November 19, 2025, 02:00:21 AM
Pinstripes
Topic: Pinstripes (Read 399 times)
Alberta Patriot
Pinstripes
April 01, 2017, 07:59:45 AM »
After the Supervalk conversion...I am looking for the correct medium gray metallic(sort of) stripe...is there an after-market one that matches close.
I want to match the front fender look for the rear fender set.
da prez
Wilmot Wi
Re: Pinstripes
April 01, 2017, 08:11:37 AM »
I have used the 3M products. A good automotive paint store or the usual , go online. They matched the orange stripe used on my bike and I referred it to others.
da prez
Alberta Patriot
Re: Pinstripes
April 01, 2017, 08:52:45 AM »
Quote from: da prez on April 01, 2017, 08:11:37 AM
da prez
Thanks I thought that 3M might be the ticket...just have to find a local supplier for a direct eyball match to the bike.
da prez
Wilmot Wi
Re: Pinstripes
April 01, 2017, 10:16:05 AM »
The online portal has a pretty good color match , but like you said , lets see it. If they have a color match scan , they will get you real close.
da prez
dreamaker
Harrison Township, Michigan
Re: Pinstripes
April 01, 2017, 11:56:47 AM »
I used Trim Bright on my fairing, the color was close, the only difference between the Honda pin stripe and the Trim Bright. The Honda had a courser metallic in it, but the colors were close. No one ever noticed.
I used the silver for mine.
http://www.trimbrite.com/index.php/features/striping
Alberta Patriot
Re: Pinstripes
April 01, 2017, 01:03:01 PM »
Quote from: dreamaker on April 01, 2017, 11:56:47 AM
Good to know the color is close...the rear frnder is far enough from any other striping so it should work...thanks.
=> InZane XXV
