« Reply #40 on: August 27, 2017, 07:06:08 PM » |
Here's an interesting fact.
Both locations are less than 850 miles for both Grumpy and Oss.
Now that should be enough info for a decent Serkle!!
Would that be a serkle or an ellipse?
« Reply #41 on: August 27, 2017, 07:26:25 PM » |
Would that be a serkle or an ellipse?  A Serkle is an off kilter circle... it is not bound by the normal definition of a circle.
Danny McMillin
« Reply #42 on: August 27, 2017, 07:32:33 PM » |
Gettin' a headache!!!
Red Diamond
« Reply #43 on: August 27, 2017, 07:39:48 PM » |
Second guess. Frankfort, Kentucky, 840 miles for OSS, 860 miles for Grumpy. Or Lexington
Narrowed it down to Lexington.
« Last Edit: August 27, 2017, 07:47:33 PM by Red Diamond »
« Reply #44 on: August 27, 2017, 07:41:55 PM » |
I'm even more confused now... I THOUGHT I had an idea based off of the newest info but it's way too close to Broussard to even be close to an Iron Butt... It's under 1,200 miles from Ossing NY to Tampa FL, so it won't be the half way point between them, there's gonna be a lotta overlap. Gonna go to bed and play with the data points given some more later while I pretend to work...
Never ask a geek 'Why?',just nod your head and slowly back away...  IBA# 22107 VRCC# 7976 VRCCDS# 226 1998 Valkyrie Standard 2008 Gold Wing Taxation is theft. μολὼν λαβέ
« Reply #45 on: August 27, 2017, 08:53:28 PM » |
I'm even more confused now... I THOUGHT I had an idea based off of the newest info but it's way too close to Broussard to even be close to an Iron Butt... It's under 1,200 miles from Ossing NY to Tampa FL, so it won't be the half way point between them, there's gonna be a lotta overlap. Gonna go to bed and play with the data points given some more later while I pretend to work... Remember it's two locations... that could be causing your confusion. If you draw the maps for each of the four start points, the overlap area should include both potential locations. FYI, the locations are not the same distance from Oss and Grumpy. The 800ish miles is for the site furthest away from each of them.
« Last Edit: August 27, 2017, 09:09:29 PM by f6gal »
« Reply #46 on: August 28, 2017, 05:39:58 AM » |
I plotted out all 4 data points, found the closest thing to a convergence point then plotted a point with an 85 miles circumference around that point. I still feel I'm off, but here's what I came up with using the latest hints:
« Reply #47 on: August 28, 2017, 06:09:01 AM » |
You've still missed at least one of the two cities. You need to draw the ellipse indicated by the president's latest statement and then just knock off the corners that are not withing your earlier maps. Too much evidence can either narrow down the target or just simply add confusion.
« Reply #48 on: August 28, 2017, 06:11:36 AM » |
Won't even begin to join in trying to figure out where but, it would be a wonderful experience for all if you're right. I ride new twisties every time I go out in every direction from Frankfort. For those interested in distilleries, there are (at last count) 7 distilleries within about 50 miles. All of them are located on twisty roads. The Bourbon Trail is not for the weak of heart.  Should this guess be correct, I'd be happy to help in anyway possible. Just let me know.
VRCC# 29981 Learning the majority of life's lessons the hard way.
« Reply #49 on: August 28, 2017, 06:50:59 AM » |
You've still missed at least one of the two cities. You need to draw the ellipse indicated by the president's latest statement and then just knock off the corners that are not withing your earlier maps. Too much evidence can either narrow down the target or just simply add confusion. Now Trump is trying to figure the Serkle ?
« Reply #50 on: August 28, 2017, 06:57:28 AM » |
You've still missed at least one of the two cities. You need to draw the ellipse indicated by the president's latest statement and then just knock off the corners that are not withing your earlier maps. Too much evidence can either narrow down the target or just simply add confusion. Now Trump is trying to figure the Serkle ?  F6gal is the president of the VRCC. Donald is the President of the U.S. I'm surprised you couldn't tell the difference.
« Reply #51 on: August 28, 2017, 07:15:46 AM » |
You've still missed at least one of the two cities. You need to draw the ellipse indicated by the president's latest statement and then just knock off the corners that are not withing your earlier maps. Too much evidence can either narrow down the target or just simply add confusion. Now Trump is trying to figure the Serkle ?  F6gal is the president of the VRCC. Donald is the President of the U.S. I'm surprised you couldn't tell the difference.   thankfully they are nothing alike
« Reply #52 on: August 28, 2017, 08:51:11 AM » |
 thankfully they are nothing alike  I really hope you're not trying to disrespect our president with that remark... On the Serkle... am I getting at least a little bit warmer? (Tried to make it an ellipse but the tool was fighting me so just left it as a circle Serkle.)
