film lube, over the anodized surface
Manganese phosphated, including under front sight base
Taper pins in F-marked front sight base
Mil.-spec phosphated 8620 steel carrier assembly with HPT / MPI tested Carpenter 158 bolt
Heat treated and plated, with chrome-lined carrier interior and carrier key attached with Grade 8 screws
Mid-length handguards with aluminum delta ring and single heat shield
M4 5-position buttstock made of reinforced fiber with mil.-spec sized tube
USA made
From the reviews - I agree with this:
"This is a great kit to finish an AR build with. It came with everything needed to complete a stripped lower. I built it on an Anderson lower receiver and everything went together great. The fitting with the lower was tight with no gaps or looseness to speak of. It came built on an Anchor-Harvey upper receiver, many high level manufacturers use receivers cast by them on their own builds. Comes with forward asst. and dust cover. The gas key and bolt carrier are chrome lined and the bolt is HTP/MPI tested. The hand guards have single heat shields in them and are not too fat like some others. The barrel is a heavy profile barrel 1x9 twist,.. which was a little heavier than I was expected, but will dissipate the heat very well. It has an F-marked front sight. The trigger is mil-spec and about what you would expect. The buffer tube is mil-spec also. All in all this is a very nice kit for someone looking to build a nice mid-length AR and not break the bank.
http://www.sportsmansguide.com/product/index/del-ton-16-mid-length-rifle-kit?a=1784641
