March 28, 2026, 12:03:46 PM *
Author Topic: LED turn signal bulbs  (Read 552 times)
Big Rig
Woolwich NJ
« on: June 24, 2019, 05:45:24 PM »
Has anyone used them? I will have my Valk for 20 years this coming November....first rear blinker to go out....I am very disappointed! 2funny 2funny 2funny
Picked up Sylvania 1156 LED bulb - Normal bulb I believe is 7506??? Anything I should be concerned with using LED's???
« Reply #1 on: June 24, 2019, 05:50:36 PM »
Had mine 22 years now and still all original bulbs except the headlight I put a daymaker in it but until
Then two years ago it was also the original  Roll Eyes the original  battery lasted 8+yrs Roll Eyes
« Reply #2 on: June 24, 2019, 09:02:58 PM »
LED turn bulbs will cause load changes on the flasher switch and they won't flash correctly.
6adan
Zip City, Alabama
« Reply #3 on: June 25, 2019, 04:41:51 AM »
Are you replacing all with LEDs or just the one? If just the one it might flash but if all you will need a electronic flasher also you need to get amber color LEDs.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
Big Rig
Woolwich NJ
« Reply #4 on: June 25, 2019, 11:57:09 AM »
Hmmm....Not the bulb, cut wire under the fender....looks like it was worn at one of the little wire supports on the underside of the fender....boy is it DIRTY in there...
20 yo bulb is still good!!!
ha ha ha
« Reply #5 on: June 25, 2019, 12:10:17 PM »
ha ha ha
Disco
Republic of Texas
« Reply #6 on: June 25, 2019, 05:39:07 PM »
In addition to the Cyclops headlight, Radiantz taillight, and Electrical Connection auxiliary run/brake, I have these on all 4 corners with no ill effects to the flasher.
https://www.superbrightleds.com/cat/tail-brake-and-turn-led-bulbs-for-motorcycles/
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
