May 02, 2026, 04:39:29 AM
throttle cables info
Topic: throttle cables info (Read 2230 times)
Hellcat
Arlington, VA
October 15, 2009, 01:30:00 PM »
Can anybody point me to pages concerning throttle cable install/maintenance in either the factory manual Dag has a link to, or in the Clymers I have? I can't find any discussion anywhere.
My bike seems to be inconsistent in terms of rpms - twist the throttle and hold it, and lots of times the rpms will go up and settle, but then continue to creep up some more. And then releasing the throttle it doesn't always snap right back to zero.
I'm hoping the throttle cable may be dragging and can be lubed or replaced. Want to try that before looking for other causes.
Wondering if the gas tank or anything else has to be taken out of the way.
Oh, and is there a difference between the two cables? I see one has the adjuster and the other does not.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
Re: throttle cables info
October 15, 2009, 01:43:00 PM »
section 3.4 in manual describes lubing it.
Last Edit: October 15, 2009, 05:09:36 PM by Misunderstood
October 15, 2009, 06:41:26 PM »
In order for the throttle to work properly there needs to be a slight amount of play in the throttle. Without a little play in the throttle the throttle tube wants to bind slightly and the increased pressure on the cables makes them tend to want to restrict easy sliding within the cables themselves. This is the function of the single cable adjustment on the throttle tube housing mounted on the handlebars.
October 16, 2009, 08:16:19 AM »
Like has been stated, proper cable operation is just a matter of proper installation[routing], lube, and adjustment.. They can be adjusted in two locations, the tank may need to be raised slightly to get a good look at the ends.. A little free-play is needed when the handle bars are at either lock/turn position..
Gunslinger
Brian Huntzinger, EMT-P
Wamego, KS
October 17, 2009, 08:52:13 PM »
It doesn't take much adjusting to really cause some issues with the cables either. As has been previously posted, a little play is a very good thing, and recheck with the bars turned to the stops both directions.
VRCC# 26468
VRCCDS# 0228
"Some learn by listening, Others learn by watching...
The rest of us have to pee on the electric fence ourselves"
