Good job. A little advise. Remove the side covers if you keep them straps where they are. They will break easy. Also make sure you loosen the for bolts holding the final drive on (before re-mounting the wheel) if you choose to not service the drive shaft.
I must have saved 20,000 or so. Where does all that money go?
Thanks, Chris. I followed the directions on this page for the four bolts on the final drive! Ain't nobody got time for worn out splines!
Which straps are you referring to? I strapped the bike to the lift using the holes that are under the seat. Didn't seem like the straps were anywhere near the side covers.