« Reply #53 on: August 28, 2017, 08:55:31 AM » |
 thankfully they are nothing alike  I really hope you're not trying to disrespect our president with that remark... On the Serkle... am I getting at least a little bit warmer? (Tried to make it an ellipse but the tool was fighting me so just left it as a circle Serkle.)  I hope you are not trying to imply f6gal and the Donald are alike ?
« Reply #54 on: August 28, 2017, 08:58:17 AM » |
I can think of very few greater compliments than to be compared to our president. And that's as political as I'm gonna get in this thread.
« Reply #55 on: August 28, 2017, 09:05:37 AM » |
No. (You'll need to work on that Serklipse.  )
« Reply #56 on: August 28, 2017, 09:19:32 AM » |
No. (You'll need to work on that Serklipse.  ) *Throws hands up on exasperation* I give up... for now at least...
G-Man
« Reply #57 on: August 28, 2017, 09:25:39 AM » |
I'm even more confused now... I THOUGHT I had an idea based off of the newest info but it's way too close to Broussard to even be close to an Iron Butt... It's under 1,200 miles from Ossing NY to Tampa FL, so it won't be the half way point between them, there's gonna be a lotta overlap. Gonna go to bed and play with the data points given some more later while I pretend to work... That's good to know.
G-Man
« Reply #58 on: August 28, 2017, 09:32:13 AM » |
From MY OWN past experience, going back to the same place is never as good as the first time. Still had fun, but.........
Even if it's the next city over, at least it's a different hotel, different restaurants, different local roads, etc. Makes for its own memories.
Just my 2 cents.
« Reply #59 on: August 28, 2017, 09:48:53 AM » |
Wherever it is within that general area, I'm sure it will be a terrific time.
Right now I'll only give myself a 25% chance of having the magic combination of time and money to make it there. It would probably be either a solo trip, or with Levi, if school is going well for him. What will likely happen instead is a car trip to the west coast with all four of us; they deserve it. If I can also do InZane XVIII, I'll be really happy.
« Reply #60 on: August 28, 2017, 01:15:55 PM » |
 thankfully they are nothing alike  I really hope you're not trying to disrespect our president with that remark... On the Serkle... am I getting at least a little bit warmer? (Tried to make it an ellipse but the tool was fighting me so just left it as a circle Serkle.)  Warmer... Just move this Serkle South and East.
Ken Tarver
« Reply #61 on: August 28, 2017, 01:38:35 PM » |
Blacksburg & Charlotte Ken
« Reply #62 on: August 28, 2017, 01:39:45 PM » |
LOL, I'm not certain I understand the complexity. With what F6gal told you draw two circles one eight hundred miles from Ossining; one eight hundred miles from Tampa. The resulting common ellipse contains both possible sites. Since she told you each distance was the most (to the furthest) and that the were equivalent, well within 1 mile, in distance you can eliminate the middle of the serklipse. How many reasonable possibilities can there be?
Dave Ritsema
« Reply #63 on: August 28, 2017, 04:53:28 PM » |
LOL, I'm not certain I understand the complexity. With what F6gal told you draw two circles one eight hundred miles from Ossining; one eight hundred miles from Tampa. The resulting common ellipse contains both possible sites. Since she told you each distance was the most (to the furthest) and that the were equivalent, well within 1 mile, in distance you can eliminate the middle of the serklipse. How many reasonable possibilities can there be?  The problem is always easier to solve when you already know the answer my friend.
VRCC 2879
Lake City Honda Warsaw IN
« Reply #64 on: August 30, 2017, 06:00:07 AM » |
Okay, walked away from it for a bit and came back at it fresh... How's this Serkle look?
« Reply #65 on: August 30, 2017, 06:29:13 AM » |
Okay, walked away from it for a bit and came back at it fresh... How's this Serkle look? It's inclusive but by using a huge circle rather than an ellipse it contains a lot of ground that it doesn't need.
« Last Edit: August 30, 2017, 06:31:53 AM by Willow »
« Reply #66 on: August 30, 2017, 06:31:21 AM » |
Okay, walked away from it for a bit and came back at it fresh... How's this Serkle look? It's inclusive but by using a huge circle rather than an eclipse it contains a lot of ground that it doesn't need.  Sometimes to catch more fish you need to cast a larger net.
