December 31, 2025, 01:17:05 AM
Bumblebee stuttering
Topic: Bumblebee stuttering (Read 1045 times)
jackt
This is one of my babies
Central Kansas
March 05, 2020, 05:52:31 AM »
I have a 97 bumblebee always ran great. but lately it (stutters) when I first start for a few minutes then goes away. Only when it first stats, And starts very easy very little choke. Only does the first time I start in AM then not again all day.
It has stock exhaust and its very quite just kind of phoot phoot (that's the beast I can describe sound).
Any ideas I have checked the valve clearance and timing and its right on.
I have ran Sea Foam and Lucas injection cleaner thru it.
Thanks for your suggestions
jack
2006 Shadow
1999 Standard (fast black)
1997 Bumblebee
2005 Gold Wing trike
KRC
Re: Bumblebee stuttering
March 05, 2020, 06:25:51 AM »
I'd check all the vacuum lines going between the carbs, when i first bought my 03 I thought it was amazing since it started with zero choke even when it was 40 F out... then I found 3 of the lines split wide open and the rest cracking.
=> InZane XXV
