November 20, 2025, 04:27:49 AM *
Author Topic: Hydrolock Avoided  (Read 814 times)
NW roller
Dunkirk MD
« on: October 28, 2016, 03:48:36 PM »
I would just like to thank all you guys who have posted about the dreaded Hydrolock.Yes its real it happened to me. However because of you guys describing the clunking noise I stopped and did not push the starter button again. Pulled spark plugs and shot gas all over my garage. Was not thinking should have done outside.  Found out petcock was bad with a little help from 3Wlonerider on the phone Thanks again Rick. Ordered my new pingle petcock # 1311-ch. Thanks for the that info pulled it up on the forms.  Hope all is going well with everyone it has been a busy time for me and I have not been able to keep in touch with a lot of you. However I am always thinking  and praying for my Valkyrie brothers and Sisters.
Those who won't listen must feel.   David B
« Reply #1 on: October 28, 2016, 04:15:30 PM »
Nor have we forgotten about you.
Glad you didn't push that starter button again.   Should be an interesting time in DC the next few months.   Watch yer Six.
« Reply #2 on: October 28, 2016, 05:37:20 PM »
Well, what about the carbs.  You need to order new floats and needle valves
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: October 28, 2016, 06:27:04 PM »
Did it come down the vacuum line to #6?
So many roads, so little time
VRCC # 5258
NW roller
Dunkirk MD
« Reply #4 on: October 28, 2016, 07:07:40 PM »
Yes
art
Grants Pass,Or
Grants Pass,Or
« Reply #5 on: October 28, 2016, 07:47:04 PM »
Was very lucky a few years ago. After an accident that had my Valk upside down foe a few hours before being impounded due to me being in the hospital I got it home and it sat for a week before I could tend to it.When my son-in-law picked it up the night of the acc. he tried to start it to load onto a trailer. It would not start and he stopped and with help got it loaded and to my home. I tried to start it and it went clunk so I stopped. a few weeks later a friend pulled the plugs and yup hydrolock and gas all over the garage. We were lucky there was no ignition source in the garage or boom. When the valk in on its side for any reason expect hydrolock.
Pete
« Reply #6 on: October 29, 2016, 05:35:45 AM »
Yes
Was there gas leaking from the weep hole on the bottom of the petcock?
NW roller
Dunkirk MD
« Reply #7 on: October 29, 2016, 05:15:05 PM »
Yes
NW roller
Dunkirk MD
« Reply #8 on: October 30, 2016, 01:12:00 AM »
Pete I did not see your question . I thought the answer I typed before it had not gone through. After further inspection it looks like I have both a a bad petcock and a stuck float in #4 cylinder. Pulled tank and with petcock in off position gas is still coming out. I'm going to pull carbs and replace needles. Can anyone give me part # and I would like to put # 38 slow jets in that was recommended. Would like know where to get them
NW roller
Dunkirk MD
« Reply #9 on: October 30, 2016, 04:05:49 AM »
I have never replaced a jet or messed with carburetors. that is why I am asking where to get these things.
3W-lonerider
Shippensburg Pa
« Reply #10 on: October 30, 2016, 04:14:16 AM »
http://www.rockymountainatvmc.com/p/43/53/213/930/-/-/196304/Pro-X-N424-26-Series-Keihin-Pilot-Jet-37.5?0&ref=gan&Attrs:1:AttrList=6102
« Reply #11 on: October 30, 2016, 04:17:50 AM »
https://jetsrus.com/a_jet_kit_street/honda_1500_valkyrie.htm
http://autoplicity.com/8543610-float-needle?gclid=CjwKEAjwtNbABRCsqO7J0_uJxWYSJAAiVo5LrZHWN6j9z7MeMak7U60NaLYYbT6pcgqCgXLptyUDNBoCnAPw_wcB
A couple sources.
You should swap out the intake o-rings while you're at it.
« Reply #12 on: October 30, 2016, 04:22:19 AM »
Do a search on You-tube.  Lots of helpful vids on carb work.
Pete
« Reply #13 on: October 30, 2016, 06:45:42 AM »
Also make sure that the vent passages and hoses are working properly, not stopped up.
They are supposed to vent the gas out instead of into the cylinder when you have a float valve failure.
SpidyJ
Murrells Inlet
« Reply #14 on: October 30, 2016, 10:16:33 AM »
Don't forget  the DanMarc..very easy especially if you're already de-smogged.
1999 Fast Black Interstate
Peace,
johnnywebb
