November 19, 2025, 03:38:59 AM *
Author Topic: Building a Rail Road or need some ties?  (Read 1183 times)
« on: March 21, 2017, 05:11:38 AM »
I know this one is a bit "out there" but, I came across an opportunity that I thought I would share.
First let me say, I am not really interested in transporting these but, would gladly quote you a price though, I do not consider my rig as an ideal option. I am weight limited. Won't put over 6 tons on my trailer. While I would, can and could, I don't view my equipment as the best way to do this. I don't want to put that much weight on my rig and the weight limit would limit me, the most I would load would significantly limit the value of such a venture. I don't think it would be worth it to the person buying these. Regardless, here is what I have an opportunity to get.
800 rail road ties, I presume they are treated for preservation but, I don't know with what. In excellent condition. 10 and 12 foot lengths. Estimated to weigh 400 lbs. each. $3.00 each. They are located on the east coast, near Philly, PA. You now know what I know about them. I don't personally want any nor am I seeking to transport them but, am also willing to get involved but transporting isn't free.
I would recommend buying a semi load if one is interested in order to keep the transport fees as low as possible per tie. What you do with them is up to you.
I am not involved in making a dime off of this.   I'll be happy to put you in touch with the seller.
« Last Edit: March 21, 2017, 05:28:15 AM by Rams » Logged
« Reply #1 on: March 21, 2017, 10:58:26 AM »
Wow, that would make an excellent block house (and bike shed).  If you had a crane to move and stack them all.
Wanted one of these ever since I saw one at Mackinaw Island.   cooldude
Needs a little bit bigger rifle ports though.
Then my county would make me take it down.   Angry
« Last Edit: March 21, 2017, 11:01:55 AM by Jess from VA » Logged
« Reply #2 on: March 21, 2017, 11:12:38 AM »
Do they still impregnate rail ties with creosote ?
« Reply #3 on: March 21, 2017, 11:24:23 AM »
Yes, but don't call it that, the EPA will have a feeding frenzy and require an environmental impact study and fine you a bazillion dollars.
« Reply #4 on: March 21, 2017, 05:47:33 PM »
Grin you are probably right  cooldude After you posted that pic I thought they could make a nice, cheap little shop. But then I thought with our 128* summers, the fumes emanating off of them might kill off my last 2 remaining brain cells. 2funny
« Reply #5 on: March 21, 2017, 07:06:53 PM »
When I lived in Garrison Texas a lot of ties were cut in that area and I believe they were sent to Houston for "treating". Long time ago when I hauled flat bed had a chance to haul some outa New Mexico to Colorado but the truck owner nixed it. RIDE SAFE.
« Reply #6 on: March 21, 2017, 07:08:43 PM »
Rob,
If that structure had sufficient ventilation, it might not be a problem for those remaining brain cells.   I said might............   Check your phone, sent you a pic of the pile of ties...
Not 100% sure but, I thought or think all those ties are Oak.
« Last Edit: March 21, 2017, 07:11:10 PM by Rams » Logged
Pappy!
Central Florida - Eustis
« Reply #7 on: March 21, 2017, 07:48:28 PM »
Grin  But then I thought with our 128* summers, the fumes emanating off of them might kill off my last 2 remaining brain cells. 2funny
There ya' go, exaggerating again!!  Grin
« Reply #8 on: March 21, 2017, 07:54:37 PM »
Hmmm  Undecided  Well, I know it gets very hot there.  Hmmmmmm uglystupid2
« Reply #9 on: March 21, 2017, 08:14:11 PM »
2funny I think Pappy was insinuating I overstated how many brain cells I have remaining.
« Reply #10 on: March 21, 2017, 08:18:46 PM »
Rob,
I realize that, I was trying to be kind.   I'm not suggesting anything about the four years you spent in Algebra one class.   Smiley
OK folks, I'm jesting, I have no idea how many years Rob spent taking Algebra...............   2funny
« Reply #11 on: March 22, 2017, 01:54:28 AM »
Lived in a house in NY for awhile that the guy made the house for himself and use creosoted beams in it. It always had a smell in the house of it, not a bad smell but you knew what it was when you opened the door. Pretty house well built and you never had to worry about termites. I know down here the RR is using cement ties instead of wood.
« Reply #12 on: March 22, 2017, 04:28:19 AM »
Rob,
Algebra ? Hell, I never made it out of simple math in 3rd grade.