« Reply #67 on: August 30, 2017, 06:33:49 AM » |
Sometimes to catch more fish you need to cast a larger net. Ah, but the Serk is not trying to catch more fish. He's trying to catch fewer, to narrow down the options.
« Reply #68 on: August 30, 2017, 06:38:39 AM » |
Sometimes to catch more fish you need to cast a larger net. Ah, but the Serk is not trying to catch more fish. He's trying to catch fewer, to narrow down the options. But my earlier casting attempts kept allowing one or two of the specific prize fish I was after to get away, thus the bigger net to catch the specific fish I'm after. Now that they've evidently been caught, I can work on a smaller, more efficient net to minimize catching the unwanted smaller, less tasty fish.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #69 on: August 30, 2017, 08:22:38 PM » |
Sometimes to catch more fish you need to cast a larger net. Ah, but the Serk is not trying to catch more fish. He's trying to catch fewer, to narrow down the options. But my earlier casting attempts kept allowing one or two of the specific prize fish I was after to get away, thus the bigger net to catch the specific fish I'm after. Now that they've evidently been caught, I can work on a smaller, more efficient net to minimize catching the unwanted smaller, less tasty fish. I truely enjoy the spirit that theVRCC shares. I've already use a big net to capture time off for both dates and will use a smaller net when the details of hotel have been determined for Ground Zero
1997 GL1500C - Black 1997 GL1500C - Purple 1997 GL1500C - Bumble Bee 1998 GL1500C - Blue and Cream
BudMan
"Two's in."
Tecumseh OK
« Reply #70 on: August 30, 2017, 08:47:53 PM » |
I've already use a big net to capture time off for both dates...
That's my approach too; I RETIRED!!!
Buddy Tecumseh OK MOOT# 263 VRCC # 30158 1948 EL Harley 2013 F6B Delux "I rarely end up where I was intending to go, but often I end up somewhere that I needed to be," Dirk Gently; Holistic Detective
baldo
Youbetcha
Cape Cod, MA
« Reply #71 on: August 31, 2017, 05:06:14 AM » |
markymark640
« Reply #72 on: August 31, 2017, 07:19:28 AM » |
I know I'm new and never been to an Inzane (yet), but I've been several Honda Hoots in Knoxsville in years past. There is a lot of nice roads in that area.
Anybody ever thought about the Fontanna Village Resort and Marina in Fontana Dam, NC as a possible location for Inzane ?
Lot's of facilities, meetings rooms etc, Nice rooms in the lodge and they also have a Campground, and a BUNCH of cabins (1 to 4 bedrooms) in the village as well as :
Complimentary Wi-Fi Restaurants ( and Bar ! ) General Store and Gift Shops Outdoor Pools and Lazy River Disc Golf Putt-Putt Golf Marina Fitness Center Miles of On-Site Trails Suitable for Biking and Hiking
And of course it's easy access to all the mountain roads:
The Dragon Cherohala Skyway Moonshiners 28 (Deals Gap to Franklin or the Highlands) The Devil's Triangle Blue Ridge Parkway Great Smoky Mountain National Park Rt 64 East from Highlands to Lake Toxaway or maybe a short ride over to Maggie Valley and the Wheels Thru Time cycle museum or make the big loop from Fontana Village to Almond, Bryson City, Cherokee, up to 441, west back to Townsend and on to Walland, thru Happy Valley down to Chilhowee and South East back to Fontana Village
rainman
Steve ( rainman) Eads
Bloomington Indiana
« Reply #73 on: August 31, 2017, 12:03:22 PM » |
that would be great but It will never happen. no big city's around
ksmith50229
« Reply #74 on: August 31, 2017, 01:10:26 PM » |
were hoping for the 10 to the 15  just incase we have snow days at school.
« Reply #75 on: August 31, 2017, 04:19:25 PM » |
Fitness Center
Now you just turned away most of the folks.
« Reply #76 on: August 31, 2017, 04:28:35 PM » |
Fitness Center
Pappy!
« Reply #77 on: August 31, 2017, 04:54:08 PM » |
WELL.....It looks like Grumpy, Bronxboy, Lesa, and I will be meeting up for less than an 850 mile ride, hopefully! Am betting other Florida riders will be along as well. Hope John Scmidt can do this one.
« Last Edit: August 31, 2017, 05:02:38 PM by Pappy! »
« Reply #78 on: August 31, 2017, 07:49:20 PM » |
We haven't always been in big cities. But they need to have a decent sized hotel.
