March 22, 2026, 04:30:59 PM *
Author Topic: A chance to spend a couple exciting days at the Schmidt house.  (Read 973 times)
« on: March 15, 2022, 06:42:14 PM »
No...I didn't misspell that. Grin  I'm about ready to swap out the motors on my trike so just tossing out the invite to anyone that wants to lend a hand. I know, it's a strange offer but never hurts to ask. It will involve unbolting the u-joint at the rear and removing it from the back of the engine...just pull out like on a car. I plan to try and pull the motor without removing the carbs, airbox, tank, etc., note I said TRY! It will be an experiment for sure. Most likely won't be until near the end of March or first part of April, mostly in hopes of warmer weather at that time. I've R&R Valk engines in the past, not difficult but is time consuming...especially if you remove everything on top first. So, just thought I'd ask...no harm in that. Wink
FWIW...my post is legitimate for a reason; I'll be 84 in a couple weeks and simply don't have the flexibility and/or the stamina of 10-15 yrs. ago. In the past I could spend all day and half the night in the shop but now...not so much. In the past, I've changed a Wing 4 cyl. motor out in a day with daylight left over. I've changed a Valk motor in a two day period, including breaks for lunch, running for replacement bolts, nuts, clamps, etc. Now, it will most likely take me three days minimum, assuming no setbacks. Figured it doesn't hurt to ask.  Wink
« Last Edit: March 16, 2022, 07:35:14 AM by John Schmidt » Logged
« Reply #1 on: March 16, 2022, 03:55:41 AM »
I have to ask, what’s the reason for changing engines?
SCain
Rio Rancho, NM
« Reply #2 on: March 16, 2022, 06:11:32 AM »
If I were closer, following your progress on this swap.
Steve
Steve
« Reply #3 on: March 16, 2022, 06:40:00 AM »
I'm pretty sure he's got a goldwing motor and all the stuff to
make his Valkyrie trike have reverse...
« Reply #4 on: March 16, 2022, 06:42:06 AM »
That will be worth the effort for sure!
« Reply #5 on: March 16, 2022, 07:21:15 AM »
BINGO!  cooldude
TJ
Lake Placid , Fl.
« Reply #6 on: March 16, 2022, 09:29:44 AM »
 Dogs and I will be right over to help you John....     2funny 2funny
Jack B
Two Rivers Wis
« Reply #7 on: March 16, 2022, 10:02:27 AM »
I can give you a hand.
Jack
Let’s RIDE
JimC
SE Wisconsin
« Reply #8 on: March 16, 2022, 10:21:54 AM »
John,
I can probably give you a hand if it works out between Dr. appointments.
Jim
Jim Callaghan    SE Wisconsin
« Reply #9 on: March 16, 2022, 10:45:32 AM »
Thanks for the offer TJ but they don't allow pets here at the hovel. You have more than one now?
Jack & Jim...let you know when I'll start work on it.
