Pilot Screw Adjustment
<< < (2/5) > >>
HayHauler:
Quote from: Hook#3287 on September 03, 2025, 05:40:40 AM
https://www.google.com/aclk?sa=L&ai=DChcSEwiGpszBzbyPAxXoUn8AHYUZMF0YABAJGgJvYQ&co=1&gclid=EAIaIQobChMIhqbMwc28jwMV6FJ_AB2FGTBdEAQYAiABEgLQrPD_BwE&cce=1&sig=AOD64_1hezmyG2RueyDQiy8L8zM6T_4NXA&ctype=5&ved=2ahUKEwisycXBzbyPAxU6LtAFHQI_IgUQwg8oAHoECBgQCw&adurl=
I bought one of these but have yet to use it, so can't say it works correctly. Can't see why it wouldn't.
That or someone with very small hands   :roll:  :)
I have that tool and with the D bit in it, it actually works pretty good.  I lubed the gear on the 90 degree joint and that helped with the adjustments.
Hay  8)
Pluggy:
You may want to double check that the enricher "choke" is fully off when you want it to be off.
dan7uk:
Quote from: Pluggy on September 03, 2025, 09:25:00 AM
Good idea
dan7uk:
Quote from: HayHauler on September 03, 2025, 07:42:40 AM
Hay  8)
[/quote
Ordered that tool, looks promising.  Beats taking manifolds off.
How many turns out on pilot screw once it's lightly seated?
WintrSol:
+1 Note that there is a slide pulled by the 'choke' lever on the left bank, connected by cable to a similar one on the right bank. Both need to be lubed, then adjusted so the little enrichment valves are pulled the same, and don't stick away from the seats. Mine needed both.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
